Question about Vicks Warm Mist V745A 1 Gallon Humidifier
Reset light comes on, unit stops operating when tank is full
I completely cleaned all hard water deposits and inside of tank. Unit works for about 5 minutes expelling generous amounts of warm steam. Then unit stops, reset light comes on which indicates unit needs water. Tank is full. I turn it off...wait 5 minutes...turn it back on and it works great for about another 5 minutes when the unit stops, reset light comes on etc. Hope there is an easy fix. I have a sick baby that needs the humidifier. Thanks guys
  • 5 more comments
  • JTT1 Feb 19, 2008
    I had the same problem. At first the problem only occured on high, and like you I found that using the low setting (temporarily) resolved the problem. A couple of weeks later it started doing the same thing on the low setting. That is where I'm at now.
  • ngardeniac Feb 01, 2009
    I just purchased a brand new vicks warm mist humidifier today and when I turn it on, it automatically goes to reset light. Is there anything I can do to avoid returning it or is it just faulty?
  • Noah James
    Noah James Jan 27, 2012
    What I did is stretch out the spring in the valve. Similar to how you would stretch out a spring in a bath tub drain to keep the lever from dropping. This was easy, though it took a while to get there. ALSO make sure the rubber piece is on the inside and on the end of the black plastic pin with the open cone facing up. I'm pretty sure originally my piece was jammed in there or on the other side.
  • Anonymous Mar 18, 2014
    humidifier stopped working .. the tank and reservoir are full. When you turn on the light on dial flashes green.. nothing else. The fan does not turn on
  • Paul Dye
    Paul Dye Jan 29, 2017
    My unit didn't have a spring valve rather it had a pendulum with a float. In order to get it set right I took s penny and sat it on top of the float and slid it up and down the length of the float until I reached the desired water level at the heater. I then superglued the penny in place. No more problem.
  • Paul Dye
  • James Mercer
    James Mercer Dec 27, 2017
    My V750 (successor to the V7450) had the "out of water/red light" come on straight out of the box. Searched around, stretched the spring as others have (which I frankly didn't think was necessary), and that didn't fix it.
    However... the float switch was the solution. The float switch is the piece that sits UNDER the container and the tower. If you don't settle that in EXACTLY CORRECTLY, it stops the water from flowing out of the container.
    It's really, really finicky. Make sure that it and the tower are settled in properly, then - when putting the tank back on - make SURE the tank is snugged up against the tower. When I did that, I noticed that the tower moved slightly toward the front of the unit. (I didn't realize that it was not perfectly straight until then, even though it was locked in by the sliding blue tab.)
    Since I did that this morning, the unit's been running for over an hour, no problems.
I was up all night with this since I just purchased it yesterday and I wanted to be certain that there wasn't some simple alternative to returning the humidifier since the reset light keeps going on immediately after I turn the unit on AND I've already followed all the directions to the T. Believe me - I was ready to return it cause ain't no 38.99 worth me doing all this tinkering and trying to figure out why they couldn't make the unit correctly cause apparently A-LOT of people have this problem. If it wasn't for my three children being so ill including myself getting sicker going out to purchase the humidifier and I was trying to avoid going back out to further compound my illness----I WOULD have just returned it. MAYBE I still will return it. ANYWAY, here's the deal: the water in the tank SHOULD flow into the boiling chamber where of course steam rises from there; however, the WATER VALVE in the CAP to the water tank does not allow any water to flow into the boiling chamber because it is so tight. The reset light goes on as if there was no water in the tank because of course, the heater is on, but no water is getting boiled because the water can't get in. There are a few things you can do. First: the water valve is a little stick and a spring within a piece of rubber that can be slipped out of the cap (this is what I chose to do). Now the water flows easily and even with the unit set to high, there is no problem. It just works. Second: You could remove ONLY the stick and spring from the water valve's rubber piece. This would work if the hole in the rubber piece happens to allow steady water flow (mine wouldn't). Third: you could probably do some cutting til you were satisfied with the results.
