Question about Cooktops
GE gas cooktop problem
The igniters spark when the knobs are off does not doit all the time just every now and then. It may go a week and not do it and then it may do it every day.
  • 2 more comments
  • Anonymous Feb 13, 2008
    on my gas cooktop, all ignitors spark when any knob is turned to lite (normal i assume). However, once that burner ignites, they all continue to spark simultaneously and constantly unless the knob is turned down to medium or below. So you can only cook from low to medium without the ignitors firing constantly. All burners do the same thing. I just installed this stove. It is used but in good condition. What is going on?
  • jsample Feb 18, 2008
    I have this very same problem! My GE gas cooktop is 15 years old but recently (6 mos or so) has started this same problem. Solution?
  • hateGE May 29, 2008
    I have had the same problem with my GE Monogram cooktop since 8 years ago. In my case, it tends to click non-stop if the most-used burner is turned on. Once it starts nothing seems to help. I also had problem with GE dual oven which has control panel problem which causes error messages and beeping sounds all the time until fuse switch is off. I replaced the control panel for about $300 but it started to do the exact same thing after about 1 year. So, now I simply turn off the fuse switch when not in use. It seems as though all GE products are made to work reliably only for 1 year which is the warranty period. Only reason I have GE applicances in my house is because it was built in when I bought the house. I will never buy GE appliances for the rest of my life. They are nothing but garbage. No wonder, recently, GE CEO Immelt announced that he plans to sell the appliance division. It is about time that American appliance companies shape up to improve the reliability to compete with forign companies just as they did for automobiles.
  • kanickjr Jan 23, 2009
    My GE gas cooktop sparks all the time -- on or off.  I had to unplug it.  Any solutions?
Sounds like the switch assembly should be replaced
Posted on Apr 08, 2008
After spraying stainless steel cleaner on the cooktop, with the knobs removed, the igniter won't stop ticking as if it's trying to ignite. All the knobs are securely in the off position. Could this be...
Yes, the moisture is probably the problem...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Jan 21, 2011 | GE 30 in. Profile JGP933 Gas Cooktop
My GE Profile propane gas cook top was just installed yesterday. When I go to turn on one of the burners, all of the ignitors click. This can't possibly be normal. Anyone else have this issue?
Yes, thats okay when you turn the knob voltage gets sent to the spark module, Then the module sparks all the burner igniter. And frame ignition only happens on the single burner of the knob you turned that sends gas to the burner associated with that knob.
Please rate me a "4" if this information was useful.
Dec 14, 2010 | GE Profile JGP636 Gas Cooktop
The igniter doesn't work at all. If I turn any knob to the ignite setting, you can hear the gas coming out but there is no ticking sound, and therefore no ignition. Can I fix this myself?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 03, 2010 | GE 36 in. JGP628 Gas Cooktop
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
Cooktops Logo
526 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
