Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Install not working
It keeps saying that information was returned during the install and says i need to install other drivers but it is all not working, i have vista and the box says compatible with vista, but the install cd says xp- what do i need to do? return my product for another brand?
  • Anonymous Feb 18, 2008
    need driver to install 240c to windows vista
  • 832 Answers
Go to www.brother.com choose your country and your mfc and download latest vista drivers (read info, too).
Posted on Feb 20, 2008
HP laptop
The set up says it couldn't find the harddisk because you need to slip stream the harddisk driver into the windows xp cd where as in the normal setup cd's it is not present.
You need to download the SATA AHCI controller driver and slip stream it in to your windows xp setup ..
You can find the information in detail on how to slip stream from the website below:
http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/
I hope the information helped you
Regards
-Dileep
Nov 20, 2011 | Computers & Internet
Can't return from standby mode. the vga, sound,
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
May 31, 2011 | Computers & Internet
When installing numark dj io during installation it always says unfortunately the installation failed. (Error: Timeout - 0x0005)
check all usb connections, with any other device like pen drive, if pen drive is working perfectly , then go to " control panal" go to "add or remove programme " and uninstall any " ASIO drivers or softwares" . and restart the PC and install the device and software, drivers as told in the product manual.
if still have problem - change the RAM of your PC,
best of luck and KEEP SMILING .aaarwind
Jan 14, 2011 | Numark DJ/iO Sound Card
My pavillion dv7 webcam stopped working. it says i need to turn on camera. i can't find any information that works. i see no quickplay program on my notebook. do you have any suggestions.
Windows Vista and 7 ( can't remember about XP ) come with native drivers for the webcam so it may be a problem with these. You could try running a system file check by browsing to all programs, accessories, right click on the Command Prompt and select 'Run as Administrator'. Type in the following command and hit return. sfc / scannow
If that doesnt work download and install the software driver for your webcam on the link below.http://www.downloadsource.net/d16952/HP-Pavilion-Webcam-Driver-Windows-Vista-x32-x64/ i hope this works for you.
Dec 16, 2010 | Computers & Internet
System says there is no hard drive. error code 0142 says hard drive error
This is what the manual says:
Replacing the Hard Drive caution.gif CAUTION: Before working inside your computer, read the safety information that shipped with your computer. For additional safety best practices information, see the Regulatory Compliance Homepage at www.dell.com/regulatory_compliance. notice.gif NOTICE: Hard drives are extremely fragile. Exercise care when handling the hard drive. notice.gif NOTICE: Use firm and even pressure to slide the hard drive into place. Excessive force may result in damage to the connector. This procedure assumes that you have completed the removal procedure Removing the Hard Drive.
  1. Slide the hard drive into the hard drive connector until the drive is fully seated.
  2. Replace the hard drive cover aligning the notches.
  3. Replace the two M2.5 x 8-mm screws to secure the cover.
  4. Install the operating system for your computer, as needed. For information on reinstalling the operating system, see the Setup and Quick Reference Guide for your computer on support.dell.com.
  5. Install the drivers and utilities for your computer, as needed. For information on reinstalling drivers and utilities, see the Setup and Quick Reference Guide for your computer on support.dell.com.
I would say that was a bit harsh and this is what I would do.
Insert your System disk and install a fresh system. During the installation, Windows should be clever enough to detect and format the drive.
If you remove the drive and with a caddy you could try to repair the system with another pc but you may get problems.
Hope this helps.
Nov 04, 2010 | Dell Vostro 2510 Laptop
BSOD keeps on flashing during installation of Win XP
I think the problem is with your RAM installed, try to swap other memory on your computer or try your RAM to other PC to determine if its working.
Jul 11, 2010 | Asrock P4VM8 Motherboard
Hello I am unable to get my HP all in one printer working? it will copy a page for me, but I cannot print anything/
Did you plug in the printer before you installed the drivers from your installation CD? If not, you need to uninstall the hp printer drivers and unplug the usb cord from the computer.
Restart your computer, run the installation cd, and then after the HP installation says it's complete then plug the usb cable into your computer. NOTE: Some HP driver installations ask you during the install to plug in your printer so the software can find it. If thats what happens then only plug in your printers usb cable when the installation software tells you to. Once it detects your printer the installation will continue. Make sure you keep hitting next or continue until the software tells you everything is installed. Now your all in one printer should work.
Wilcocoop
Dec 09, 2008 | Office Equipment & Supplies
OS load failure.
The bluescreen saying about the ACPI, I had the same problem at work with a older computer. Next time you get the bluescreen read everything it says.
It tells you to press a button, I'm not sure thats why I'm telling you to read the bluescreen (windows 2000 or xp) it was f5 or f8.
You press f5 or f8 I think it was f5 since f6 is to load custom drivers.
So you press f5 when it asks you to press f6 This disables the ACPI subsystem in the setup and you should be able to install windows 2000 without any more problems. If its not f5 read the bluescreen thats where I got it!
Good luck, keep me posted and tell me if theres anything else.
Feb 23, 2008 | Toshiba Satellite A65-S1065 Notebook
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
41 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