Posted on Feb 01, 2009
  • 3 more comments
  • boom boom
    boom boom Jan 13, 2014
    I just found out this by myself so I hope it does the trick. 1) Remove the cap 2) remove the rubber from the sinkhole 3) Now you have to place them back except the rubber shouldn't be inside the hole, just place it on top. It
  • Kellie Davis
    Kellie Davis Nov 22, 2016
    I ACTUALLY PULLED THE SPRING AND EXTENDED IT THEN PUSHED THE PLASTIC PIECE BACK INTO THE SPRING "clearly THE SPRING is now waaaay longer" then attached it back to the dock. Flipped the switch and WALLLAAAA! I'm soooo happy this worked because my baby is so stuffy. Also, if you want more steam (like I do because it gets all in my 6 mth old) add some kosher salt. *A word of caution.. when I connected back to the dock water DID spill out. Soon as it did I said I DONT CARE* Small price to pay for longevity. Good Luck!
  • Michael L Donnelly
    Michael L Donnelly Mar 12, 2017
    Easy just take cap off spring out cap back n works well.
  • Aming Altalaguire
    Aming Altalaguire Feb 01, 2018
    Works like magic!
  • Aming Altalaguire
    Works like magic!
OK, had the same problem. When reset light comes on, unplug humidifier and replug. This resets the reset...Now the light will turn green when you put it on I or II. Happy vaporizing!
Posted on Nov 11, 2010
Thanks, ngardeniac! Took out the valve. Works fine. A little messy, but works fine.
Posted on May 09, 2010
    New Friend:
I have the same humidifier and found it was doing the same thing even though the water reservoir was full. But I fixed it! If you remove the water tank, the cooling chamber there will be a locking mechanism you just pull back with your thumb and pull out the double tray to access the heating chamber there was tons of hard water deposits and shards built up like no tomorrow over the heating pod. Unplug your device and scrape out all the gunk and either use your fingers and nails to scrape it off or use a sponge with a scouring side and make sure you rinse it all out including in the removable tray there will be some deposits in that too. After finding all this my humidifier worked like brand new!! Hope this helps everyone.
Posted on Mar 10, 2015
  • Imma Choi
    Imma Choi Jul 08, 2015
    This worked for me!
  • Michelle Widmer
    Michelle Widmer Apr 13, 2016
    Didn't work for me ??
    New Friend:
I have had the same problem with mine. For a while unplugging and replugging it would reset it. Then after a while that would only work if I put it on low after unplugging. Eventually none if it worked so I unscrewed the cap and pulled on the black washer/plug until it clicked back out. Then released. No overflow water problems because the washer is still there but I've forced it out so it understands there is water in the tank. Works just fine on high or low every time.
Posted on Feb 08, 2015
  • Jennifer Bee
    Jennifer Bee Mar 10, 2015
    Pull your unit apart and there is probably a ton of calcium/hard water deposits built up over the heating chambers that makes the device think there's no water. Clean all that out and it'll work like new again.
Mine was full of water, orange light came on instead of green. I tried turning it off
Posted on May 04, 2011
  • ForTheBoys May 04, 2011
    Not sure why the site is cutting off my text. Here is my solution:
By setting the unit on I (low) instead of II (high) solves the problem. The unit doesn't produce as much warm mist as before, but it does run continuously until the tank is empty.
Posted on Feb 07, 2008
Tank is full, but after a few minutes why does it stop and the 'Tank Empty' light comes on?
Reset light comes on, unit stops operating when tank is full ...
www.fixya.com/support/t384577-reset_light_comes_unit_stops_operating
Feb 6, 2008 - Question about Vicks Warm Mist V745A 1 Gallon Humidifier ... Tank is full. ... for about another 5 minutes when the unit stops, reset light comes on etc. ...the humidifier since the reset light keeps going on immediately after I turn ... water in the tank because of course, the heater is on, but no water is getting ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Jan 17, 2016 | Humidifiers
Walgreens Dual tank humidifier 2035 stopped working
I've never seen this model, but it would suggest that the unit is unable to function due to either an electrical failure or needs a serious deep cleaning (esp.the part that interacts with the water to form mist.) I would completely empty the unit and clean it, then partly fill the reservoir with 50/50 mix of white vinegar and water and let it sit for 24 hours (possibly longer) to remove any deposits. (Doesn't take much build up to kill the ultrasonic process). Other than that, try calling the manufacturer and see what they will do for you. (Think it's Sunbeam).
Dec 21, 2015 | Walgreens Dual Tank Ultra Sonic...
