Question about Enteractive DarkBASIC 3D Games Creator for PC
About nests Could anyone tell me what this error message means? After running source code, message reads: "Could not close nest at line ##" I'm new to DarkBASIC and most programming languages, but I'd just like a method to pursue debugging it myself as to learn better. Cheers, Dharq
  • imhotter1
    imhotter1 Dec 06, 2012
    set text size 60 cls rgb(0,0,0) `opening to the game center text 300, 150, "CRAPS" set text size 25 center text 310, 200, "CREATIVE COMPUTING MORRISTOWN, NEW JERSEY" SET TEXT SIZE 18 center text 300, 250, "press any key to continue" wait key cls rgb(0,0,0) print : print : print R = 10 T = 0 game_start() function game_start() Number_choice() Dice_roll() endfunction function Number_choice() print "losing numbers: 2, 3 ,and 12" print "point numbers: 4,5,6,8,9, and 10" print "jackpot numbers: 7 and 11" print "other numbers dont matter" print "pick a number and type it in, than click enter to roll dice" input Z: X = (rnd(0)) T = T + 1 if T = 0 print "if you want to play again input 5, if not put in aything else" input M if M = 5 game_start() else ending_credits() endif endif endif return function ending_credits() print "thank you for playing" print "press any key to end" wait key end endfunction _line230: if X = 4 or 5 or 6 or 8 or 9 or 10 print X;" is a point. i will roll again" H = int(7*RND(1)) Q = int(7*RND(1)) O = H + Q if O = 1 or 0 gosub _line230 if O = 7 gosub _line290 if O = X line310() exit endif endif endif endif return _line290: print "you lose $" ;F F = 0 - F R = R + F gosub _line320 return function line310() SET TEXT SIZE 50 print "winner............CONGRATS!!!!!!" SET TEXT SIZE 1 PRINT "its a girl" set text size 18 F = 2 * F R = R + F if X = 4 or 5 or 6 or 8 or 9 or 10 print X;" is a point. i will roll again" H = int(7*RND(1)) Q = int(7*RND(1)) O = H + Q if O = 1 or 0 gosub _line230 if O = 7 gosub _line290 if O = X line310() exit endif endif endif endif endfunction
That's when you forget to add endif after the IF statement
Posted on Jul 02, 2008
I am trying to replace my Totaline P374-1000 thermostat with a Nest. The Nest needs 110 or 120 volt, but there is no sticker on the P374. Can you please tell me?
Your Totaline 374 almost certainly is running on 24 Volts transformed from somewhere near your furnace, boiler or a/c unit. You will probably need to find that and run new wiring for your NEST. I suggest you consult with a professional electrician or HVAC tech if you are not experienced in such things. Transformer probably looks like this:
Jun 25, 2018 | Heating & Cooling
My hotpoint washer WMFUG942 has displayed error code F06 and has flooded my kitchen due to the water from my machine expelling through the kitchen sink during the cycle thanks
Please check for rodent nest. For some reason bugs and small rodents love to nest in areas of resistance..actuators..rexepticles..plug ins..sounds dangerous for the newborns right? Thing is its that old nest that is your problem now. It degrades and chunks jam here and there then stuff stops working. Adverse weather forces creatures to seek temperary shelter especially if a birthing event is looming. So don't try to stop it as nature always wins..but inspect your appliance as soon as you notice a change in performance before that nest costs you a days wages.
Feb 09, 2018 | Hotpoint Washing Machines
Rookie question:I have a 12yr old Goodman model GMP 050-3 furnace w/ Honeywell thermostat.I want to a Nest digital thermostat but red line doesn't have enough juice to power the Nest. My options?
I'm guessing your blue wire is your common and red is hot. You need a voltage meter. Should have 24 volts with R&B. If not either you blew the 5 or 3 amp fuse when hooking up or your wiring is wrong. If there is an outlet close you can test red to ground and see if you have 24. If you do have 24 blue is either not common or its unhooked or shorting on something. Good Luck!! Fuse would be internal , car style, turn power off and open furnace to inspect.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 03, 2017 | Heating & Cooling
New Nest thermostat, Model 2.8 Software version 4.0.1 keeps getting a low battery and shuts off and shuts down the furnace. Please help.
Do you have a common wire? The nest thermostat needs the common 24V C wire installed to keep the battery charged fully. Nest should tell consumers of this problem, but they don't. Its required for any powered thermostat. Even the new fancy Honeywells with touch screens etc..
Gotta realize the battery cannot run the display and wifi plus all the sensors for very long.
Jan 23, 2014 | Nest Learning Thermostat 2nd generation
QuickTime Troubleshoot
I am having a 'problem' installing iTunes v8 - the install seems to go ok until I get to the part of the program which invokes the Quicktime software upload (v7.5).
Although I don't get a 'controlled' Error message, I am advised that
"A newer version of Quicktime is installed on your computer - Quicktime needs to close" a message then appears telling me that iTunes install has failed as "iTunes needs QuickTime" - no **** sherlock!!
Try as I might I am unable to get past this problem - can anyone out there advise me ?
I have uninstalled until I am blue in the face using all teh standard solutions i.e Regedit, MSConfig, removed Temp Files in Docs & Settings etc etc. To my mind there is still part of the system that has nested a piece of Quicktime code that is screwing up the install.
This is doing my head in and I have 2 iPods that requirev v8 that I cannot use!!
Sep 15, 2008 | Apple QuickTime
Dryer stops drying and lint error message...
try cleaning the vent line. if you have a flex vent line make sure it isn't kinked in any spot. make sure the outlet outside does not have a birds nest or anything blocking it
Nov 10, 2007 | Siemens WT79020EU Electric Dryer
Enteractive DarkBASIC 3D Games Creator for PC Logo
441 people viewed this question
Top Enteractive Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Enteractive Computer and Internet Expert? Answer questions, earn points and help others
