Question about Hoover Commercial C1660-900 Bagless Upright Cyclonic Vacuum
Hep! My 3 month old Hoover Mach 5 doesn't pick up!
When vacuuming, the roller brush won't stay spinning. It just stops. My carpet looks like it has never been cleaned. The cyclone is working cause I can see dirt spinning around, but it hardly picks up anything. The belt is still in place, though maybe it is not tight enough, I don't know. It went from working great, to hardly at all.
  • 2 more comments
  • Anonymous Mar 02, 2008
    Same exact thing!!! 3 months old and the spinning brush stopped working!!! I am sooo disa ppointed in Hoover!! DO NOT buy the HOoover Mach 5 bagless!!!
  • dooleymoe Jul 28, 2008
    same problem, housekeeper ran over something, it runs but when changing directions the brush stops or squeaks.
  • ruger2124 Jan 10, 2009
    I have the same problem. My hoover mach 5 is only a couple months old. When I first got it I loved it, I bumped into something while vacuuming and it started to chatter so loud you cant hear a thing. When I opened the bottom to investigate the belt looked too loose so I got a new belt, which was no easy task since they don't have them in any local stores I had to order it on-line. When I put the new belt on it too looks way to loose. This vacuum is so loud and doesn't pick up very well anymore. I'm very disappointed.
  • Anonymous May 23, 2009
    We have the same problem. It worked great for the first few months. Then the brush stopped working and its no good without the brush.
What is happening is the secondary filters, HEPA and the canister all need to be cleaned. This is vital. What the vacuum repair people are keeping from you is that tidbit of wisdom. This particular vacuum is picky about airflow. Pull the canister, and on the body of the vacuum on top of where the canister sits are the secondary filters. There should be a sticker explaining how to remove them. Clean them throuougly, mine was filthy. Make sure you clean the canister by unlocking it and cleaning out the micro holes and the cone end. Mine was completely plugged. Now brush the dirty side of the HEPA filter with the combo tool. Let the secondary filters dry completely (you can blow dry them on cold) Re-install everything, and the vacuum will run like brand new. I vacuumed the whole house after I completed this maintainence and it works like a champ. Don't return this vac until you clean it completely.
Posted on Sep 24, 2008
Hi, I just got this vacuum at a 2nd hand store for $20, because it was "broken". Im quite handy, so I took it home and tore it completely apart. There are alot of hidden screws, so take your time. I sprayed everything out with my air compressor, cleaned all the filters, and tore the canister apart and sprayed it out thoroughly.I put it all back together, and it works like new. I love non handy people, their loss, my gain. The belt problem may be the switch. There is a spring, and a click type mechanism, like in a ball point pen. if it became misaligned, or popped loose, that could cause that problem. Hope this helps
Posted on Aug 10, 2010
    President:
  • 1,673 Answers
The first thing to try would be a new belt. once they stretch to a point, they can't hold tight enough to turn the brush roll under load. Check the brush roll also, hold the ends and it should spin freely, if not, then it has bad.
Posted on Feb 07, 2008
Simple stuff first...did you check the switch for carpets versus smooth floors? For smooth floors, the brush doesn't spin. You also have to switch it with the handle down. Took me a while to figure this out.
Posted on Sep 16, 2008
Have a dyson dc41 brush head wont spin so tried another which i bought this wont spin either the hoover picks up well with the hose what could be the problem be please
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 30, 2017 | Dyson Vacuums
Hoover cyclean brush stopped revolving
The belt may be broken or worn If your cleaner is not picking up fluff and hair from the carpet or has become heavy to push it is possible that the belt has snapped. This belt makes the sweeping brushes spin round underneath the cleaner and brush dirt into the path of the air suction. The brushes also give that 'groomed' look to your carpet by gently brushing the carpet fibre. If you pick up something sharp or debris gets jammed in the brushes then the belt may snap. Also over time your belt will stretch, so it's a good idea to change your belt once per year to ensure the cleaner picks up dirt effectively.
Dec 14, 2016 | Hoover Vacuums
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
I'm getting no suction and the brushes are not rotating
Hello! If you are using the cleaner on carpet, it is necessary for the brushes to rotate to assist the motor with maximum pick up. If your brushes are not spinning check the belt to make sure it isn't broken or stretched. The belt will need replacing about once a year. Below are steps for checking the belt on your U5399-900.
1. Place handle in low position and turn cleaner over so bottom side is up.
2. Remove the 4 screws. Lift off bottom plate.
3. Inspect the belt for rips and tears. If it is damaged in any way, broken or stretched replace the belt
This unit takes belt 38528033. Be sure you replace belt with genuine Hoover parts. Here is a link where you may go to order a replacement belt.
Service Center Locator
Hope this helps!
Jun 05, 2014 | Hoover U5399-900 WindTunnel Lite Upright...
Brushes don't spin
Hello :
try this please : switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
or try this also if the above suggestion didn't work :
Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
please rate !
May 07, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
The belt on my hoover cordless is not spinning when I turn it on
You need to replace the belt. Even though the belt may look fine it can be stretched and therefore it won' t turn the roller brush against the resistance of the carpet. You can get Hoover replacement belts here:
Hoover Replacement Belts
Oct 29, 2009 | Hoover Vacuums
Brush won't spin on my Hoover Mach 5
I love this vacuum but had the same problem.
SOLUTION:
take the roller off and flip the thin belt inside out. This fixed my vac and works great again.
Oct 12, 2008 | Hoover U5194-900 Mach5 Multi-Chamber...
No spin
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=782631
No spin
Posted by erin_david on Jul 14, 2008
Vacuum's brush does not spin on (low) carpet unless switched to "high" but then roller does not pick up hair on carpet. Belts are in good condition. Maybe belts are loose?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Your problem is that you may need to change the belt every 4 to 6 months as a recommended belt change on the vacuum and also keep an eye on the brushes or brush strips; they also help in the vacuum working properly. Here is a typical belt change on a Hoover. Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover windtunnel
would suggest the drive belt is stretched and thus is slipping when contact is made with the carpet.
Jan 14, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Steam vac will not pick up dirty water
My Hoover Steamvac problem isn't with the bruches--it's with the suction. Dirty soapy water stays in the carpet instead of being returned to one of the holding tanks.
Oct 21, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Commercial C1660-900 Bagless Upright Cyclonic Vacuum Logo
811 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