How to clean humidifier
I generally use White Distilled Vinegar. Clean your unit out the best you can with warm soapy water first and then soak or add the straight vinegar into the filter containment area and use a mild bleach solution for the water tank and soak and swish a little for 15 minutes then drain and rinse with fresh cold water and let air dry. The mineral deposits will slowly dissolve but will still take some scrubbing with a blue pan scrubbing pad or hard toothbrush. Depending on how hard your water is and if you use a water treatment additive will make a big difference in the cleaning process. Some people prefer to use distilled water in cool units as well as steam since it is almost completely mineral free and doesn't cost to much. Regular cleanings based on useage and water condition will greatly help the life and good operation of any humidifier including periodic filter changes if required.
Sep 26, 2014 | Humidifiers
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
My Vick's Warm Mist V74A was absolutely lovely when I purchased it (May of June of 2010). However, I CAN ADMIT (because I'm sure majority of people are not) that I have not cleaned it since or read my...
The simplest and easiest way to clean the interior workings of the unit is to fill the tank with a 50/50 solution of White Vinegar and Bottled Distilled Water. Run the unit for an hour. Turn it OFF for 30 minutes and the run it again, until the tank is almost empty and turn the unit OFF. Empty the remaining solution and refill the tank with Bottled Distilled Water. Turn the unit ON and operate it for at least 45 minutes to an hour. This will flush out all of the remaining solution.
What you saw before before cleaning the unit, was a build up of mineral deposits and scale from the tap water that you used. In the future, I would highly recommend that you use Bottle Distilled Water, rather than tap water. That way, you won't have to flush the unit as often and you'll be using water that is mineral free.
Hope this helps you solve the scale and mineral deposit problem. Please don't forget the rate my response to you. Thanks!
Apr 14, 2011 | Vicks Warm Mist V745A 1 Gallon Humidifier
How to clean air-o-swiss humidifier?
Gererally according to the booklet in the box.
If you no longer have those instructions, simply clean out the
basin, make sure no mold, dust, hardwater or calcium is deposited.
Use a 10% bleach water solution to kill bacteria, and thats is basically it.
Just dont miss any spots, but humdifiers should be cleaned every few uses.
Feb 19, 2010 | Air-O-Swiss 7133 Humidifier
What works best in removing Calcium deposits (I believe)? I've got the BWM2600 filterless and this deposit has hardened on the inside and seems to be slowing down or preventing the vapor from coming...
one thign that you can do is get a solution for any hardware store or any store that sells humidifiers. then you would take 1 cap full of the solutions per gallon of water. and let it run through your unit.. or if you don't want to do that. what you can do is rinse the tank portion out with bleach and rinse really well. get a soft toothbrush and lightly brush off the build up off the coils. if that doesn't work please let me know and i'll see what else i can do.
Jan 04, 2009 | Bionaire BWM2600-UC Humidifier
Venta 207 digital humidifier
Caring For Your Venta-Sonic Humidifier
IMPORTANT!
Always unplug the unit before cleaning!
When to Clean Your Humidifier
 Clean your humidifier weekly or more often during heavy use, depending on your
individual water quality. Clean your humidifier before storing and after long periods
of storage.
 When cleaning the inside of your unit, keep water away from the air outlet. Exterior
may be wiped with a damp cloth when unit is off and unplugged.
Cleaning the Oscillator and Water Sensor
 Turn off the unit and unplug power cord. Remove tank from base and empty
reservoir in base. Use cleaning brush provided in base to clean off mineral deposits
and sediment from oscillator and water sensor. Do not scrape or clean with tools
that have metal parts. Be careful to not damage the surface of the oscillator.
ATTENTION: Damage to the oscillator may cause the unit to not work properly.
 The oscillator (ultrasonic transducer) is highly sensitive. Keep this important part
clean and treat gently. Do not touch the oscillator while the unit is operating.
 Do not use soap, cleaning agents, detergents, or other chemicals for cleaning the
tank and humidifier.
 After cleaning fill water tank (see instructions above) and return tank to base.
Storing the Venta-Sonic
Switch off and unplug power cord from A/C outlet. Empty remaining water from base
and tank. Clean tank and unit (see for instructions above). Make sure all parts are
thoroughly dry—allow at least 24 hours to dry. Leave the filling cap of the tank
loosened. This will keep the cap and gasket from sticking together. Pack Venta-Sonic
in original packaging and store in a cool and dry place.
You can find your manual at this link:
http://www.venta-sonic.com/pdf/vs207manual.pdf
Good Luck.
