Question about RCA P52939 52" Rear Projection Television
Rca big screen tv
I have a RCA big screen tv, that plays well except for the picture is blury, and the words displayed are fuzzy what causes this and is it wroth fixing thanks for any help you may be able to provide
    Genius:
  • 1,030 Answers
How old is the set. im guessing from my research the set could be about 4 to 6 years old?.... this could be many things but first thing i would guess is the fluid in the tubes could be getting old..as they age the fluid grow alge and blurrs the image. also dirt and smoke tend to dirty the lens on the crt. most tv shops can change this fluid. If they do the tend to charge quit abit. our shop would charge between 250 to 400 to do this. I find this to be a rather involed repair. removeing 3 crt remove the fluid cleaning the tube and replaceing and adjusting them. so first thing is to clean the lens and the mirror
Posted on Feb 08, 2008
MY RCA R61WH76 61 INCH TV IS BLURY AND LOOKS LIKE IT HAS 3 PICTUR
RCA Scenium Profiles HD61 TV IT'S AT 480i how I get at 1080i or 720i please help....thanks...
Jul 02, 2009 | RCA R61WH76 61" HDTV
RCA model P60812BL 10 years old picture goes fuzzy once on
Your convergence amplifiers are begining to malfunction. This is not expensive However I would advise that you get a qualified TV technician to work on the set due to a chance of damaging you TV if you install the amplifiers incorrectly.
I hope this helps
thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
May 24, 2009 | RCA D52W19 52" Rear Projection Television
If I tap the rca jacks in the back the screen gets distorted
You need a hdmi connector from your tv source to the TV. RCA connectors don't have the capability for HD signal transmission. You can use them for a connection but the picture will be fuzzy if trying to watch HD signal. Check your cable/dish box to see if there is a hdmi output. If so, buy a hdmi cable & that should solve your problems.
Mar 19, 2009 | Akai LCT4216 42 in. LCD Television
TV, RCA MOD # F19424, CTC 203U5, Picture blury
Focus and Screen. The focus control may help, just like focusing a set of binoculars or an old camera. Watch the picture on the TV, using a mirror can help and make an adjustment until the picture is as clear as you can get it. If it still is not clear it may mean that your picture tube is weak.
If you can avoid it, don't touch the Screen control. If you have, let me know and I can advise you on the proper way to adjust it.
Oct 09, 2008 | RCA Televison & Video
Mitsubishi big screen blury
In all probability the picture is fuzzy too, its just harder to notice. This can be as simple as an adjustment in the back of the set. Carefully remove the back and look for the flyback transformer (part with large red wire coming out of the top). The should be 1 or 2 controls on it. One should be marked focus. Adjust that to get sharper focus.
Let me kow if that fails to resolve the problem.
Thanks,
Dan
Sep 30, 2008 | Mitsubishi WS-55807 TV
Big grey/black spot
Is it a fuzzy spot or an actual hard edged black spot?LCD televisions can have a loss of pixel display- most very small. Was the TV hit with something or dropped against something (the screen)?
OR Try this first:
Black box appears on the screen
• Closed-captioning might be on. Check the Analog or Digital Caption option in the Setup menu.
Please let me know if your problem is solved. Thank You.
Aug 15, 2008 | RCA LCDX2722W 27 in. Television
Won't play ANY movies
separate the plug on the other appliance,check if the trouble is dvd or tv by connect other input device like game console or dvd.
Feb 11, 2008 | RCA DRC8052N DVD Recorder
RCA Big Screen is fuzzy.
Common problem and RCA recommends the following to cure: replace R17520 with p/n# 218508, C11503 with p/n# 194903, and crystal.
Bill
Dec 12, 2007 | RCA P52937 52" Rear Projection Television
Picture fuzzy and flickers (like tracking)
The flicker could be caused by a bad solder connection arcing or even a bad picture tube. If you notice the screen getting drawed in from the sides as well as top and bottom it may be in the power supply regulation circuits, but the focustat around the area of the high voltage transformer could also be breaking down. If it's over about 8 years old, I would replace it with a HDTV set. Check out the latest issue of Consumer reports for ideas. (No I don't work for them-I've just seen so many people just walk into a *Mart and pick out a TV like they were choosing a box of cerial without doing a bit of research to find one that would suit them best, that I'm trying to put out a word to the wise among us).
Feb 04, 2007 | RCA F35673MB 35" TV
RCA P52939 52" Rear Projection Television Logo
186 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
