Question about HP Photosmart C6180 All-In-One InkJet Printer
"printer disconnected" most of the times i have the above message displayed on my hp director. using visa on a laptop,printer shows up in network ok,can check ink levels etc. the "radio mast" is not displayed on my printer screen. the only way i can get it to print is to switch the printer on,request a document print,turn printer off and on again.once its on the radio mast is displayed on the printer screen and after a few seconds hey presto it prints!! i also have a laptop running xp and don't have as much problems as i do when using the visa machine.why? i've contacted hp to ask if there was a driver problem but was told ther was "no issues" this is driving me nuts!!!!
    President:
  • 4,402 Answers
On a wireless network, if more than one device has its SSID set to hpsetup, the all-in-one may freeze or stop responding. Solution Choose a unique SSID for the HP PhotoSmart All-in-One product by following the network setup information in the Basics Guide or Network Setup Guide for your product. Cause The all-in-one may hang or freeze if multiple devices in the area have their SSID set to hpsetup.
Posted on Feb 08, 2008
I have a hp psc 1310 series printer and i can not find the site to check the ink levels. The book says to use the hp director on page 28.
Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer. Checking the ink levels on a Windows computer
  1. From the HP Director , click Settings , Print Settings , and then click Printer Toolbox .
  2. Click the Estimated Ink Levels tab. The estimated ink levels appear for the print cartridges.
Checking the ink levels on a Macintosh computer
  1. From the HP Director , click Settings , then click Maintain Printer .
  2. If the Select Printer dialog box opens, select the HP PSC, and then click Utilities .
  3. From the list, select Ink Level . The estimated ink levels appear for the print cartridges.
Oct 05, 2010 | Office Equipment & Supplies
49.4c02 service error in hp laserjet 2300n
HP 2300 ERROR 49.XX
• A critical firmware error has occurred on the printer
• Turn printer off then on
• Disconnect the parallel cable or the network cable
• If message still there when the network cable is disconnected
upgrade firmware in jet direct card and the formatter board
• Bad network cable
• Replace firmware DIMM
• Replace the jet direct card
• Replace formatter board
• Replace engine board
95% of the time it is a PDF that has a font that is not recognized by the printer! If the error is not there when you follow the above, you may have to clear out the print queue.
Apr 23, 2010 | HP LaserJet 2300 Printer
CAN,T GET HP DIRECTOR TO OPEN ON VISA COMPUTER
HP Director isn't compatible with Windows Vista. HP Solution Center replaces HP Director in Vista.Check out the explanation here - and some information about how to install Solution Center.http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01471226&cc=us&lc=en&dlc=en&product=303753
Jun 06, 2009 | HP PSC 2410 All-In-One InkJet Printer
My printer is not printing
After multiple trys I finaly got it to work by doing the following:
Turned off printer, disconnected network cable and power cable. and reconnecting Network cable, power cord and turning on. This was done about 5 times or more before it worked.
Mar 19, 2009 | Fujitsu Office Equipment & Supplies
Hp 6110 all in one hp director not working.
try to do the following:
1. Double-click the HP Director icon to load the program into the memory. You will not see HP Director open at this step. Do not click anything else on the screen until Step 2 is completed.
2. Press the Alt key and the Space bar together, and then
select Minimize from the menu that displays in the upper left corner of the window. If necessary, click it again until HP Director minimizes.
The HP Director software now appears as an item on the Task Bar .
3. Click HP Director on the Task Bar . The software opens and displays normally.
4. Repeat Steps 1 through 3 every time the HP Director software is used.
or
  1. Go to the HP Software Download Page .
  2. In the Enter a product number text box, type the printer model, and then press Enter .
  3. Under Product search results , select the printer model.
  4. Select the operating system.
  5. Under Update , click Critical update to resolve an issue with HP Director after installing Internet Explorer 7 .
  6. Follow the instructions that display on the screen to install the update.
Cause:
In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software, does not exhibit this issue with Internet Explorer 7.
Sep 02, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Director won't open. I am on XP and IE7
HP Director has a flaw and is not compatible with IE7
I have a psc 1100 and I had to update my software from HP
CHECK THIS OUT
Go to HP, this link, type in your printer model #.
It still may fail to show...if it does not show HP recommends this
work around.
Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
  1. From desktop, double-click the HP Director icon to load the program into the memory. HP Director will not open at this step. Do not click anything else on the screen until Step 2 is completed.
  2. Press the Alt key and the Space bar together, and then select Minimize from the menu that appears at the upper left corner of the window. If necessary, click it again until HP Director minimizes. HP Director software displays as an item on the task bar (the row of open software programs that appears at the bottom of the desktop screen).
  3. Click HP Director on the task bar. The software opens and displays normally.
  4. Repeat Steps 1 through 3 every time you use HP Director.
    NOTE: The HP Director window might appear larger than normal, but the software is functional.
Cause In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software on products introduced after 2004, is compatible with Internet Explorer 7 and does not exhibit this issue.
Apr 30, 2008 | Computers & Internet
HP PSC 1315
If the patch or the updates did not work on the link I sent you try this Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
Mar 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
Window vista
go to http://h10025.www1.hp.com/ewfrf/wc/pfinder?tool=product&query=PSC+2210+&dest_page=product&lc=en&cc=au&dlc=en
Choose which model of the 2210 all in one series you have, click on Software and Driver Downloads and then click on the button that says Check.
This will check to see that you have the most recent version of the driver.
Oct 17, 2007 | HP PSC 2210 All-In-One InkJet Printer
Hp director
It could be about this: I had same problem until I found a review somewhere - even HP technical support was totally useless - until HP FINALLY decided to up date its drivers to account for my/many people's downloading of Internet Explorer 7. As this is now done, and you cannot easily uninstall IE7 and go back to IE6: try again (1) HP Director and if not (2) I think update drivers or (3) uninstall / reinstall. Hope it helps.
Apr 04, 2007 | HP PSC 2410 All-In-One InkJet Printer
I can't get access on my PC to the HP Director.
Hi Seaner, I would suggest removing HP Director from the computer using Add/Remove programs in the control panel and then reinstalling. If that doesn't work let us know what operating system you are using, any error messages, problems, or changes that lead up to this situation. Also don't forget to rate this posting when done.
Feb 09, 2007 | HP PSC 1315 All-in-One Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
