Question about Symphonic WF-719 19 in. TV/VCR/DVD Combo
Tray won't open
The tray won't open. Also everything turns off after about 20 second when it is on the DVD mode.
  • 979 Answers
Shop time for this one..The DVD has a fault of some sort. Hard to tell without opening it to troubleshoot...accordianman
Posted on Feb 29, 2008
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
Tip
INITIALIZE THE DVD PLAYER -FIRMWARE UPDATE
FIRMWARE UPDATE
1. Turn the power on and remove the disc on the tray.
2. To put the DVD player into version up mode, press [9], [8], [7], [6], and [SEARCH MODE] buttons on the remote control unit in that order. The tray will open automatically.
The DVD player can also enter the version up mode with the tray open.
3. Load the disc for version up.
4. The DVD player enters the F/W version up mode automatically. If you enter the F/W for different models, "Disc Error" will appear on the screen, then the tray will open automatically.
5. After programming is finished, the tray opens automatically.
At this time, no button is available.
6. Remove the disc on the tray.
How to Eject Manually
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
on Jan 19, 2016 | Denon DVD-1740 DVD Player
Memorex 3202-3223 dvd burner disc tray won't open
Try reseating the DVD drive so it makes proper connection.
Mar 05, 2012 | Computers & Internet
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
DVD tray delays about 20 seconds when opening
May be your CD's are burnt and have alot of free space that requires long reading before it can play.
May 28, 2008 | Samsung HT-X40 System
"safe" keeps me from opening dvd tray manually (must use remote control)
I unplugged the recorder for 10 seconds, replugged it in and voila, the problem was solved.
Walt in Indiana
Apr 11, 2008 | GoVideo VR3845 DVD Recorder/VCR
Will not open the DVD tray.
if your dvd tray is not open you need a one inch pin or needle into hole..the hole right side .....then your dvd tray open
Feb 01, 2008 | Samsung DVD-HR720 (80 GB)
LG DVD+RW door won´t close
Deliverance
this problem can happen if tray-in sensor not sense. their r a small liver which press tray in sensor automaticly when tray stay inside. liver and sensor location is near emergency exit hole (when u use a pin for emargency exit actually u press this liver then it release try-in sensor). check this liver and its path any pice of cd is their or not. (to check open ur drive cover. to open it at first use emeargency exit hole to open tray then open cover)
Dec 19, 2006 | LG (GSA-4120BK) DVD±RW Burner
Symphonic WF-719 19 in. TV/VCR/DVD Combo Logo
107 people viewed this question
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