Apr 03, 2008 | Venta VS 100 Humidifier
Clean
This is the link to your manual:
http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
CAUTION:
Always be sure that the appliance is unplugged and switched OFF before cleaning or attempting to store the item. NEVER PLUG OR UNPLUG UNIT WITH WET HANDS.
DO NOT leave water in water tank or water basin when unit is not in use as it may result in the build up of mineral deposits and bacteria that can inhibit the output efficiency of the humidifier.
PLEASE NOTE that if water remains in the water tank for more than a day or two, bacterial growth is possible.
ALWAYS use fresh cool water when using unit.
NOTE:
When removing water tank, water may accumulate under vapor lid and on the bottom of the water tank. It is recommended to have a dry cloth ready to dry wet surfaces.
DISINFECTING THE WATER TANK AND WATER BASIN
1. Fill water tank with 1 teaspoon of household bleach in 1 gallon of water. Let stand twenty minutes, shaking vigorously with two hands every few minutes, drain and rinse with clean water until the bleach smell is gone. Dry with a clean cloth or paper towel.
2. Wipe the water basin with a soft cloth dampened in the bleach and water solution. Rinse the water basin with cool water to remove any bleach smell. DO NOT IMMERSE WATER BASIN IN WATER.
3. Wipe all exteriors surfaces of the base with a soft, dry cloth. Do not immerse the base in water or use water to clean the base. An electric shock may result or the humidifier may be damaged.
NOTE: It is recommended to clean humidifier with water and bleach solution as stated above after using the humidifier the fourth time.
GENERAL MAINTENANCE AND CLEANING
Before any cleaning operation, switch the humidifier off and unplug it.
1. Always unplug the unit before cleaning.
2. The humidifier must be drained and cleaned before storing.
3. Once unplugged the exterior of the unit may be cleaned by wiping with a soft dry cloth. Caution: The ON/OFF switch must be thoroughly dry before unit is again plugged into power source.
4. There may be some lime deposits in the nebulizer, particular in areas with hard water. Overcome this drawback by cleaning the nebulizer with water and vinegar on a soft cloth regularly, as follows:
A. Dampen a cloth with vinegar and wipe the nebulizer gently, until the lime deposits disappear completely.
B. Rub down gently with a dry cloth and remove remains of humidity.
C. Do not rub the nebulizer with solid objects.
D. Do not clean with chemical products
5. When cleaning the water basin do not place the nebulizer directly under the water tap.
6. Never immerse the unit in water or let water enter the fan vent (see figure 3) or any other openings.
7. It is normal for water to be in the water basin. However water must not get inside the central body. If this should happen, take the humidifier to an authorized service center before using it again.
8. Clean the inside of the water tank at least once a week, as follows:
A. Fill the tank with clean water adding a few drops of bleach. Close the tank completely with its cap and shake by holding the tank with both hands. Do not hold by handle while shaking the tank.
B. Rinse thoroughly.
Water Level Sensor- The water level sensor is made of three key parts. When cleaning DO NOT MISPLACE these parts and MAKE SURE that you assemble these three parts correctly after cleaning and before operating humidifier. They are as follows:
Plastic Cap – this part has 4 flat tabs coming out from the bottom and is placed on top of a plastic pin.
Water Float - a small round part resembling a "life saver" candy located underneath the plastic cap.
Pin – plastic pin that secures water float and plastic cap.
To clean the water float unscrew the plastic cap from the pin. Remove the water float and clean by wiping the parts with a soft damp cloth. Replace the parts by first putting the water float onto the pin and re-screwing the plastic cap onto pin.
Good Luck.
Apr 01, 2008 | Crane Penguin 1 Gallon Humidifier
Cleaning instructions
I was looking for instructions as well, because I thought I had lost the manual. But then my wife found it. According to pages 8-9 (I scanned the pages as well and posted it here):
CAUTION:
PLEASE NOTE that if the water remains in the water tank for more than a day or two, bacterial growth is possible.
NOTE: When removing water tank, water may accumulate under vapor lid and on the bottom of the water tank. It is recommended to have a dry cloth ready to dry wet surfaces.
3. Once unplugged the exterior of the unit may be cleaned by wiping with a soft dry cloth. Caution: The ON/OFF switch must be throughly dry before unit is again plugged into power source.
Nov 12, 2007 | Crane Cat EE-3187 1 Gallon Humidifier
Vicks Warm Mist V745A 1 Gallon Humidifier Logo
17,913 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
