Question about Dryers
Fixing a gas dryer belt
I need help getting the new dryer belt to tighten up with tension.
I got this far & can't find how to get tension on it.
It is a GE gas dryer w/ a model # of
DDG7980RALAD.
Thanks, Jason
jmjmorgan@sbcglobal.net
  • 240 Answers
That I believe is an older model GE with the idler bar instead of the short bar. I believe there is also a rear panel that you can remove to gain access to it. I dont remember for sure if it keeps tension up or down. Loop your belt around the motor pully, then find out which way it keeps tension on the belt, then loop the belt around the idler pully and release so that it keep tension on the belt itself. Let me know if you need further information.
Posted on Feb 06, 2008
Tighten belt tension on whirlpool dryer
No way to tighten other than replace belt, or new tension spring.
Aug 30, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Managemylife com
See if there is a pulley on the belt that can be moved to tighten the tension. Often the motor's mounting bolts can be loosened and the motor itself can be moved to tighten the belt and restore friction. If not possible, a new tight belt is in order.
Nov 23, 2013 | Maytag Dryers
How to fix a belt that is making a loud noise on a 1994 Ford Taurus
If it is a loud squeaking sound, the belt is stretched out too far for the tensioning pulley to take up the slack. Check if the belt has grease or oil on it. If it does find the cause, fix the cause and then change the belt...there is no tension adjustment to be made,
Jan 14, 2013 | 1994 Ford Taurus
Does the dryer belt need to be tightened occasionally like the washer belt does ?
no,it has a tensioner on it to keep it tight,its either glazed and slipping on the drum or the drum wheels that the drum ride on are full of lint and dragging and need replaceing or oiling
Mar 06, 2011 | Maytag Atlantis MDG8600AW Gas Dryer
I have a 1999 chevy blazer with a 4.3 in it. i put a new belt tensioner and a new belt on it. everytime i put a new belt on its quiet for a while but then eventually it starts squealiong once it gets...
no ajustment...spring loaded.... but need to check all the pullys with the belt off a lot of the time it is a idler pully making it ride wrong but not far enough to throw belt off....hope it helps
Nov 25, 2010 | 1999 Chevrolet Blazer
Belt over pullies correctly
they should be on a tensioner that automatically tightens check the spring on the tensioner if it is weak replace it they usually last the life of most dryers however you have a commercial one so Lord only knows how many hours a day it runs
Dec 19, 2009 | Fisher and Paykel DE08 Gas Dryer
Dryer gets hot but wont turn.
guess what when you buy the new belt the instructions are on the package and the belt is only about 20-$30 bucks try it yourself and be sure to unplug the unit when you do it nothing greater than doing a project youself and it works after your done......
Aug 26, 2009 | Kenmore 63942 Dryer
How do I tighten the tension on the alternator belt? I have a loose belt on my 1993 Legacy, and I don't know which bolt(s) to loosen to tighten the tension on the belt. Also, is this a pretty easy fix, or...
there is a nut on the idler pulley under alternator loosen this then there is a bolt above pulley tighten this then tighten nut on pulley you should be good to go
Aug 19, 2009 | 1993 Subaru Legacy
Drive belt needs replacing on Hotpoint TC71P
how do i get my tension correct on a hotpoint tc71p
Jan 19, 2009 | Maytag PYG2300A Gas Dryer
Could you please tell me how to tighten my altenator belt on my 94 olds achiva s? Your help would be appreciated, thanks
I believe this car has a sliding alternator for putting tension on the belt. There should a bracket above the alternator with a bolt that goes through it and the alternator, loosen this bolt first. Next there should be a pivot bolt on the bottom of the alternator which when loosened you can tilt the alternator back adding tension to the belt. When you have it tilted back far enough just tighten up the bolts without releasing the alternator til the bolts are tightened up all the way. You may need a long pry bar such as the tire wrench to add a little extra tension that you just can't get by hand tightening. Hope this helps you.
Jan 13, 2009 | 1994 Oldsmobile Achieva Special Edition
Dryers Logo
112 people viewed this question
Top Dryers Experts
