Question about Pioneer DEH-P6400 CD Player
Display On my DEH-P6400 the display will rotate from standard to inverted color then back again, Is there a way to turn this off?
  • outsidetech Mar 07, 2008
    I know exactly what cbrguy means and also how he must feel. That 'feature' is annoying as all hell. In fact ,I consider it a safety hazard. At night when the screen (no matter which display or 'none') literally flashes back, it catches your eye and the resulting distraction could lead to disaster. Other than dimming it down to 1, I have not found a solution. But I will recommend you keep a log of this to a good lawyer in case of an accident.
One of the replies from another 'helper' hit it on the money with a different model. You need to press & hold (in off position) the # 6 button for demo. Once the demo starts, a choice for inverted display will suggest to press #5 to turn off or on. At that time you will be able to correct your problem as I have. I had to do it twice because I was driving at the time, which I don't suggest , when I remembered the advice , lo and behold, it worked . Thank you other replier for that tip.
Posted on Mar 09, 2008
    Genius:
  • 1,224 Answers
Solutions clarified someone says to hit #6 then #5 to shut off display reverse inverter demo for this radio one thing i noticed they did not mention is too completly turn off the source radio completly then hit appropriate buttons to make invertions correct i hope this clarifacation worked for you and you get a little more under standing of this demo off switch
Posted on Apr 21, 2008
    Brigadier General:
  • 6,966 Answers
For a Pioneer DEH-P6400, there are only ten (10) choices how the display will look. They are:
  • Source Icon Display
  • BGV 1
  • BGV 2
  • BGV 3
  • BGV 4
  • Level Indicator 1
  • Level Indicator 2
  • Movie Screen 1
  • Movie Screen 2
  • Entertainment Clock
I am not aware of an "OFF" choice. To change how the display would look, press on the "ENT" (Entertainment button top left) to cycle through the different visual displays.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 06, 2008
I need a wiring diagram for a pioneer deh-p6400.. please help..
red - 12v battery
yellow- 12 ignition
black- ground
blue/white- amp turn on
white FL+
white/black FL -
gray FR +
gray/black FR -
green RL +
green/black RL -
purple RR +
purple/black RR -
Feb 15, 2011 | Pioneer DEH-P6400 CD Player
I have a Pioneer DEH-P6400 head unit. I need a wiring diagram so i can reinstall it.
the standard radio diagram is
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
that should help u
Aug 13, 2010 | Pioneer DEH-P6400 CD Player
I need a wiring color code for a pioneer deh p6400 stereo deck ex i need to know what each color goes to ex. which color is the constant which is right speaker + etc
constant is yellow . switched ignition is red. ground is black. amp remote is blue white. illumination is orange. speakers are gray front right. white is front left. green is rear left. purple is rear right. all speaker wires have a match with a black stripe.black stripe is negitive
Feb 07, 2010 | Pioneer DEH-P6400 CD Player
I need the wiring diagram for the Pioneer CD player model DEH P6400
Red= acc 12v
Yellow = constand 12v
black = ground
blue/white = remote turn 12v out.
purple pairs are the Right rear speaker
Grey pairs are the front right speaker
white pairs are the front left speaker
green pairs are the left rear speaker
orange white is the dimmer.
Mar 17, 2009 | Pioneer DEH-P6400 CD Player
86 buick century
go to a car stereo store and buy an adapter plug it will plug into the plugs in your dash then all you have to do is match the wire colors from your radio to the colors on the adapter..........i believe some walmart stores carry these
Dec 27, 2008 | Pioneer DEH-P6400 CD Player
Aux and sub settings
you have to turn the headunit off using the headunit (there is a button that says off or power just cant remember which one) once its off and is displaying only the time you hold the function button and all the other options will come up.
Jun 29, 2008 | Pioneer DEH-P6400 CD Player
Wiring diagram
Check here for the info you need.
Mar 13, 2008 | Pioneer DEH-P6400 CD Player
Install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
Have you measured the 12v ignition and permanent supply?
Also check the earth.
You will need a tester for this.
Check the fuses
John w
Feb 13, 2008 | Pioneer DEH-P6400 CD Player
Pioneer DEH-P6400
Make sure the unit is turned off. Then press and hold the function button for about 3-5 seconds. It should beep and the clock should be displayed. Then press up or down then left or right.
Jan 17, 2008 | Pioneer DEH-P6400 CD Player
Pioneer premier car cd player display problem
Not sure what model you have, but there are several DISPLAY options that can be cycled thru using the DISP key on most models.
Best of Luck.
Nov 01, 2007 | Pioneer DEH-P6400 CD Player
Pioneer DEH-P6400 CD Player Logo
220 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
