Question about Toshiba 57H82 57" Rear Projection Television
I am working on this tv it has no picture and there is a red light blinking
Power suppliy fuse is good i have no picture and a red blinking light
  • rixwrex Feb 21, 2008
    I have the same problem I turn the tv on and I hear click click and then the lite starts blinking in the front
  • vampski17 May 16, 2008
    Hey, I also have the same problem with my tv. The blogs you referred to had a different problem, picture was all messed up. This convergence amp can affect either the picture altogether or just skew it?
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
Posted on Feb 07, 2008
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
When the TV is plugged in the screen is black,little red power light bottom right corner blink 5x then you hear the sound of power on pause then power off. This continues to repeat and no picture.
Repairing Flat Screen TV - Blacked out with blinking red light
? 12:00
https://www.youtube.com/watch?v=3GmtBthpzDk
Mar 15, 2012 - Uploaded by n1bpd
Repairing Flat Screen TV - Blacked out with blinking red light ...Capacitors are little cylinders with a flat top with an X. If they have failed the X .... picture, no sound, totally black just the red power light blinking on the corner ... hello i have a dynex dx-lcd42-09 the red light blinks as soon as i plug it in i opened ...Missing: 5x
comments on EASY HOW TO FIX SAMSUNG TV- NO POWER
https://www.youtube.com/all_comments?v=hgcmWO7mqmo
Dec 16, 2015 | Samsung 55" UN55D6420 3D LED TV Smart TV
A Philips 37PF7321D TV, no picture. Powers on, audio works, input switching works. Got picture once (menu and signal) clear, bright and good color. No blinking red lights. What to check or test next?
Looks like you have done a lot of testing. Try Philips at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Feb 26, 2015 | Philips Televison & Video
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Where is the fuse located on a KP53S25 Sony TV?
hello there should be a glass fuse in the power supply also beware in a lot of sony sets there are soldered in fuses aswell. and circuit protectors i hope it helps
regards
shaun
Feb 05, 2010 | Sony KP-53S25 53" Rear Projection...
My toshiba TP50H15 color tv comes on then off and the light blink
The flashing power light on those Toshibas is usually caused by capacitors on the power board having failed solder connections. I have fixed them before by removing the power board and resoldering the capacitors. If you have experience with soldering and electronics it is an easy repair. Most shops will recommend replacing the entire board since their labor to repair it would probably cost more. Toshiba put out a service bulletin on this issue which a good technician should be aware of. (If memory serves the capacitors are C109 and C110.  Since your TV still turns on you probably haven't blown fuse F860 which often blows when these capacitors act up.)
If you would like further help with this please post a comment back here.
Dec 05, 2009 | Toshiba TP50H50 50" Rear Projection...
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
No Picture
i have the same problem, differnt tv.
Blinking Code: LD740
it's for a 42w34 lg/zenith.
im thinkin power board, or Zsus..
Dec 10, 2007 | Acer AL2416W 24 in. LCD Television
Toshiba 57H82 57" Rear Projection Television Logo
62 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
