Question about Dell E173FP 17" LCD Monitor
Dell Monitor Weirdness
I have a Dell Flat Screen LCD Monitor I bought almost year ago.
After the first week I thought I liked it, then I did a photoshop image that I liked enough to use as a desk top and the image left a strange stain on the LCD that will not leave. Today it also has ghosts of applications I have used and windows I had open, these tend to leave their trace digital residue on the monitor for hours sometimes. Not sure you guys have a fix for this. Even so this is my last Dell.
  • JWraith Feb 07, 2008
    Ahhh. what?
  • 44 Answers
Tell me in briefly
Posted on Feb 07, 2008
  • Inderjeet Singh Bhambra
    My dear i can tell you the symptoms only.
    1. check the LCD EHT tranformer voltage (they are exceeding) or there are 2Kv polyster capacitor used in that section, they also control the voltage, if anyone of that capacitor is not working may effect on LCD screen resolution & leave stain on panel for few minutes.
    2. It may be due to LCD loose earthing connection on both side,
    LCD outside & back panel
    3. check the LCD back panel display voltage.
    4. Remove the input data cable and only switch on the EHT transformer. check the glare of LCD screen, adjust it & back on.
    thats it.
    best of luck
My Dell moniter is a 19 inch monitor (Model No: E193FPc) and it's been working fine for 5 years. Now when I plug in the power, the power button goes green, but the monitor shuts off instantly. This...
your LCD monitor has a defective cathode driver inside, it will shut down your monitor when it has short circuit or has defective cathode bulb. you have to open your LCD case to see the circuit .you need screw driver set plus and negative to open the case. if your have knowledge in troubleshooting you can check the circuit if it has a short or defective part at the cathode driver, it has two small transformer that supplying the 2 or 4cathode tube in upper and lower screen of lcd
Aug 18, 2011 | Dell E193FPC 19" TFT LCD Flat Panel...
I have a Dell 15"
You need a new driver for the monitor. Are you now using a new Operating System? Perhaps Windows 7? Go to the http://dell.com websit and look up your monitor under downloads and drivers. Fidn the compatible driver for your operating system and download it.
Dec 31, 2010 | Dell E151FP 15" Flat Panel LCD Monitor
I have a Dell E173FP 17 inch Flat Panel LCD Monitor. About two weeks ago after having turned it off at night (leaving the PC on) then turning the monitor back on in the morning it would light up to half of...
The monitor can be repaired - by replacing one or both the fluorescent tube and inverter. You can have the work done for you - or you can attempt it yourself. Lamp prices vary based on size - but most hover in the $10 range. Inverters can vary in price too - but run more than lamps for the most part. There are numerous suppliers for these parts such as this and instructions about how to do it such as this.
I hope this helps! Please rate my reply - thanks!
Dec 21, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
My Dell flat panel monitor #1704FPTt will not stay lighted for more than 1 second. It started fading when first turned on about 2 weeks ago, otherwise it has been fine. Can it be fixed (it is about 8 years...
Fist place to check will be the power supply, look for bad caps with bulging tops, check to see if you do have 12vdc feeding the back light inverter circuits, see example of failed monitors (90% are due to bad caps): http://s807.photobucket.com/home/budm/allalbums
Jan 20, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
My 15 inch Dell LCD flat screen monitor has 4 blue (cyan) verticle pixel bands about half an inch wide on my screen. The monitor is about 3 or 4 years old. Can you help?
Sorry, but it's kaput. Broken. LCDs were pretty bad a few years ago. A new one will cost a lot less than that one did, and will work a lot longer.
Oct 01, 2009 | Dell 1505FP 15" LCD Monitor
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Dell Monitor 15"flat panel-2 Horiz. black lines
HAS IT HAPPEN ANYMORE OR IS STILL THERE.
CHECK YOUR DRIVERS, UPDATE THE DRIVERS, CHECK THE CONTROL PANAL IN THE FOLLOWING FOLDER DEVICE MANAGER, PROBLEMS REPORT, SYNC CENTER
OTHER THAN THAT TECHN SUPPORT OF YOUR VENDER WHERE YOU BOUGHT YOUR MONITOR FROM OR GO ON LINE AND TYPE THE FOLLOWING INFORMATION EXAMPLE:
DELL E151FP FLAT PANEL LCD MONITOR 2 BRUSH STROKES ON SCREEN
ENTER
SEE IF ANYONE ELSE MAY OF HAD THE PROBLEM OR TO COME FIND OUT THAT THAT WAS A RECALL ITEM FOR THAT MONITOR, JUST KIDDING, ITS WAY OUT THERE
ROD
Feb 09, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Dell E173FP 17" LCD Monitor Logo
138 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
