Question about Jazz DV-179 Digital Camera
Using Jazz DV-179 as WEBCAM on MSN Messenger
Having a small problem getting this camera to work as a webcam on msn. I have installed the cam and went thru msn setup. When I send my cam to an msn contact it starts up and gets to the point where I can see myself but the other contact see nothing. This happens with all my contacts not just one. then after a few seconds of seeing myself it closes and the camera turns off
I have also tried using different USB plugins.
My ideas??
  • kelise Mar 09, 2008
    Whenever I hit the record/play button it should automatically give me the pc camera mode however a **tice shows up that microscoft does **t have the scanning capability for this specific device; and offers ** options; therefore ** ability to use the web cam? Please advise.
  • 90 Answers
Please call Jazz Products @ 732-572-7050
Posted on Jun 30, 2008
Not working with msn messenger
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Apr 06, 2010 | Logitech QuickCam Messenger Web Camera
How to configure logitech with msn messenger?
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Click 'Finish'
Dec 09, 2009 | Logitech QuickCam Messenger Web Camera
I have installed the camera and it works fine in testing it.....but when i want to use to on MSN, it says there is no camera installed. i have unistalled and reinstalled but am lost how to get it to work?
HI,
First uninstall your msn messenger and then uninstall then webcam software/drivers.After that reinstall the webcam and then reinstall the msn messenger.
This should fix the issue.
Let me know the result.
Thank you for using fixya.
Nov 17, 2009 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
Dell webcam manager working with msn messenger?
if you have the webcam center opened along with with msn then it wont work on either one of them.
you can try these steps tp check if it works for you or not.
1)look for the web cam center system tray icon and right click on it if its there and select exit
and as u said u cant see you self in web cam console --- in webcam console you can only see your self under the doodling tab and only of your webcam is working at that i.e
either you have the webcam center opened or any other messenger or software which turns on your cam then only ull be able to view your cam in webcam console alongside.
Apr 28, 2009 | Dell XPS M1530 Laptop
as ive told others, make sure u actually turn off the software program that came with the computer before using with msn! u should be able to have it on while using it but for some reason some computers wont allow it! it "tells itself" that there are 2 programs trying to run the web cam when really only one is.
but because the program is on, it sees it as being used in 2 places at 2 different times!
try turning off and exiting the software (dell webcam manager) and then go onto msn and try using ur web cam!! make sure the dell manager is exited, then when u have a msn window open, turn the cam on and see if ur friends can see u then..
good luck..
if this doesnt work ill check back and see what i can do for you!
Mar 21, 2009 | Dell Inspiron 530 Desktop Computer
Acer crystaleye webcam wont work with msn
I know a lot of people are having problems with the acer cam
if you updated msn try going back to your old version
or if you have'nt updated it you can try that.
The only other thing is to uninstall cam and reinstall
I've had to that so many times on my acer crystal eye cam
Jan 14, 2009 | Computers & Internet
Acer Crystal Eye Webcam and MSN Messenger
Straight from MSN helpdesk:
1. Click Start, click Run, copy and paste the following text: %SystemDrive%\Program Files\McAfee\SiteAdvisor in the Run box and click OK.
2. Right-click the file sasets.ini or sasets.dll and select Open With, then select Notepad.
3. Locate the section titled [msnmsgr.exe].
4. Change Enabled=1 to Enabled=0.
5. Click File and select Save.
6. Close sasets.ini or sasets.dll and restart your computer
Kathie x
Jan 09, 2009 | Acer Aspire 5920-6727 Notebook
Jazz dv179 webcam sound?
My digital JAZZ DV 179 works normally but don't fontion as webcam, what can I do?
Nov 22, 2008 | Jazz DV-179 Digital Camera
Philips spc 700nc web cam
First of all, have you verified you are using latest version of MSN messenger. If so and the problem still exists, give one of the other instant messengers a try, say like YM or AIM or any number of others.
What exactly do you mean by ' seems to work '?? Can you see yourself in the cam using whatever software other then MSN that you may have on your computer.
Feb 20, 2008 | Philips SPC700NC Webcam
Jazz DV-179
i don't think that the camera work as a webcam from the computer.
Jan 24, 2008 | Jazz DV-179 Digital Camera
Jazz DV-179 Digital Camera Logo
152 people viewed this question
Top Jazz Cameras Experts
wgenglan
Level 1 Expert
pontelemon
pontelemon
Are you a Jazz Camera Expert? Answer questions, earn points and help others
