Question about LG HBM 730 Bluetooth Headset Wireless Headset
Bluetooth HBM-730 I had my hbm 730 paired to the lg phone than I delected the pairing connect and now my hbm can not fing the lg phone. K.O.
  • Anonymous Apr 28, 2008
    Even when I put it in pairing mode, it can't find the headset. It used to work before.
  • Anonymous Mar 29, 2014
    HOW TURN ON
  • 242 Answers
Just set the bluetooth earpiece to pairing mode and start searching bluetooth devices from your phone.
If you don't have a manual, just post back.
Posted on Apr 07, 2008
HBM 730 Bluetooth Headset Wireless Headset: Headset was given to me a while ago and I have a n...
To put your headset in paring mode, first turn it off. Then, press and hold the PWR/END button until the indicator led is solid lit (some 5 seconds). Now, make your phone's bluetooth software to search for devices. Select 'LG HBM-730' from the list. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
Hope it works for you
Hope it works for you.
Cheers! Carlos
May 05, 2010 | LG HBM 730 Bluetooth Headset Wireless...
How to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Feb 12, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Sir I have a LG HBM 730 head set. I cannot pair to my mobile.
Most Pass Codes For These Devices are DEFAULT Codes Such as 1234-- 0000- Try Them.
Jul 24, 2009 | LG HBM 730 Bluetooth Headset Wireless...
My LG HBM-730 does not connect to cell phone
I powered down both my cell phone and bluetooth earpiece. Attempted to reconncect and it worked immediately.
Jan 24, 2009 | LG HBM 730 Bluetooth Headset Wireless...
Pairing 730 and lg vx 860
To put the LG HBM-730 into pairing mode you must press the MFB for 5-10 seconds from power off. Pairing mode is denoted by the LED glowing solid red. LG has chosen to stick with the default pairing code of '0000'. Using Bluetooth specification 1.2, as is the custom, the HBM-730 supports both headset and handsfree profiles.
I found this on the internet and hope it works for you
Sep 05, 2008 | LG HBM 730 Bluetooth Headset Wireless...
LG HBM-730 Won't Connect to Treo 650
Actually it's a Treo 680. Finally took the battery out of the phone. That seemed to clear everything so that I pair the bluetooth with no problem.
Feb 22, 2008 | LG HBM-730 Wireless Headset
LG HBM 730 and VX 9400 pairing problem
I found the solution. The original password setting is a combination of zeroes - at least 4. If you did not originally change your password setting for your bluetooth from the original setting - try that. It worked for me.
Also - Thank you for your reply.
Oct 25, 2007 | LG HBM 730 Bluetooth Headset Wireless...
How do you put the LG earpiece in pairing mode???
0000 worked great for my LG to Motorola Headset Pairing. Thanks
Mike
Oct 11, 2007 | LG HBM 730 Bluetooth Headset Wireless...
LG HBM-730 disconnect problem
Check your headset on a different phone if the same thing happens - you need a new headset.
Aug 13, 2007 | LG HBM 730 Bluetooth Headset Wireless...
I can set up my headset to my new phone
Step 1 - Enable Bluetooth functionality on the Motorola V3m. Note: The Bluetooth power must be set to ON position to pair the device. From the main screen, press Menu [Center NavKey]. Scroll to Settings & Tools. Scroll to Connections, press [Center NavKey]. Scroll to Bluetooth, press [Center NavKey]. Scroll to Setup, press [Center NavKey]. Scroll to Power XXX, press [Center NavKey]. Scroll to On or OFF, press [Center NavKey]. Step 2 - Put your fully charged Bluetooth headset into pairing mode. Start with your Bluetooth accessory powered off. Hold down the power/end key for 5 seconds. You'll hear a short beep and the LED light turns red. Your Bluetooth accessory is now in pairing mode and ready to be paired with your handset. Step 3 - Pair the Motorola V3m with a Bluetooth Accessory. From the main screen, press Menu [Center NavKey]. Scroll to Settings & Tools. Scroll to Connections, press [Center NavKey]. Scroll to Bluetooth, press [Center NavKey]. Scroll to Handsfree, press [Center NavKey]. Place accessory in pairing mode. See accessory pairing instructions. Scroll to Look For Devices, press [Center NavKey]. Phone displays Scanning. Scroll to XXXAccessory NameXXX, press [Center NavKey]. Phone displays Bond With XXXAccessory NameXXX. Press Yes [Right SoftKey]. Phone displays Enter Passkey. Enter 0000, press [Center NavKey]. (See accessory instructions as passcode may vary.) Phone displays Connected.
Jun 17, 2007 | LG HBM 730 Bluetooth Headset Wireless...
LG HBM 730 Bluetooth Headset Wireless Headset Logo
570 people viewed this question
Top LG Radio Communications Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
coolboyjitu
Level 1 Expert
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
