Question about Samsung HP-R4252 42 in. Plasma HDTV
Samsung HP-R4252 Sounds good. What things do i need to check. I have a multimeter and O-scope. will I need anything else for the checks
  • 1 more comment
  • mark pasley Feb 08, 2008
    I check all the voltages on the Assy PCB P-SMPS card.
    VA 70.8vdc
    VE 90.9vdc
    VS 209vdc
    Vset 197.6vdc
    Vscan 192.6vdc
    VG 14.9vdc
    5.3 = 5.3vdc
    All the fuses are good to go.
    They are close it calls for:
    vs 70
    vsc -190
    ve 90
    vset 195
    oops va is 70 and vs is 210
Does OSD come up? On Screen Display if you hit the menu button? Also, with the room dark, can you see anykind of light being disipated by panel? or is it competely black?
Let me know. GURU JAY
Posted on Feb 08, 2008
    Sergeant:
  • 261 Answers
Just check the voltages and refer to the sticker on the back of the panel (inside) Should read VA, VE, VS, VSET, VSCAN, VSUS,VSUSTAIN, ETC. And see which ones are missing then write them down and we will go from there. See if any fuses are blown as well. Just check those on the Ohm check. Or diode check is handy as well for this. Let me know if i can assist further. GURU JAY
Posted on Feb 07, 2008
  • Jay Henderson
    Jay Henderson Feb 08, 2008
    VE i thought should be around 60vdc and Va At about 100vdc or so. What does the sticker on the inside say. Usually in upper right corner of panel. Voltages should be close. Let me know.
    Guru Jay
Hi I have a Samsung HP-R4252 42" Plasma HDTV. The
Try website like Ebay.com to buy a refurbish tv main Tuner signal board.The part number it is on a sticker on the board,must take the tv aparts to read it.The fan itself buy it on Ebay.com too,or try website like Partstore.com to buy a part fan.
Jun 09, 2011 | Samsung HP-R4252 42 in. Plasma HDTV
I Have a Samsung HP-R4252 42 in. HDTV Plasma Television and the picture is not showing. It does have sound but no picture. Is there any ease way to fix this problem??
sounds like the video cable is not in the right input.
or maybe you have to redo the setup and be sure the tv is set to the right video input . HDMI or component etc. I hope this helps.
Oct 19, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Turn on my tv samsung HPR 4252 and I get no sound or picture
DOES THE TV TURN ON , HAVE YOU TRIED OTHER SOURCES LIKE DVD ,DID YOU CHECK YOUR HDMI CABLE IF ALL OF THIS SEEMS GOOD IT LOOKS LIKE A DEFECTIVE MAIN BOARD REPAIRE ABOUT 325 DOLLARS
May 31, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung plasma hp4252 type sr42p5 faulty screen
Hi
Most likely cause are leaking capacitors in the power supply, however I've seen the convergence IC cause the same problem. If you have a good ERS meter and are willing to check parts one by one then start with the DC side of the power supply. I fast scope makes this easier. There are a lot of safety precautions you need to be aware of. These are listed in the service manual, which you'll have to have to do this kind of work. If you don't have any of the above then I wouldn't recommend you try to tackle this. Find a reputable repair person.
Apr 14, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
I have one Samsung HP-R4252 no give video and sound, I check all fuse it's good, check all voltage are good, only turn on the led in power button and flashing when press any key in the remote control, I...
try replaced main Y assy board or power supply board
Manufacturer Samsung Part Number BN96-02033A Description ASSY PDP P-Y MAIN BOARD
Manufacturer Samsung Part Number BN96-02213B Description ASSY PCB P-SMPS
Sep 03, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Hp-r4252 turns on and off repeatedly
Main logic board!! cost $100 !! Does the picture come on when on!!??
May 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
Feb 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
R4252 No picture, sound OK Y-Drive buffers overheating
Try to replace the Logic Board, about 50% chance to fix the problem.
Jan 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HP-R4252 42 in. Plasma HDTV Logo
186 people viewed this question
Jerry Greenberg
Jerry Greenberg
