Question about Boston Acoustics XB6 Speaker
Voltage selection on Boston XB6 Sub
I live in Australia and bought a Boston XB6 sub from USA, expecting it to have a voltage selector on the back panel to switch to our local voltage of 230 volts, which it does not. I looked at the inside of the amplifier module and saw on the power supply board two jumper connectors with positions marked for 120v and 230v. If I change these to the 230v position is that all that is required to operate it on 230 volts?
Thank you
  • samj1 Feb 06, 2008
    Thanks for the reply. Are you really sure, as I don't won't to destroy it by overvoltage. I believe it is a switchmode supply as there is no large transformer, just a small thing that looks more like a choke further down the board. Would the internal fuse blow if the voltage is too high?
    Master:
    Sergeant:
  • 440 Answers
Yes u got it
Posted on Feb 06, 2008
  • nick helpap
    nick helpap Feb 06, 2008
    should work fine sum have them on back sum are inside on a jumper
  • nick helpap
    yes i im sure it would rather then before it would getto unit yes
Boston micro 95pv sub-woofer is blowing 3A Slow Blow fuses.
I would expect a shorted component in the power supply
Sep 06, 2016 | Boston Acoustics Micro90X Speaker
I just bought a cs6000i sewing machine from USA. I live in India. Why is there smoke coming out of my new sewing machine? Is there a problem with the voltage?
Yes, India voltage is 240, USA is 110. You have probably fried it, should have purchased a machine from another 240V country like Australia of used a voltage converter to break it down.
Feb 28, 2015 | Sewing Machines
Pv700 sub woofer has loud hum
If the speakers are turned off and the sound is still there , check the Amps , as it could be voltage transformer noise from the amp . This is caused by non sealing of the transformer .So I am told
Dec 17, 2013 | Boston Acoustics Audio Players & Recorders
Hook up to a receiver
what kind of connector is opn the sub? probably a mini-audio plug like a set of headphones? If that is the case, you can get an adapter from mini-plug to rca cable.
Oct 07, 2013 | Boston Acoustics Audio Players & Recorders
Bought from usa to australia changed to recomended fuse, fuse blows as soon as turned on the unit was brand new any ideas ?
hi,
You have to check the working voltage of the adapter of you device. If it purchased from US then it will be 110V. I think the Line voltage in Australia is 220V.Also You have to check is there is any input voltage selector in the in its adaptor . If it there you have to change it to 220V. If there is no such selector then you have to buy a 220v to 110v converter .Then connect the out put of that converter to to your device. You can by this converter at any electronic spare part shope near to you. Or you have to by a new 9V 1.3Amps AC adaptor. When you going to by the converter or a new adaptor take the device. If so they will explain you how to connect the converter or adaptor . By changing a fuse you can't change the operating voltage. If The adapter is designed to use in 110V then the fuse will blow. If you change the fuse and make more experiment with it it will make the full system useless.
ok
Aug 05, 2011 | Lexicon MX200 Multi-Effects Processor
My last reference was incorrect. I have a Sony CDF in Greece. Will it play in the USA?
The voltage in Greece is 220volts and in USA is 120v. Now depending on where you bought it from there might be a voltage selector at the back ( near or inside the battery compartment you will find a slide switch - you will have to use a flat blade screwdriver to change voltage). Mostly only Asian models have 120/220v selector because Japan is 120v and the rest of Asia is 220.
Another way to find out if its multi voltage, check the sticker or engraving at the back it will be mentioned on it.
Apr 02, 2011 | Sony CFDS03CP CassetteCD Boombox
Francis Francis X3 voltage
hello. The electrical power used in most of Japan is very similar to that of the USA. The difference is that Japan uses 100 volts as opposed to our 110. Therefore, most electrical appliances, blow dryers, etc will work equally well in Japan and in the USA.
Since you are in Australia now, use the same adapter for your expresso machine as you use for other small appliances and you should be fine.
Sep 13, 2009 | FrancisFrancis! X3 Espresso Machine
Emits a loud hum or rumble sound.
This problem is usually because of grounding.
If you look at the power lead, you will notice it is the regular "kettle plug" shape, but it only has two pins (live and neutral). There is no earth connector.
You have to ground the sub to your receiver. This is done by running a RCA connector connected to one of the unused connections to the amp.
However, this doesnt ALWAYS solve your problem. As in my case. I have a Pioneer 7.1 receiver, which is ALSO not grounded. so running a spare RCA cable has no effect. What I have done is wired a RCA connecter to a copper cable and connected the other end to the Earth pin on a 3 prong plug. This is plugged in to a wall socket, thus grounding the sub.
It's not a solution the manufacturer will suggest, but it seems to work for me.
Nov 12, 2008 | Boston Acoustics XB6 Speaker
Subwoofer noise
You didn't say is your sub active or passive.If its active first check signal cables from theater system,power line of the sub, it has to be the same phase as the system.If its passive take a voltmeter disconnect the sub from the system and measure for DC voltage on the SUB output on the system when its OFF.If DC voltage is present your amp is damaged.It can also be that the preamp circuit for the sub doesn't mute the input when unit is on stand by and you hear frequency of your power supply (50-60Hz) on the sub
Mar 09, 2008 | Audio Players & Recorders
BA745
yes bad bord so cheap on these u can kick bass out like u wanna best bet referb kilspsh on ebay 70 bucks bass on them rocks ok
Jan 16, 2008 | Boston Acoustics BA745 Computer Speakers
Boston Acoustics XB6 Speaker Logo
227 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
