Question about Delstar DS-802 Digital Media Player
Vista + mp4 = PROBLEM
I got this mp4 player for christmas, and I can't get my computer to recognize the device. I live with my friend and we share her computer, and she has Windows Vista (which I hate). I bought all of this music and downloaded it to my computer and can't get it on the player. Can anyone help me?
I have tried just plugging it in and the first time it said that it had downloaded all of the software needed, and then it wont read it. A message will pop up saying that the device has malfunctioned and that Windows can not read the device. Please help!
You need to go windows media player and go to sync. then drag all the music you riped to your library. the its just clik sync and wait for the files to download
Posted on Feb 10, 2008
2 Suggested Answers
SOURCE: Vista + mp4 player= not working! help
return the mp4
Posted on Mar 02, 2008
I have a Craig 1 GB MP4 Player, my windows vista will not recognize it. Is there any solutions to this?
Hi trueworddeli...
Try this solution to your problem
Go to Device Manager
To get to the Device Manager
Right click on MY COMPUTER> PROPERTIES> click the Hardware tab> Device Manager
Here you should see no "yellow" exclamation points.
If you do then it means that you have a device conflict.
If you currently have your unit plugged in, you may notice the "unknown device" which would be your MP3 Player
Click on any item that has the exclamation and remove it.
After you remove all devices with conflicts and then click on refresh, and you will search for your MP3 player.
If you MP3 Player is not there restart the computer and then go back to Device Manager.
The computer will have installed your MP3 player this time and recognize it..
Please take time to rate me
Sep 12, 2011 | Craig CMP168C MP3 Player
Hi, my pc don't read the mp34 audio player =( help!!!
Why is my mp3 and mp4 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see mp3 and mp4 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the mp3 and mp4 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: mp3 and mp4 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 and mp4 Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for mp3 and mp4 Players when used with Windows OS.
The mp3 and mp4 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
May 05, 2011 | Digital Audio NAP256 MP3 Player
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
4. Power issue.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
STEP 1 - Connect the Sansa player to the PC
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
Bought a VibeTech DCX 8GB nano MP3/MP4 player from a deals website for christmas. The unit comes with little documentation, a USB cable and headphones. Unfortunately the unit is not recognized by either...
XP and Vista probably won't recognize it without drivers installed for it, I would suggest trying it on a newer computer, something running Windows 8 or 10 should see it just fine. The older operating systems just arent that compatible with newer USB devices unless you have a driver to install for them first.
May 04, 2017 | Audio Players & Recorders
Hello, I'm having problems with my mp4 player
MP3 or MP4 player encounter "Drive inaccessible or corrupted and unreadable" are likely defective.
To be careful on it this mp4 player is memory damaged already.
I tell you, you can no longer use this one anymore because i have a lot of mp3 or mp4 with the same problems you have, i try to repair & open it and check the circuit, even the integrated circuit can no longer use.
I wanna say you a new one and don't wait this mp3 or mp4 player of yours are working back normally. Even I wanted to share to you about my knowledge on this but anybody would say "just buy a new one".
Hope this tip might help you my friend.
Please rate me.
Thank you.
Sep 14, 2009 | Audio Players & Recorders
My compaq/hp with windows vista basic O/S will not recognize video taken with samsung mx20 digital video camcorder. the cam' shoots video in mp4 format is there anywhere I can get a update for mp4 I assume...
the windows vista will not recognize usb camera devices so first you should have the driver installed and then try some other media players other than windows media player to play the imported video and i recomment vlc player
May 18, 2009 | Computers & Internet
Barbie MP# player installationg problem
I bought a new MP4 player with out manual and I am disabled how to operat it. Can you help me with my MP4 player? The code is MP4-GE-NE-005
Jan 09, 2009 | Audio Players & Recorders
I suggest finding a friend with an XP machine. Connect to that one, and if it works, it means Vista does not yet have the correct driver for this player. Dont expect a lot of success with video. Tons of people are not able to play video at all, eventhough it will download to the player fine.
Jan 23, 2008 | Delstar DS-802 Digital Media Player
Mp4 player
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Dec 26, 2007 | iLO (2 GB) MP3 Player
Delstar DS-802 Digital Media Player Logo
352 people viewed this question
Top Delstar Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Delstar Audio Player and Recorder Expert? Answer questions, earn points and help others
