I have 2 furnaces with the HE225A1006 humidifier. With heat on, water supply on, humidity control up (hear click at approx humidity level), the water flow is never delivered to the unit (I think solenoid never turns on). Have new filters in. They only worked the first year. Any thoughts? THANKS!
I have same problem with no water flow on identical humidifier but was able to fix it. Removed the inlet to the solenoid valve and found (1) a small taper mesh filter inside (2) a small diameter orifice that was clogged. Cleaned the miniature filter and used a sewing needle to open the orifice and now works perfectly.
SOURCE: Aprilaire 760 Humidifier water continues to run
You need to determine whether the problem is in the solenoid or in the furnace electronics. You could put a voltmeter on the solenoid connection to see if the furnace is still holding the solenoid open after the blower stops. This will tell you whether it is the solenoid or not.
SOURCE: Water flow through humidifier
The solenoid that turns on the water to the unit should not change the water flow, so you should get the same amount of water that flows into the solenoid. If you want less water, you can partially close the valve at the water source.
SOURCE: Continous ware flow on Honeywell HE220A Humidifier
I am having the same problem. I have had my humidifier for about 5 years now and I just started having the problem where the water continuously flows through the solenoid. I took apart the solenoid by removing the fittings from both sides. When I did that, I noticed that there was a hole in the metal that allowed me to see through to the other side. Apparently, it had corroded and and broken through, allowing the water to pass through the solenoid without really going through the valve within the solenoid. There are several sites that sell replacements for about $70, which is not cheap, but cheaper than buing a new humidifier for $120. Here is one site I found: http://www.iaqsource.com/product.php/honeywell/32001639-002/?product=112783&category=1142
SOURCE: cleaning a furnace humidifier steel filter?
Most water panels are generally replaced once a year on flow through humidifiers.
SOURCE: wiring problem
Sounds like you may have put 120v through a 24v solenoid and humidistat.
Is the HUM terminal on the furnace 120v or 24v?
If it is a 120v terminal you will need a 120x24v transformer and a new solenoid and maybe a new humidistat.
