Question about Canon ZR45MC Mini DV Digital Camcorder
Device Initialization Failed
When trying to transfer my recording to the computer, I get the above error. Is there a driver that I need to install? USB ports show working properly. I can transfer my still photos from another camera o.k.
  • gskinner Aug 09, 2008
    When importing still images from my ZR45MC to my computer, I get an error message "No camera detected". Is there something I'm doing wrong or is there a fix?
JDeRuvo
  • 48 Answers
SOURCE: Device Driver Software Not Installed
Invest in a $10 USB memory card reader and simply take your card out and plug it in. The PC will read it as a drive and it's a simple drag and drop to get your pictures onto the PC for editing and printing. Much better than trying to trouble shoot driver issues.
J. DeRuvo
Digital Camera HQ
Posted on Dec 04, 2007
dbarchitect
  • 150 Answers
SOURCE: driver update problem for digital camera
In order to get rid of the error, you have uninstall the driver, update your operating system with updates from Microsoft (see below for instructions) and follow these suggestions:
  1. Best method, copy the photos to the computer by connecting a card reader to the computer and plug the SD card into the card reader and transfer using your favorite software (like Picasa) or through My Computer.
  2. Drivers are not required for the A400 and Windows XP. So you can plug in the camera, without drivers and it should work. This appears to be the one that's not working, You need to un-install the drivers and either reinstall, try updated drivers from the links below, or don't use the drivers.
This information is in the manual on page 96. See this link for the manual.
See this link for details about the WIA driver.
About the error "driver update failed" rea
I personally have stopped altogether trying to get the drivers and software installed because they can cause more problems. I just transfer using a card reader.
If you want to use the software that comes with the A400, it's best to install ZoomBrowser, then you will need to follow to this link to get the update to this software.
Once this is done, reboot your machine to make sure the system is then up-to-date.
Make sure you have also updated your machine with Windows Updates. This is done by opening Internet Explorer and clicking on Tools | Windows Updates. Follow the links at their site to update your machine.
Posted on Dec 06, 2007
  • 24 Answers
SOURCE: Vista and firewire 1394?
Firewire works fine under Vista, but it's quite possible your USB to Firewire bridge doesn't have proper Vista drivers. You wouldn't expect Vista to include these, they would be installed from a disc that came with your adaptor. USB to Firewire is a questionable option at best... there are often problems with it. You may be better off with a PC-Card or ExpressCard solution, if the laptop is your only computer.
Also, when the camera says "DV IN", it's expecting video from the PC to be sent to it, it's not in capture mode. Most camcorders must be in either "play" mode, or a special "link to PC" mode in order to even be recognized by Windows (any version) as a video input device.
However, until you resolve the issue of supporting your Firewire device in Vista, nothing the camcorder does will be an issue yet. You should check the documentation that came with your USB to Firewire device, the driver disc, etc. for information on Vista support.
Posted on Jan 21, 2008
Mark_Webber
  • 472 Answers
SOURCE: Moving photos from pc to Elura 65 camcorder memory card
You can buy both internal and external USB card readers that can read just about any card you can think of in a package about 3" square. They are not expensive either.
Your local PC retailer will (read should) have these in stock.
Hope that helps
Posted on Apr 12, 2008
pagebor
  • 2785 Answers
SOURCE: Uknown device Error - Canon PIXMA M180 All-In-One
just unistall the usb printing support from the device driver then you you restart then you put the printer cd in the rom and try, post your comment
Posted on May 17, 2008
Getting lidl silvercrest turntable / audacity to transfer records to computer
Assuming you've installed the Audacity software, first check your recording device. If you use Windows, first check the Audio Control Panel. For Windows 7, click Start > Control Panel > Hardware and Sound. Under Sound, click on the Manage Audio Devices link. In that window, click on the Recording tab. Select the USB option and make it the active device.
