Question about Refrigerators
I have ice forming in my frig compartment
Kenmore frig, about 6 yrs old
  • Anonymous Feb 07, 2008
    the teperture in my frig is 38 degrees, the ice is coming out of the vent from the freezer.where the cold air enters the frig, ice is coming with it.
  • 66 Answers
Thrmosstate in your fridge is no good. replace it.
Posted on Feb 06, 2008
Frig & freezer not cooling enough. Ice forming in back of bottom freezer.
You need to have the defrost cycle checked.( heater, limit stat, timer) If the frig can't defrost air can't move across your coils to cool properly. To temporarily get by until you can get a repairman, use a blow dryer to melt the ice build up. Once melted it will work normally for about 2 days till it freezes up again.
Nov 13, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
Upper portion (frig not cooling properly) Lower portion (freezer) forming ice on #3 setting.
Is it forming ice or frost? It sounds like an automatic defrost problem. If the freezer frosts up it won't circulate enough air up to the fresh food compartment. Try defrosting it manually for 24 hours by shutting it down and leaving the freezer door open. Afterwards, if it resumes normal operation I would bet that there is something faulty in the defrost circuit, i.e., defrost heater not working or defrost control.
Feb 23, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer is icing up. Unit is about 2 yrs old
You need to check out the back of the freezer. At the current status, it may be locked with ice. Have it defrosted or just have it melted away. Clean the coils and the entire unit. Either the drains were blocked by food debris or dirt causing water to accumulate and ice to form or the thermistor has been iced or is faulty or too much ice accumulated in the unit's coils.
Oct 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE frig/freezer side by side about 5 yrs
Bad defrost timer, most likely. It is not defrosting the evaporator, and therefore, no air can be passed over it. Hope this helps
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water in fridge
First, empty freezer and fridge. Unplug and leave door open for at least 3-4 hours. Blow out drain lines with compressed air. It is more likely that the drain line is clogged than frozen; but a clogged drain line will freeze-up quickly.
Aug 08, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Sheet of ice forms on bottom of freezer
Your defrost heater assembly has probably failed. Look at the ends of the heater for darkness like that of a bad neon bulb. Replace the heater assembly as a unit after removing the ice with a hair dryer. Becareful not to drop the glass heaters when replacing.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 19, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
