Question about Gateway FPD2275W LCD Monitor
PLEASE HELP!!!! 19" i-inc LCD monitor (AG series)
Hello, i need help with my monitor, it is brand new and i just hooked it up and the colors and screen resolution are horrible, i have gone in to the nenu and tried to adjust on my own but still no luck, i also converted back to factory settings and again still no luck...i am attaching a photo of my monitor...any help will be greatly appreciated :)
    Master:
    Sergeant:
  • 440 Answers
What is native resltions 1280-1024 right are using dvi white plug longer way cleaer might wann upgrade your video card if u dont have dvi out ok
Posted on Feb 06, 2008
  • nick helpap
    nick helpap Feb 06, 2008
    no problem thx u again rate this as ffix ya so it helps others
Samsung 19 "LCD SyncMaster 931BW ...Colored
Hook a spare monitor to the computer to insure there is no problem, if everything checks out okay,the problem is in the Samsung screen display and is not cost effective to repair, far cheaper to buy new. But if both screens show the same problem, it is a video graphics card issue in the computer, one further thing if the video cord is detachable from both ends, sub another cord.
Feb 04, 2011 | Samsung 19" LCD Syncmaster 931BW Monitor
Hello, i need the inverter for this monitor proview pl913s silver 19 inc. flat panel lcd. product# pl913s The monitor turns on and shots off after a second. how can i resolve this thanks
Did you inspect the caps for domed tops in the power supply/inverter board yet? Worst case will be the lamps assembly.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 14, 2011 | Proview PL913S 19" Flat Panel LCD Monitor
AG Neovo Monitor not working
nothing you can reset from monitor other than color brightness. You can contact with AG Neovo as service.us@agneovo.com to have a RMA number and they will estimate you the repair fee if it is out of warranty.
Jan 06, 2010 | Neovo E-19A 19" LCD Monitor
My new monitor will not display RED. All the
Check for a bent pin in the VGA connector. Each color, Red, Green, and Blue has its own pin for the signal. If its pin is bent then no color!
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 29, 2009 | Samsung SyncMaster 930BF 19" LCD Monitor
FPD1975W 19 inch LCD Monitor Problems, no display or if display no proper colors
I suggest these tests and in this order.
1. trying a new VGA or DVI cable. Fixed it? If yes then your old cable is damaged toss it out. If no try step two.
2. Hook it up to a new computer. Fixed it? If Yes Your graphics card on the first computer may need to be replaced If No you likely have hardware damage in the monitor which will need to be repaired by a technician. If this is the case I recommend buying a new monitor the cost for repair is likely almost as much as a new monitor.
Nov 30, 2009 | Gateway FPD1975W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor color has changed to blue
Hey Buddy
My AL1916W was having same problem, its due to faulty IFB which cannot save colors after pressing reset, get it replaced from acer, if its in warranty, acer will replace ur LCD within a week.
Mar 15, 2008 | Acer AL1916W 19" LCD Monitor
After any game, and go back to XP, my monitor go like 8 bit color,have to power down and up
Try useing a different resolution. The native resolution should probable be 1280 x 1024. Try updateing the video drivers.
Nov 23, 2007 | Acer AL1916W 19" LCD Monitor
Yellow hue
My name is Todd and I'm with Dell's online outreach group.  Have you tried hooking that monitor up to another system to see whether it's the monitor itself or the system causing the problem?
Is the color distortion always there, or is it only happening at certain times or with certain applications or programs?
Let me know if you're able to try this monitor on another system, or another monitor with this system.  If not, we can try a few different things to test it.
Thank you,
Todd
Customer Advocate
Dell, Inc.
http://direct2dell.com/one2one/archive/2006/11/19/3648.aspx
Oct 08, 2007 | Balance CM2019 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
67 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
