1. My fridge is making a loud clicking noise at the same time the fan runs.
2. Can't get water or ice (even though there's ice in the ice maker).
We recently changed the filter so we assume it's not a filter issue.
If there is ice in the icemaker and its not ejecting the ice you more than likely have a bad heater in your icemaker not heating the cubes for the rake to scoop them out. No water through the door would probably be a separate issue. If its a GE they are known for poor insulation on the freezer door and the water line will freeze going up the inside of the door. If you remove the kickplate there will be a quick connect coupler. remove it from the line going up the door and call for water. If you get water to this point you know the line is frozen through the door. If not then you will want to check your saddle valve for calcium deposits gunking it up. Least common issue would be a bad water valve.
