Question about SuperMicro SuperServer 7043M-6
Need help on SuperMicro SuperServer 7043M-6!!
We recently bought a used SuperMicro SuperServer 7043M-6, with 2 3.06 Ghz Xeon processors, 2 GB RAM, an Adaptec 3210S RAID controller, and 4 36 GB Hitachi SCSI drives. I want to install Windows XP Pro SP2, but it seems the hard drives are not being recognized. The server had been setup as RAID 5, and thats how we want it too. I deleted the RAID 5 array and tried to create a new one, but it said there are no RAID capable HBAs or no free devices. I also got Windows to install partly, but it said there was a missing file on bootup, and I tried to just reinstall it, but now it wont recognize my drives again.
Please help!!
Thanks in advance, Jason
Ok, all you have to do is reset CMOS. the same thing happened to me once I tried to install windows on my supermicro board. What you have to do is load the bootable CD that came with the board and follow the instructions in your book.
What happens is that windows does not have the drivers for the supermicro RAID and SATA components. The board will recognize these on it's own until you go to install windows improperly. Windows does not have the drivers for those, realizes it, and says "Windows has stopped to prevent damage" but it does it anyway. Just clear CMOS, read the book with the board on how to install an OS, and try again.
Clearing CMOS: This can be done by taking out the 3.5v watch battery you see on the board for about 5 minutes. Another and riskier way is to clear CMOS by shorting the pads. On a diagram of your board, you should see CMOS Clear. Find those two pads on you board in that general area from the diagram. You'll know you've found it because the board has CMOS Clear printed near them. Just touch them with a screwdriver for 5-10 seconds. CMOS should be clear and ready to start new.
WARNING! Be careful when clearing CMOS with the pads, if you stick the screwdriver in the wrong place, you could damage your board. Be sure to unplug your power supply before working on your machine (I'm sure you know this.) and be sure to get the correct drivers for windows this time! Oh, and rechange any settings you changed in CMOS since it has been reset to the factory defaults.
Posted on Dec 03, 2008
Can run windows 8 on IBM intellistation z pro ?
IBM IntelliStation zPro came with different CPU chips through 1997 to 2006. Depending on which year or type your machine is will determine if you can upgrade to Windows8.
The chips used were
IntelliStation Z Pro
Type 6899 (March 1997 to ??)
Type 6865 (October 1998 to April 2000)
Type 6866 (January 2000 to March 2002)
Type 6894 (May 2001 to June 2002)
Type 6221 (November 2002 to February 2005)
  • Dual Intel Xeon at 2.4, 2.67, 2.8 or 3.2 GHz
Type 6223 (August 2004 to March 2007)
  • Dual Intel Xeon with Intel 64 (formerly EM64T) at 3.0, 3.2, 3.4, 3.6 or 3.8 GHz
Type 9228 (June 2006)
  • Dual Intel Xeon Model 5130, 5140, 5150 or 5160
Windows 8 If you want to run Windows 8 on your PC, here's what it takes:
  • Processor: 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2 (more info)
  • RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card: Microsoft DirectX 9 graphics device with WDDM driver
As you have Type 6223 which a Xeon faster than 1GHz it should work with Windows 8 but not all Xeon processors are compatible depending on which one you have. See this Microsoft site after you check your Xeon chip family on the motherboard or through the Windows system command. Search for xeon.
Processors What processors support Windows 8
Aug 15, 2014 | IBM IntelliStation Z Pro 6223-42U PC...
Windwos instalation
You are missing updates to the OS.
Jan 11, 2014 | SuperMicro SuperServer 7043M-6...
Error in windows installation
Not sure if XP will recognise SCSI as the primary drives. Under Linux no problem but most Windows OS's were never designed to support SCSI since it is more of a server drive system not a common home PC setup. I am not a MS fan and have not used MS products for many years so things might have changed. Remember XP is no long supported by MS so you might run into more problems down the road. I loved XP and changed OS's once the Vista/7 garbage took place.
Dear sirs, I would like to upgrade the cpu`s of my Compaq Evo W6000 PC with the Motherboard Model 06D0h. Please let me know what are the strongest cpu`s I could use. Many thanks Murat
I suggest this to you.
Intel Xeon Processor, 1.4 GHz/100.0K
Intel Xeon Processor, 1.5 GHz/100.0K
Intel Xeon Processor, 1.7 GHz/100.0K
Intel Xeon Processor, 2.0 GHz/100.0K, L3
Intel Xeon Processor, 2.2 GHz
Intel Xeon Processor, 2.6 GHz/400
Processor, 1.8 GHz, 603FCPGA
Processor, 2.0 GHz, 603FCPGA
Processor, 2.2 GHz, 603FCPGA
Processor, PRST, 2.4 GHz/400, INT 261668-004 284645-001 source: ftp://ftp.compaq.com/pub/supportinformation/technotes/evo_w6000_workstation_rev6_us.pdf
Jun 29, 2011 | Compaq Evo Workstation W6000 PC Desktop
Want to change from SCSI to SATA. How can this be done?
You will need to change the backplane to a SATA type. (Fairly easy) Once done, you can change your hard drives and start using the new configuration.
Good Luck
C2Solutions
Jun 03, 2011 | SuperMicro Superserver 8052-8 (sys80528)
My supermicro server will power on, but nothing shows up on the screen. I don't even know if it POSTS correctly.
When you power on your server, does it make any type of sound? Thanks
C2Solutions
Nov 18, 2009 | SuperMicro SuperServer 6022L-6
SUPER P4DC6 motherboard.
The P4DC6 supports upto two Intel Xeon processors this link will provide much more detailed information on your board, it also includes all updated software, drivers, bios files and manuals
http://www.supermicro.com/products/motherboard/Xeon/860/P4DC6.cfm
Oct 30, 2007 | SuperMicro Super Micro Desktop Motherb...
Silly question perhaps...
Ooh! That motherboard uses RIMMs, not regular DDR memory. And you'll need a matched pair to get it to fire up and permit access to the BIOS. Checking eBay I see you can get a pair of 256 MB modules for less than $10, so your curiosity won't cost you too much.
Sep 22, 2007 | SuperMicro P4DCE+ MOTHERBOARD
SuperMicro SuperServer 7043M-6 Logo
503 people viewed this question
Top SuperMicro Computers & Internet Experts
David
David
Victorman
Victorman
Joseph Hoffmann
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
