Question about Samsung PCJ534RF 53" Rear Projection Television
RED OUT OF ALIGNMENT
I was changing channels the other day and suddenly the red fell out of alignment with blue and green. It is not evenly out of alignment all over the screen but has a wave effect on the top left side and bottom left. In the middle of the screen the alignment looks ok and in the bottom right. We had this happen a few years ago while the TV was under service contract, however I don't know what was done to repair it. any ideas? The TV has been working great besides this up until now. I pulled the covers today to try to see if I could spot a board cleaner than the rest or something that looked like it was newer in order to get an idea of what was replaced the last time. No luck. JLW5561@aol.com Thanks! Jeff
  • 3 more comments
  • jlw5561 Feb 07, 2008
    It is a 52" rear projection TV
    It is a 52" rear projection TV. The red has slipped out of alignment, but not evenly. It has a "wave" effect. The red is there so it must be whatever keeps it in sync with the blue and green.
  • jlw5561 Feb 08, 2008
    The set is about 7 years old and it does have three cathods inside.
  • rhu61228 Jun 19, 2008
    It
    is a LG PT-43A83 GALLERY rear projection TV. The red has slipped out of alignment, but
  • tj77jsy Oct 01, 2008
    I have a 3 1/2 year old 42 " samsung projection tv. A week ago it has started to show red shadow on the right side of the TV. The rest of the TV is fine. Your help will be much appreciated.
    Thank you
    Scholar:
  • 163 Answers
Smack it on the back closest to the board (Not Hard)..to see if its a Cold sloder joint issue.. (Trust me I've seen issues).. Also Not familiar with the model is it Flat Plas, CRT, LCD?
Talk soon....
Posted on Feb 06, 2008
  • Ken LaDere Feb 07, 2008
    Should be an alignment board depending on the age to set the linearity.. (For RGB).. How old is the set? Rear may have 3 seperate mini cathodes...
    (Its been a while Jeff)...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Oct 26, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Red and Blue slightly out of alignment
If constant all over the screen it is the static convergence that needs adjusting.
The green is not adjustable!
Move the red magnets with the blue covered with a piece of card to align with the green and then move the blue with the red covered to align with the green.
May 13, 2017 | Panasonic PT-51G41 51 in. Rear Projection...
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Convergence -manual
Replace the convergence amps and test and replace any or all of the 2.2ohm resistors in the yoke return path out in front of the amps. This unit takes two STK392-110 Sanyo originals, DO NOT GET CHINESE KNOCK-OFFS... Buy them from Acme sales out of Florida and you can be assured they're originals.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Oct 11, 2008 | Toshiba 42H81 42" Rear Projection...
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
The red, blue, and green are all out of alignment. HELP!
Sounds like the guns are out of alignment. This isn't normally something that a user can adjust.
Has the television been dropped/jarred or moved recently?
If the TV has a manual degauss function, you can try that (assuming it's really a CRT). Otherwise unplug it from the wall for a half hour, then plug it back in and see if anything has changed.
Apr 07, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Color alignment problem
You will need to put the unit into wahts called service mode because it will have to totally realigned since you change the whole module you changed the chip that had you stored memory setting for convergence called an EEPROM. here in the shop I would unsolder the old EEPROM and put it on the new BOARD. Also on most models you don't have adjustments for the green you have to move red and blue to match green. Imay want you to describe again to me what you can adjust now with the new board in the unit can you move all colors left right and up/down
Mar 10, 2008 | Samsung HCM4215W 42" Rear Projection...
Panasonic PT-53WX42
convergence IC bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Red is off to the right while blue and green light are in sync
Convergence alignment issues are common to all rear projection
TV's....Repair requires replacement of STK IC's on large heatsink.
After repair, alignment often returns to normal......T.
Oct 27, 2007 | Sony KP-51HW40 51" Rear Projection...
Samsung PCJ534RF 53" Rear Projection Television Logo
105 people viewed this question
Jerry Greenberg
Jerry Greenberg