In Audacity, you may also need to make sure that this is the recording device that is active. That should be the third drop down from the left in the Device Toolbar. (If it isn't visible, click View > Toolbars and check it.) The Device Toolbar is right above the recording trace section in my version of Audacity.
Now click Record (the red circle) and start your turntable. Do you see a change in the trace? You should see a flat line for up to 10 seconds and then see this change to a set of high and low values.
If you don't get this, check if your USB ports are working. If you use a USB hub, try a direct connection. Check the device manager under Universal Serial Bus for a triangle with a red x or a yellow triangle. Try updating the driver by right clicking on the device. Also check Windows Update (for an optional update) or your computer manufacturer site for a new driver.
Unfortunately with the USB, you can't hear the recording as it is made. Do a short recording and then stop it. Then play back the selection. Adjust the input volume level lower if your trace is hitting the top of the box. This is clipping and your recording won't include the full signal from your record.
I've used Audacity for recording cassettes through the line in port. You can do this with some turntables if you add a pre-amplifier and use RCA to 3.5 mm adapter. Connect to the line in on the back of the desktop (blue).
If you could not install Audacity, go to http://audacity.sourceforge.net/ to get a version that works on your computer's OS.
I hope this helps.
Jul 05, 2012 | Audio Players & Recorders
Direct3d device initialization failed
your video card doesn't support direct3d, or check out if your video card driver is properly installed on your device manager...
Jul 28, 2011 | Intel Video Game Consoles & Games
Camera initialization failed.. Lenovo Y410
Hi mbmedel,
I see that you are having issue with your camera with an Error Initialization Failed.
you can try reinstalling the drivers of your camera from the Lenovo website, or you can locate your Camera driver in the D: drive if you still have that partition then look for the Drviers folder then look for Camera you should see the installer in that folder it maybe name setup or dvinstl.
Also you can try Holding Down the Fn + Esc this turns the camera On and Off see if the camera will repsond to this function if not then try the reinstallation of the driver.
If during the Re0installation of the camera driver then an Error show could not detect camera or device then the camera on your machine needs to be replaced.
I hope this helps.
Have a nice day,
mvincentc
Jun 10, 2011 | Lenovo 3000 Y410 Laptop
This is message error appear during I install canofile : RNBOVDD.DLL An installation virtual device drive failed initialization choose.'close' to terminate the application
The RNBOVDD.DLL is a Device Driver used for DOS and Windows 16-bit...so needs to be removed hence follow the steps listed below.
Run the Registry Editor by typing in regedit in the run search bar and Select the HKEY_LOCAL_MACHINE window.
Double click on SYSTEM. Double click on CURRENT CONTROL SET. Double click on
CONTROL. Select VIRTUAL DEVICE DRIVERS.
Double click on VDD:.......RNBOVDD.DLL line on the right side of the window.
Delete RNBOVDD.DLL. Confirm by pressing OK.
Shutdown and restart Windows.
ALL THE BEST...................
Feb 21, 2010 | Canon Canofile 2.01 Full Version for PC
Problem with Drive WJ430 - LOREX - QLR0440
Download an XP type for starters...
Jul 23, 2009 | Computers & Internet
I get I get SQLDUMPER LIbrary failed initialization
SQLDumper is used to collect stack information and debug information in case SQL Server crashes. The dump that is created out of this is normally send to Microsoft and is used by the development team to debug problems (not that you can elect not to send this information to Microsoft).
The error above means that likely your SQL Server installation is corrupt, so I would suggest that you reinstall SQLServer.
Apr 14, 2009 | Microsoft Windows XP Professional for PC
I cant transfer files from recorder to my pc
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Mar 12, 2009 | Olympus VN-4100PC Digital Voice Recorder
Pctv hardware initialization failed
first unistall the software. and then remove the hardware device and re insert the slot again. after that install the software. If any other doubt please come to gmail chat at salnazi@gmail.com
Jul 03, 2008 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
Canon ZR45MC Mini DV Digital Camcorder Logo
76 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
