Question about Compaq iPAQ H3850 Pocket PC
PC/PDA "connected" yet PC won't read PDA
I purchased a used Ipaq 3955 that had a dead battery. I installed Active Sync on my PC and when the PDA was in it's cradle, I was able to "explore" and view all the files stored on the PDA. I then decided to download a few new games to the PDA and after I turned off the PDA and removed it from the cradle, I realized that all the files I had stored had been deleted due to lack of a battery. So I purchased a new battery and changed it. Now the new battery is charged and when the PDA is connected to the PC via the cradle, Active Sync on both the PDA and the PC state that the two are "connected" but the error message reads that the PC cannot verify the version of Active Sync on the PDA. When I click on 'explore' within Active Sync, the folder shows NO files. The PC is unable to read the PDA now, eventhough the Active Sync program says they are connected. I made sure there was nothing being blocked by a firewall and I also checked to make sure that both the PC and the PDA were set up to connect via the USB ports. I have tried multiple different USB ports. Still nothing happens. Help??
please tell me how to change the battery of my PDA HP 3870 without losing my data. Thanks
Timak
  • 905 Answers
Try this.
With the PDA not in the cradle, unplug the cradle from the computer. Open up the activesync app, and goto File >> Connection Settings. Show Status should be checked, as well as Allow USB Connections. The 3rd box should not be checked if you are not using any serial links. Connected To should be set to automatic unless in corporate environment, Open Activesync should be checked, uncheck allow wireless connection.
Don't plug your cradle into a USB Hub either. The way the hubs operate and what activesync expects aren't quite always the same.
You didn't mention if you have a sleeve for your iPaq or not, also try above with and without the sleeve. Hopefully, the sleeve won't be part of the problem because it is so much easier getting the iPaq into the cradle when a sleeve is installed.
Posted on Sep 02, 2009
    Problem Solver:
  • 5 Answers
Try syncing through bluetooth, there could be a problem with the cradle. i have had an issue very similar to yours and had to do a soft reset on my pda. then set up your device to use a blue tooth connection( you may need to buy a bluetooth dongle for your pc).
Posted on May 29, 2009
HP iPAQ 110 will not active sync
no operating systems stated,
windows 10? what?
why would a battery this old be good, if was, its like world record.
buy a new battery ,better upgrade to smart phone.
sync
but the HP end and the Microsoft end have to have compatible and working drivers. to work.
the 110 is dead product at HP
http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=3544497
your only hope is talking to Microsoft now,
see if they support it, my guess w10 does not
how far back , support software drivers ended, ask MS.
looks like (hard to track) w7 is last OS supported.
i see scalpers selling drivers now, for this old product.
good luck with them,,,
try asking on a real HP forum
other asked this vast times, and the answers are dead correct.
http://h30434.www3.hp.com/t5/Calculators/Synchronization-involving-HP-iPAQ-110-and-Windows-8-PC/td-p/5078151
excerpted
Unfortunately, WMDC is not compatible with Windows 8 and you will not be able to sync your Outlook related data to your iPAQ. There is no expectation that Microsoft has any plans to update WMDC to make it compatible.
You may be able to use a third party paid application to sync the data, like Companion Link or Akruto Sync.
Mar 19, 2017 | HP iPAQ 110 Pocket PC
Active sync problem
check your anti-virus and firewall software - this can prevent outside connections being made over activesync
Nov 30, 2008 | HP iPAQ H1940 Pocket PC
HP Ipaq h5550 does not connect through cradle
First sorry for my bad english.I have a same PDA (acually its dead :-( ) And me too had this problem.Try moving a little bit your pda on cardle, or (this looks like crazy but actually worked for me) do not fully put in the cardle into pda.I mean dont stick in into cardle, just a little bit.
Jun 30, 2008 | HP iPAQ H5550 Pocket PC
Did you tried installing the ActivSync again, for Windows XP the version is 4.5, for Windows Vista is 6.0, Try installing the AS
Feb 02, 2008 | HP iPAQ H3955 Pocket PC
Active Sync Installation not recognizing Outlook on PDA
Remove the Activesync software...reinstall it.
Thats the best and fastest suggestion I can give you.
I have the same problem off and on.
Nov 21, 2007 | HP iPAQ rx5915
Application not supporting
to install any application u need to attach the phone via cable with ur phone using active sync..then run the application on the pc it will get installed automatically on the pda.
Oct 15, 2007 | HP iPAQ hw6515 Pocket PC
Does the ipaq 2215 work with Outlook 2002?
Active Sync will work with many version of outlook. Your PDA interfaces with Active Sync. Certain versions of Windows Mobile software and/or PDA's require higher versions of active sync to sync correctly.
Sep 12, 2005 | HP iPAQ H2215 Pocket PC
IPAQ 3955 Won't Sync?
Try uninstalling, rebooting and reinstalling ActiveSync on the host. If you haven't yet upgraded to 3.6, maybe upgrading will clear up the problem.
Sep 12, 2005 | Compaq iPAQ H3955 Pocket PC
Reinstallation of app onto iPAQ upon hard reset
In activesync under Tools/Add REmove programs you can check the box and click "ok" that will install the program. For the most part it's best to do it one program at a time. Obviously your PDA should be cradled or this. Most programs will re-install fine this way. Some programs though do require you to re-install from the installtion program directly since active sync doesn't pick up some important parts of the program. The two programs I have that require the special install are: CLC Journal since it has an outlook component and sets up a sync for the Outlook Journal. The Stowaway Keyboard driver since it had to ask me what language (the new driver doesn't do this...) The other 30 odd programs I have install straight from active sync.
Sep 11, 2005 | HP iPAQ HX2110 Pocket PC
Compaq iPAQ H3850 Pocket PC Logo
303 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
