Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Lift-Master garage door opener Model 1045-6 1/3 hp
Door will nor operate after it has been used 3 times, with either remote or wall switch and light stays on.
If I disconnect power supply and reconnect power, unit works again for 3 times.
  • Anonymous Mar 30, 2014
    Want lift door
There is a thermal cut out in the motor, usually the motor must cool before the opener will operate again. If the opener only operates 3 times it must be heating up too quickly.
First you opener is only made to do your job for you, which is opening and closing the door. If the door does not operate properly manually the opener will not operate properly.
When the door is disconnected from the opener it should lift easilly, it should basically stay at whatever point you let go of it (midway and fully open) and it should close without slamming down. It does not matter what size the door is!!! If it does not something is wrong with your springs and the door can be VERY DANGEROUS!!
With that being said it sounds more like a static lock-up possibly a loose ground or even a circuit problem in the home.
Bryan
Posted on Jun 28, 2008
  • 3 Answers
Most residential garage door openers have a max. amount of cycles they can run per hour. Thus the difference between a residential opener which only needs to be opened a few times a day vs. a commercial opener which needs to open 10-20 times and hour. This could be your problem, you may be running too many cycles too soon. This would explain why it seems to work again after unplugging the power. You're resetting the unit. Hope this helps.
Posted on Apr 01, 2008
Master lift remotes suddenly won't work. Wired panel button works opening and closing door.
Make sure the light in the wall control is not blinking. If it is press and hold the lock button on the wall control for 3 seconds.
Feb 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
My lift-master garage opener works just fine from wall button, but will only open but not close from any remotes (from car or original remotes) If I open it with remote and immediately close with wall...
We have the same model and similar difficulties. We were told it's a bad antena. Not sure if there is anything we can do about this. Sometimes it works with the remotes, sometimes not. Always works with the wall switch, because that's wired.
Nov 12, 2010 | liftmaster Chamberlain Garage Door Opener...
Help, my Lift-Master garage door opens 2-3 ft
SOUND LIKE A BROKEN SPRING.
LOOK ABOVE THE DOOR IF THERE IS A GAP IN THE SPRING IT NEEDS TO BE REPLACED,
I DO NOT RECOMEND THIS AS A DIY JOB. THEY ARE UNDER MUCH TENSION AND CAN COST YOU FINGERS IF YOU DON'T KNOW WHATYOU ARE DOING - CALL A PRO
HOPE THIS HELPS
Apr 10, 2010 | liftmaster Chamberlain Garage Door Opener...
Problems with door
Check your door sensors. Make sure the small light on each one is lit and not flickering ever so slightly. Tweak them a bit.
Feb 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
Lift-master 2000SDR remotes will open but not close garage door. Same problem with all clickers and even those programmed into the cars. What could this be and better yet, how do I fix it?
Lift-Master 2000SDR opener. Opener generally works fine from the remotes. However, first time in the morning in cooler weather, it will start to close and the reverse and the lights blink. I have checked the senors - appear to be aligned properly. I have lubed the gear and used garage door spray on the rollers and hinges at the proper places. To close the door when this happens, I have to hold the wall button.
Nov 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Professional series, lift master 1/3 hp, the remotes will not operate door but door will operate from wall pad
Check to see if the small light in the wall pad is blinking. If so press and hold the button with the lock icon for 3 seconds.
If this isn't the case your receiver may have failed. The wall button works without the receiver;
I would remove the logic board and look for loose or missing traces on the printed circuit board.
Nov 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Lift Master 1/2 HP Prof. line and remote will not open door but from inside on wall it will if you hold the button for about 5 seconds and then hit the button again it will open door. There is a...
If you have the 3 button wall control you need to press and hold the button with the lock icon for 3 seconds.
You may also need to new wall control. You shouldn't have to hold that button in nor press a second time.
Nov 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door won't close
It sounds like the door sensors have been bumped or somehow gotten misaligned. Tweak them until the light on each one is lit and not blinking. They must be pointed at one another.
May 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hi I have 1/3 hp liftmaster garage door opener that will not open from the remotes but will open with button on wall. I think it is a reciever problem?? any suggestions?/
reset your remotes and your main transmitter after removing and replacing the remote batteries (these use rolling codes that change each time you operate the door) the procedure for doing this is listed on the liftmaster website
Apr 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,665 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
