Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
Posted on Jan 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Dyson vacuum. The vacuum won't stay
I have a Dyson vacuum. The vacuum won't stay running. When I release the power button it immediately turns off.
  • Anonymous Jun 19, 2013
    Thank you kuranuk! I had the same problem and your solution worked for me too!
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Jul 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
23387
Points
93
My vacuum had this exact same problem, but was out of warranty because it was remanufactured. Thankfully, it's a very quick, five-minute fix.
  1. UNPLUG The Vacuum!
  2. Remove the cannister.
  3. Extend the handle and remove it.
  4. Remove the two torx (T-15) screws behind the power button, where the handle normally stows.
  5. There are four tabs holding the front plate containing the power button on; use your screwdriver to release them.
  6. Gently pull the front plate off.
  7. The switch on the right is the power button. Remove it, try clicking it a few times; if it sticks, great! Replace it and reassemble, otherwise you'll need to replace it.
  • Sara Bolton
    Sara Bolton Jun 21, 2014
    Thank you! This was so helpful. Fixed my problem. :)
Lynn Brandt
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 19, 2012
Lynn Brandt
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5868
Points
I just wanted to thank kuranuk for the above post - it fixed our problem! THANK YOU VERY MUCH!
Anonymous
Level 2:
Novelist:
  • Expert 167 Answers
  • Posted on Apr 22, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
167
Questions
0
Helped
155779
Points
338
Hi its Darran at Dyson.
Sounds as though the switch is faulty. So that we can help you, please contact our Helpline on 1866MYDYSON.
Please ensure you have your serial number to hand when calling as the advisor will need this to identify your machine.
Kind regards
Darran
Dyson Customer Service
3helpful
Dyson dc35 button won't stay on
Where can I order the switch from?
Vacuum will not stay on
Hi Patriccia,
I'm sorry to hear you're having difficulties with your Dyson's on/off switch. If the switch won't stay down when pressed, please call us free on 1866MYDYSON, or email [email protected] so we can provide further assistance. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
The power button on my Dyson DC19T2 won't stay on
The switch is broken. If you are handy, remove the old switch and match it up at a hardware store or a Vacuum repair shop. It shouldn't cost much to have it replaced by a proffessional either.
My on off button won't stay pressed down so the vacuum won't stay running.
Hi Melissa,
I'm sorry to hear you're having difficulties with your DC17. If the on/off switch doesn't seem to be working correctly, it's best if you get in touch with us directly so we can help. You can call us free on 1866MYDYSON, or email [email protected]. We'll look forward to hearing from you.
Kind regards,
Jack
When i push the power button and let go it turns off and won't stay on. what might be the problem.
Sorry to hear you're having difficulties with your DC27. In case you haven't already tried this, make sure you press down firmly on the power switch when turning the cleaner on. If the switch still won't stay down, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
3helpful
2answers
My dyson power button won't stay on unless you hold the button down. Is there anything that I can trouble shoot to fix the problem or is the button broke? If broke where can I go for repair?
Sorry to hear you're having difficulties with your DC24. If the on/off switch won't stay down, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
22helpful
2answers
My dyson will not stay on when i press the button.
OK...so while I'm sure that hitting the power button w/ a mallet will work...I was having the same issue and felt uncomfortable hitting my very expensive Dyson w/ a mallet.
Here is what I did to fix the problem I have a DC17...I am sure instructions will vary by model Here is what you will need: 1. flat head screw driver 2. Torx -15 screw driver.
1. remove the dust tank  2.Pull the extension tube (handle) out (as if you were going to  vacuum a tight area.  3. there are 2 torx screws that you will have to remove 4. there are 4 retaining clips that you will use the flat head screw driver to unlatch.   5. After you remove the torx screws and release the 4 retaining clips, the front panel (that houses the power button) can be removed.  6. This will expose the actual power button itself.  Most likely it was jammed. 7. Once you think you have fixed it...test out your fix. 8.  If fixed...reassemble
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
