Question about HP Compaq nx9030 Notebook
Does not start...
When i press start the power led is on and i can hear the cpu fan for some seconds and it stopes here. No image, no sound, nothing.
  • 2 more comments
  • Twins2 Feb 07, 2008
    That's what i im afraid of...
  • anamroqa Feb 15, 2008
    my compaq nx9030 does not work when i press the power botton its only light the blue light and nothing appear on the minitor
  • isso Mar 31, 2008
    when i power on my labtop, the pwoer comes on but nothing appers on the sreen even the drives does not spin neither the fan. The fan just take two or three rounds of movement then stop. Could anyone help me. am confuse and at a middle of work.
  • wayne230370 Apr 15, 2008
    try to turn on laptop power button comes on load beeping then the blue standby flashes and computor will not come on
  • 43 Answers
:( motherboard is dead :(
Posted on Feb 07, 2008
No the motherboard is not dead becouse when you press and hold the power the computer truns on then you should turn it on many times then it work after a while
Posted on Feb 15, 2008
  • Nikhil Bhargav May 18, 2012
    but even after many tries it doesnt switch on! i had taken my laptop to a service center he told the IC is not working.
I have a emachine that powers ou, power pack fan, cpu fan but not the hardrive. It shut down and now won't start up. No beeps
Unplug from AC, open the case, clean if necessary, reseat the memory mods, use Electronic Contact Cleaner spray on contacts, plug in, push the on/off button. Does it begin to start, and in a few seconds completly shuts down? No LED's , no fans, nothing? Sounds like a PSU failure. Mine went out in 6 years.
Jan 09, 2013 | Computers & Internet
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
HP G71-343US LAPTOP DOES NOT TURN ON
First check the power source and if ti gets power...Check also the battery. If it seams to have power but it just do not start ..than check the ram memory ...and also the CPU fan ..Usually if it seam to have power but when you hit the on button do not make any sound at all ..not even the fan ..than it is either the cpu corrupted or the motherboard..but mostly the cpu ..cause when the motherboard is out of order...usually it do not show power at all on the power led and hdd led....
If it starts the fan ..but no image at all..you may consider a video card issue ...but for now..try to open it and see if the ram memory is not to blame ..or the cpu ..cause after you eliminate a power issue ..these 2 are the only one capable to make it act this way ..
Oct 09, 2011 | HP Computers & Internet
Hi. my CPU (system) does not start. When i press the power button, the light turns on for a second then nothing happens.
Does the power supply fan spin when you switch it on ??
Do you hear a"posting" beep??
Does the CPU fan start to spin??
If no to all of these probably dud mobo.
Dec 21, 2009 | Intel CPU
I had a loud fan noise coming from inside my desktop box for a while. One day (& ever since,) when I went to turn the box on, absolutely nothing happened: no fans, no BIOS, no LEDs. I made no config...
This may work however i think by ignoring the sound of the Fan you might have destroyed the cpu and the motherboard.If you can try the processor in another machine you might just have to replace the motherboard only.
Good Luck
Dec 03, 2009 | Intel Motherboard
Acer travelmate 292elcI problem starting
Hi, sorry to hear you are having problems. When this happens it usually suggests that the CPU/system board has failed. If the laptop is still under warranty I would suggest taking it back because this is something that will be covered and they should be able to fix it or replace the laptop itself. If not you may have to pay to have the system board/CPU replaced. Good luck and hope this helps. Si :)
Sep 26, 2007 | Acer TravelMate 292ELMI Notebook
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
HP Compaq nx9030 Notebook Logo
104 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
