Question about Whirlpool ET1FHTXM Top Freezer Refrigerator
Whirlpool Refrigerator not cooling properly
I have a Whirlpool Model ET1PHKXP03 It is not working properly. It will freeze the food in the freezer and then it will warm up and it thaws. It goes up and down. It has one one control unit in the Fridge area for both freezer and Fridge. I cleaned the coils of any dust thinking that might be part of the problem but that did not work in fact it seemed to make it worse.
I am thinking it is the thermostat or maybe the automatic defrost is bad.
If it has a computer board in it then that may be bad and then I will just replace the thing. Unit is about two years old
  • saif613 Mar 06, 2008
    when we switch on the refrigerator lights & fan getting work but
    there is no cooling , only the hotness will appear
  • chris aube May 11, 2010
    is the divider between the freezer and refrig. warm?
    New Friend:
  • 3 Answers
If the top of the freezer is hot and the bottom is cold the condenser is frozen/defroster is burned out. (most common problem, specially at 8 years.) Take the inside back panel from the freezer and check to see if the condenser is frozen over. In the bottom of the freezer is a quartz bulb that turns on every so often to melt the ice off the condenser. ($30 part) If the freezer top is cold and bottom is hot and the outside of the frig is very hot. The control board went bad and is not running the compressor/fan correctly. There are online sites that can tell you how to remove and test the board with an ohm meter. ($75) There is a fan behind the ice maker, but it is rare to go bad. There is usually 3 thermostats in the freezer. They are usually good for 20 years, and if they went bad, the frig usually wont run, but you can test them with an ohm meter. ($12 each)
Posted on Apr 19, 2017
    Top Expert:
  • Whirlpool Master
  • 81,423 Answers
I would try replacing the defrost timer and cleaning the condenser fins.
  • 159 Answers
SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Posted on Aug 10, 2007
  • 400 Answers
SOURCE: Whirlpool Top-Mount Refrigerator Freezer warm, cracking noise
8yr old? Buy a new one. The cracking sound is from expansion and contraction of the cabinet and ice cooling or defrosting. It can be as simple as a bit of a top up of refrigerant, but can also be that your compressor has worn down the valve plates and therefore is not producing sufficient pressure throught the system.
Posted on Mar 06, 2009
Sea Breeze
  • 4655 Answers
SOURCE: 3 YEAR OLD FRIDGE. DEFROST PROBLEM. FREEZER NOT
Your refrigerator has a defrost timer located inside the fresh food compartment if bad this will stop the defrost, I did not see a circuit bort for the model ED5FHEXMQ Make sure your model is correct because it will mislead any attemp to give help, Thanks, Sea breeze,
http://servicepartstec.blogspot.com/
Posted on Mar 27, 2009
watugot
  • 290 Answers
SOURCE: Foul rotting vegetable type odor in top of Kenmore refrigerator
If the icemaker motor or heater short out it will cause a foul odor. I have never heard it described as cooked broccoli, but it can be pretty bad. Remove the icemaker and inspect the bottom of it where the heater element is and remove the white cover of the motor and look in there. You can take the three screws out of the motor module and see if anything is burned on it.
If you can rule out the icemaker, the next things to check would be the evaporator fan motor and defrost heater. Generally, if a fan motor starts causing an odor it will stop running completely and if a defrost heater goes out it will quit defrosting. It is possible, but unlikely, that something has gotten into the evaporator area and is sitting on the defrost heater so that it is "cooking" during the defrost cycle.
Check the icemaker first, it is the most likely cause of the odor. Post back with complete model number if you need further assistance and we will go through checking everything else.
Posted on Oct 24, 2007
  • 18 Answers
SOURCE: whirlpool Model # GB2SHTXTS00 refrigerator not cooling.
Sounds like the defrost timer is not tracking the time properly. The unit needs to defrost once every 6-8 hrs. in order to work. Make sure the inside (evaporator) fan is running ok. If it rund for a few days and then warms up in the refrigerator section (coil iced), then the defrost timer is the culprit.
Posted on May 29, 2009
Purchased a Whirlpool Model w8TXNGFW0 Oct 2012. Food freezes on top shelf and freezer starts to thaw. Repair man said it will always do that because it was a less then $600 fridge and that's wha
talk with a lawyer and get a refund as the fridge is not fit for the purpose
if the statement is correct then 90% of units around $600.00 would not be working
Aug 27, 2017 | Whirlpool Refrigerators
My chest freezer (10 years old) won't freeze. Motor is running and the red indicator light remains on, but neither the amber or green lights are working.
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
Regards.
May 01, 2011 | Whirlpool 10 cu. ft. Chest Freezer...
My whirlpool chest freezer runs but does not freeze?
I hope this helps........
Best regards.
Apr 07, 2011 | Whirlpool Freezers
Keep a refrigerator/freezer in garage. The
Good day,
Yes. Domestic appliances will not work properly below approx 55 degrees.
The freezer suffers most simply because the machine runs rarely at 55 degrees and degrades as the temp goes lower.
They are designed to balance properly when in an environment where people live. Ideally 70 to 90 degrees Fahrenheit.
The machine is not broken.
Moving it inside, is the only solution.
Thank for using Fixya
Jan 02, 2010 | Frigidaire Freezers
Whirlpool conquest sibe by side GS6SHAXKQ01 freezer has defrosted and food is thawed
I have whirlpool conquest model GS6SHAXKQ01 - Came home to puddle of water, everything in freezer is melting, frig is getting warm. Lights come on both sides...Suggestions? Thanks
Sep 29, 2009 | Whirlpool GS6NBEXR Side by Side...
Thaw's. Turn-off for period of time it would freeze as normal
Make sure nothing is inhibiting air flow. I don't think it is advisable to store food in an ice machine however that is not likely the problem unless the food itself is inhibiting air flow. Most ice machine manufacturers recommend against storing any food in an ice machine. If there is a freezer component in you model the check to see if the evaporator coils are frosting up and the frost is blocking airflow causing the ice storage chamber to get warm. High humidity can cause frosting. Leaving a door to the ice maker open too long can cause frosting. A low refrigerant charge can do this although it seems logically like it should not. With a very slightly low charge one end of the evaporator gets super cold and the other end is not cold enough. Frosts starts collecting on the super cold end and accumulates across the evaporator coil to the other end eventually blocking all air flow. With too much humidity from open doors frost accumulates over the entire evaporator evenly but still blocks. You shut the unit down. It thaws out and works OK on restart until frost again builds up. If its not a frosting problem but it just stops making ice then the ice may not be releasing. Check the water supply and change any filters to insure good water flow. A good water supply is required for proper release and harvest of the ice in many ice machines. If the ice doesn't release it takes a shut down and thaw to clear the suspended ice out. Check for these things and write back if you need further assistance and can provide me with more details.
Jan 19, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Whirlpool ET1FHTXM Top Freezer Refrigerator Logo
552 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
