Samsung Projection DLP Looks like
Looks like a piece of hair or something is caught inside. About 1 inch wide on the screen, transparant, around 10 inches long. The end of it wiggles. This morning it was on a different area of the screen. Any idea what it could be?
  • sda4chester Nov 25, 2008
    I have the same problem, looks like a hair on the screen and it wiggles, is it a hair?
    Master:
    Sergeant:
  • 440 Answers
Ya hair on bulbs get in ther blow it out suck it up dust trythat 1st ok
Posted on Feb 06, 2008
I have white dots on my HL-6156 Samsung tv. Started with 4 and is now 10 wide spaced over 12 to 15 inches of screen. Anything I can do ? Set is 5years old.
The DLP chip needs replacement that what causes the white dots eventually they will fill the entire screen assembly. You can get the replacement DLP chip with instructions from www.tvrepairworld.com
Mar 21, 2013 | Televison & Video
I just finished replacing the color wheel on my samsung dlp tv and now there is a 3 inch wide dark stripe down the left edge of the tv. the stripe is transparent but it looks like something is covering up...
First thing you want to check is the bulb alignment and make sure there is nothing obstructing the light source. Check the foam sheath on the projector lens and I hope you didn't touch the color wheel with your fingers, you coauld be seeing the effects of finger prints.
Jun 08, 2011 | Televison & Video
What is causing my picture to darken on my samsung 60 inch dlp tv
Most likely the tv projection lamp life are ending.The tv projection lamp been inside this tv like 1 1/2 or 2 years?Tv been on watches like 4 or 5 hours each day?The tv projection lamp life are ending,require a new tv projection lamp.
Jan 04, 2011 | Samsung HL-S6767W DLP TV
Dark shadow about 4'' at top of screen of 56'' dlp samsung hlr5667
There is a piece connected to the color wheel assembly called a light tunnel. It is between the color wheel and optic assembly. There is 4 mirrors inside. One of them probably got dislodged when the wheel shattered. Sometimes they can be repaired using high temp glue or you may have to replace the tunnel.
May 18, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
GREY AREA ACROSS TOP OF MY HP 65' DLP PLEASE HELP
My brother had the same problem and had the sending tube or its a round tube that projects the image to the screen. He had it repaired in home for $465.00. Ouch!
Dec 11, 2008 | Toshiba 50HM67 50" HDTV
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Purple-tinted transparent line
im thinking the set has a bad engine
Dec 18, 2007 | Samsung HL-R5678W 56" Television
Toshiba 46HM84 DLP Black and white pattern..
contact your dealer for service flashfor this symptom.(light tunnel)
Aug 11, 2007 | Toshiba 46H84 46" Rear Projection...
Toshiba DLP TV
Light engine issue I would say, is it somewhat transparrent? if totally black might be something else but more than likely will be a light path issue inside the light engine.
Jul 17, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
