Question about Whirlpool LGR5634L Gas Dryer
Dryer lights, heats up some but wont relite
Dryer will light and heat but cycle off on the dryer cycling t/s. Then it will close and ignitor will glow but will not relite. i feel its the cycling t/s but not sure. any advice?
DRYER WORKS BUT DOESNT HEAT UP AND DRY CLOTHES IS IT THE IGNITOR OR COILS
Posted on Aug 04, 2008
    Problem Solver:
Replace the coil packs on the gas valve this fixes 90% of gas dryers lighting intermittently. The bracket comes off and they are sold seperately from any appliance parts retailer.
This worked for my dryer.
Posted on Feb 07, 2008
Kenmore 500 series gas dryer has no heat and no glow. Thermostat fuse has continuity. Replaced ignitor and coils. bypassed flame sensor and still have the same problem.
Having checked or replaced what you have thus far here a few things still to check
Cycling thermostat in blower housing,in addition to thermal fuse it must have continuty to be good
Timer check wiring diagram in control panel and check for continuty that are supposed to be closed when set to a normal heat cycle
Motor switch heat circuit check again with wiring diagram and see which wires on motor switch must be closed when running so dryer will heat.This a built curcuit asurring the dryer will never heat when motor is off
If your model has it check heat relay in control panel for continuty on heating circuit for relay(not the circuit that closes relay)
as far as power to the ignitor the hot side comes from timer to and through the thermal fuse and cycling t-stat, to ignitor.the neutral comes from neutral wire on cord to and through motor when motor is running and motor switch is closed
so on ignotor plug check hot wire to ground(not neutral) if has 120 vac to it timer/t. fuse/ cycling t-stat and flame switch are all good and its the motor switch is the problem.The motor switch can not replaced seperatly and must replace entire motor
Gene
Aug 09, 2011 | Kenmore Dryers
First cycle dryer will fire as normal. each time after it will not light. glow plug is working but no gas allowed to turn on. i'm feeling it may need coils for gas valve?
I would change the ignitor first...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 16, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Ignitor glows gas valve opens, burns for a while then gas valve closes and ignitor cycles , if dryer is off a while it will light again. amana
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 24, 2010 | Amana Dryers
Dryer cycles through twice then wont relite
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 | Dryers
Have a frigidaire "gallery" series stackable washer/dryer, the heating element initially turns on when the dryer starts. you can see the element light up and feel heat but after a minute of run time the...
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Frigidaire Dryers
Was getting one heat cycle then ignitor woud glow but no call for gas. put in new cycling thermostat, thermostat boosting heater and heat sensor. I got two heat cycles before it went cold..?
heatman101
Aug 08, 2010 | Amana DLG330RAW Gas Dryer
Dryer wont stay hot
Assuming you have removed the lower access panel (two or three scres all the way at the bottom of the lower front panel) to view the glow plug (ignitor), if you see the ignitor cycle on but the gas does not ignite after the machine initially heated in the beginning of the cycle you will want to replace your gas valve coils. They are the round black things mounted to the top of your gas valve.
This should solve your problem.
Good luck to you!!
Jul 13, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Maytag dryer runs but doesn't heat up
1. Open the small access door in front of the dryer and start the heat cycle. The ignitor must glow a bright orange so that it is hot enough to light the gas. If there is no orange glow, then the ignior needs replacement.
2. If it glows then cuts off, then glows, again and cuts off, the thermocouple sensor wire is out of position. It needs to be very, very close to the ignitor. This thermocouple sends a temperature signal when it senses that the ignitor is hot enough to ignite the gas. Unplug the dryer. Re-position the thermocouple wire mount so that the thermocouple wire is almost touching the ignitor. You may also "bend" the wire. Plug power back on and heat.
3. If it still does not heat, then the automatic gas valve that is controlled by the thermocouple sending unit is broken. The automatic gas valve cannot be safely "fixed" and must be replaced.
Hope it's just the thermocouple wire.
Oct 05, 2009 | Maytag PYE2300AY Electric Dryer
GE Gas Dryer (Model DQSR 483) Drum works but does not heat
There are three things besides what you aleady checked:
Oct 01, 2009 | GE DBXR463EBWW Electric Dryer
Whirlpool LGB6000KQ1 gas dryer not heating up consistantly and sometimes smells like gas is leaking.
if ignitor is glowing but burner fails to light ck/replace the 2 black coils on valve they will sometimes fail after 1st couple of heat cycles
Nov 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool LGR5634L Gas Dryer Logo
139 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
