Question about Cell Phones
Kyocera 312 cellphone and bluetooth
I purchased a blue tooth headset that I was told works on the Kyocera 312 cellphone but when I go to settings there is no Connection for bluetooth. Can this be done
  • Anonymous Jul 02, 2008
    i dont no how conect the bluetooth
  • MISSDEEDEE Dec 02, 2008
    I NEED HELP CONNECTING MY BLUETOOTH TO MY KYOCERA 312
N/A
Posted on Oct 19, 2008
Ear loop broken-purchased loops and they snap and break
nujanitoral.jpgDon't spend lots of money buying blue tooth headsets Go to your local Walmart and purchase the Emerson Blue Tooth headset it comes with 2 ear loops that are made of a flexible plastic and 6 inner ear buds for a very snugged fit. The ear loops will also fit your LG blue tooth headset. You can also purchase the headset by following this link http://www.walmart.com/ip/Wireless-Gear-Bluetooth-2.0-Headset/15852098
Jun 11, 2011 | LG Cell Phones
Setting up my blue tooth
You need to pair it with the phone, working on phone settings, what is phone model?
Aug 29, 2008 | Motorola Mobility Bluetooth Headset H3 for...
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I cannot connect bluetooth headset,please tellme how to connect
Hi and thank you for using fixya:
1- go to communication settings on your phone and turn blue tooth on and on discoverable mode
2- press down blue tooth button down until light flashes repeatedly
3- cellphone should show that it found a blue tooth device and it will ask you if you want to connect
4- say yes and it will ask you for a code or password
5- here are some standard passwords
1234 0000 00000
thank you and good luck
Mar 20, 2010 | Logitech Bluetooth Wireless Talking Kit...
Plantronics 222 bluetooth
The kind support people at circut city told me to set my passcode to 0000. This worked...
Sep 21, 2008 | Plantronics - Bluetooth Headset Plus Base...
Blue-Tooth set-up
usually you press and hold the button on the bluetooth headset device for 10 secs, the led will change color, then you pick up your phone get into the bluetooth part of the settings and tell the phone to look for it. Then after that when it finds it, the pin will probably be 00000.
Look it up on google the model of your headset you should be able to find the pin.
Aug 12, 2008 | Motorola Mobility RAZR V3c Cellular Phone
I cannot connect two cellphones with blue tooth
As I told someone else, Verizon has put a block on bluetooth capabilities. I have found the only thing the bluetooth is good for is a headset.
Mar 11, 2008 | Samsung SCH-u740 Cellular Phone
My phone
Pairing your Cell Phone to your
Bluetooth Headset:
(FROM Bluetooth Headset)
1. Make sure Bluetooth Headset is fully charged!
2. Hold down talk button (center button of headset) up to
(Five) 5 seconds, then WAIT until you see a solid blue
light then immediately flip open earpiece part of headset.
THIS MEANS the HEADSET IS NOW IN PROGRAM MODE.
AT THE SAME TIME/ WHILE BLUETOOTH
IS STILL OPEN & IN PROGRAM MODE….
(FROM CELL PHONE)
1. Click on “Menu” (Left Button)
2. Scroll to Bluetooth icon. (Lower Right Hand side of menu)
3. Click “Ok” button
4. Then click on “My Devices
5. Click “OK” again
6. Select “FIND NEW”: Cell phone searches/connects to pair up
with Bluetooth Headset.
7. Once your Cell phone discovers your new headset, select
ADD” or click on the recently paired headset device.
8. You will then be prompted to enter a pairing code.
Use either..
a. 0000 or
b. 1111 or
c. 9999
Congratulations on paring/ connecting your new
Bluetooth Headset
w/ to your new Cell phone!
Jan 16, 2008 | Kyocera Switchback KX21 Cellular Phone
Phone wont detect bluetooth H700
Mine could be discovered when powered off/ on my cellphone and retried... Sounds like solution to M$ programs, eh? :)
Apr 18, 2007 | Motorola Mobility H700 Wireless Headset
Cell Phones Logo
178 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
