Question about Daewoo DVRS04 DVD Recorder/VCR
Dvd's get stuck and unit is hot
Hi, I have had the DVRS04 for a few months. I can play a new DVD (bot a dvd copy) for about 1 hour and 15 minutes or so then the picture freezes up. I can't find whether progressive scan is on or not or if that's the problem. I notice when it freezes and I remove the dvd, the dvd is hot to the touch (and so is the player).
  • QowboyVern Feb 06, 2008
    huh? - I plugged the DVD recorder into AC power - what do you mean by power pcb - and filter electrolites? those aren't mentioned in the manual...
  • punchbuggy27 Jun 23, 2008
    I have been having the same problem, but it seems to happen only when the DVD is from Netflix. The DVD won't play at all, and is hot to the touch.
  • 106 Answers
Your dc voltage on power pcb is wrong.,replace all filter elctrolites
Posted on Feb 06, 2008
  • sasa beljin Feb 07, 2008
    that stuff mentioned in service mannual,call serviceman you need him
Hi I have a 1 to 15 CD DVD Systor SATA 20x Duplicator Burner Copier System who buys 5 months ago, but now when I turn the machine on but the display controller is lit but I do not see the menu, I can not...
sounds like you may have a loose connection on some of your drives i would open it up and check it out. also if it has a usb interface you can re download the firmware for this. you may wanna try and unplug it for a few minutes to refresh the system. let me know if tghat helps that what i found when i did research on your issue for you.
Mar 15, 2011 | SySTOR Systems 111 Target SATA Standalone...
Dvd get stuck 1 hour into film
There MAY be contamination of dust on the lead screw that moves the head. Be VERY careful cleaning as the head is suspended on flexures that are moved for the fine movement necessary to follow the tracks on the disk.
You might want to take this in to a repair shop and see if they can clean it.
Replacing the drive would likely cost the better part of the original cost of the whole unit.
Dec 13, 2009 | Sony RDR-VX555
Panasonic DMR-E55 doesn't play dvds
if its getting worse, could be the laser is on the way out.get a new one (player)
Oct 03, 2009 | Televison & Video
My remote control cannot work on rewind, fast forward or comerical skip. The DVD screen display SET 1.
Hello, I had the same problem and after spending a few hours reading and trying things, I found a solution. Its very simple. Power on your unit (manually) and then on your remote control push and hold at the same time"enter" and the number "1" while pointing directly to your unit and this should solve the problem. Good luck.
May 16, 2009 | Panasonic DMRES15 DVD Recorder
After approx 1/2 hour of play the movie gets stuck for few seconds, plays again for 2-10 seconds, then permanently gets stuck. Sometimes a smack to the machine works, ff does not work....we usually just...
Smacking the machine is a good way to destroy the DVD lens. Get a CD/DVD lens cleaner and make sure there aren't any marks on the disk. Dirt & smudges cause about 75% of all CD/DVD player problems.
Feb 27, 2009 | Toshiba SD-2150 DVD Player
Dvd does not play
Three problems - the Media Converter will not correctly convert videos over 15 minutes long, it will not recognize the DVD's file structure, and it cannot play copyright-encrypted video files. This player is more for YouTube-style videos. Here is a workaround:
1) Use video editing software to break the DVD file into 15-minute chunks
2) Run the chunks through Riva FLV Encoder - convert it to AVI format, and make sure sound is enabled
3) Run the Riva-converted chunks through the Philips Media Converter
4) You can now watch your movie in 15-minute chunks - I hope you chose filenames that allow the files to be played in sequential order
Have fun!
-Tha Mp3 Doctor
Dec 26, 2008 | Philips GoGear SA3245/37 Digital Media...
Green screen
I had the same problem, my TV had two SCART inputs - when plugged into one the DVD played green, when plugged into the other, it played normally. Have you tried this?
Oct 22, 2008 | Daewoo DVRS04 DVD Recorder/VCR
How can I record from the vcr to the dvd
on a combo unit ,insert the vcr tape and then put a blank dvd r /rw in to unit , you should then press rec button and records to dvd.
note you cant copy proteceted tapes due to the macrovision
Mar 25, 2008 | Daewoo DVRS04 DVD Recorder/VCR
DVD/VCR Locked
My DVD/VCR Daewoo locked and everytime i pressed a button it just said LOCK! I plugged off the vcr for a few hours and then plugged it back in and pressed the on button. Now im watching the dvd that was stuck inside. Try it, you just never know.
Nov 19, 2007 | Daewoo DVRS04 DVD Recorder/VCR
Daewoo DVRS04 DVD Recorder/VCR Logo
63 people viewed this question
Top Daewoo Televison & Video Experts
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
