Heating & Cooling Logo
Posted on Jan 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Boiler making clicking noise
I have a baxi dou-tec combi 40he boiler and it started making a clicking noise and the temperature on the guage went up to 87, i reset the boiler and the temperature came down but when i turned the hot tap on the temperature went up to about 67 and kept going up so i turned the tap off and reset the boiler again and now the temperature has gone down to 51, but when i turn the tap on it goes over 67 again, what should i do???
Paul Carew
Level 3:
  • Heating & Co... Master 3,807 Answers
  • Posted on Jan 10, 2010
Paul Carew
Level 3:
Answers
3807
Questions
Helped
1298665
Points
10523
Contact baxi and ask ther service people there was aproblem with this but i cannot recall it now ,hopethis helps
1helpful
I want to use my baxi bermuda gas fire just as a fire as having a combi boiler installed is it possible
yes a combi boiler has to be piped so they would cut off the pipes to your baxi and you can ues it as a gas fire only
2answers
Baxi duo-tec boiler - when water comes on flame roars up. When i put the heating on the flames roar for 5 minutes then die down.
is the boiler a combi if so have you checked the pressure. it needs to be at 1.5 bar 2 bar at the most . also check that the heat the boiler is producing is completeing the circuit on the heating if you have access to the pipe work there should be 2 or 3 22mm copper pipes. now turn the heating on and check which one is getting warm. the one that is is your flow and in about 2 to 3 min there should be one more pipe getting hot let me no if this is the case
Baxi duo tec e160 code
Fault Code E160 on a Duotec Boiler is a fan fault.
Mine has just gone for the 2nd time! Gas engineer is on his way......
Where do I turn the heating up on my Baxi combi boiler please? Can`t locate anything that looks like a temperature guage.
go to www.baxi.co,uk and you can down load maunals which should help you as they have most thing in them on how it all works , and it is yours to keep
2helpful
2answers
Central Heating\which combi boiler?
HI right first i would look at a worcester greenstar combl
best you can get and you have full back up from worcester leave all rads with stats as they are i think you will have to remove one , the that would be the bath room also the greenstar comes with a clock bulit in these are on the worcester bosch web site i have been a gas fitter fot 30 years and this what i would go with a really good combi, you can also get awire less room thermostat for this hope this helps
Hi there i have old baxi boiler i was wondering
pilot has to be on all the time on this baxi ,piolt might be a bit large might need adjusting down
Baxi 80 e some rads hot others cold
is the pump running or is there an air lock near to the boiler check water tank in loft the smaller one to make sure you have water in the system
Re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Top Heating & Cooling Experts
Paul Carew
john h
