Question about GE JVM1440 Microwave Oven
Not heating The power to my microwave is ok, the unit turns on, etc. The problem is it is just not heating anything..AT ALL.Is this a problemwith the chopper or something else.
  • Anonymous May 01, 2008
    my unit comes on,but does not heat food. the carasel and fan work fine
  • 579 Answers
Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Posted on Feb 07, 2008
My 10 year old GE Spacemaker XL1400 microwave has stopped heating the microwave's contents.
probably a magnatron failure
take it to an appliance repair shop for a proper diagnosis and get a quote as repairs can be more expensive than new unit
Nov 24, 2015 | GE SpaceMaker Microwave Ovens
Runs but does not heat the food.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
Allow the circuitry to dry out by avoiding stovetop cooking for a few days. .... it to microwave, but its just not warming up myfood at all, any idea on how i can .... Everything works except themicrowave- it wont heat anything up.
Microwave Diagnostic - Has Power Not Heating - GE ...
? 2:34
https://www.youtube.com/watch?v=E_iUYIV8wD0
Aug 9, 2013 - Uploaded by ApplianceVideo.com
Microwave Diagnostic - Has Power Not Heating - GE, General ....internals of a similar GE Microwave unit that would not heat food.... Sometimes it turns on, sometimes it doesn't. .... My GE microwave space saver does not heat but it comes on. ... What's Inside A Microwave Oven (Teardown / Taken Apart) ...
Nov 18, 2015 | Microwave Ovens
My fan for the stove reduces power once the microwave is turned on
you must understand that any manufacturer has the proper design engineering from to save electricity, etc. And they using the new concept of reingeenering.
If the microwaves do not HEAT and working, do not worry.
Mar 06, 2013 | Microwave Ovens
Kenmore 665.6061200 over range microwave. Problem started a few days ago with a clicking sound from the RH side of the unit (seemingly behind the control panel), about 3 clicks per second for about 3-4...
The most likely cause of the clicking sound is the power relay that is connected to the microwaves PCB (circuit board) that turns the magnetron on and off. If starting to fail it may result in multiple clicks, then once fully failed, your microwave would simply not heat anything (as the high voltage components would not be getting power).
Unless you have a strength in electronics and repair, and understand the lethal dangers involved in working on a microwave, even one that is unplugged, this problem will likely need to be repaired by a qualified service centre.
Depending on the microwave design and the technician the whole relay circuit board may need to be replaced making this repair vary from relatively inexpensive to more expensive.
Oct 21, 2010 | Microwave Ovens
Everything works OK but will not heat anything
Look at magnatron for holes, diode, and HVTransformer..Depending on age of microwave you may need a new one.
Jun 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Neff microwave oven not heating
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 22, 2009 | Microwave Ovens
Ge jvm1870 it won't heat anything, all other items work
Ok, if this unit has stopped heating, this will confirm a major fault within the Magnetron. this device is responsible for the heating affect and, you will need to replace this damaged part in order to restore proper heating functions in you microwave oven.
Mar 03, 2009 | GE JVM1870 Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
GE JVM1440 Microwave Oven Logo
193 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
