Question about Refrigerators
Noisy refrigerator compressor (?)
Whirlpool top freezer refrigerator makes a loud clanging noise, 2-4 beats, when shutting down. Less than 10 yrs. old. Cools fine. If this is a compressor noise, is there any way to tell how long the fridge will last or if it will just die without warning?
  • 1 more comment
  • Anonymous Feb 08, 2008
    there is a noise problem in the forst free refrigerator in whirpool . when it strat in the 10 mintues the noise is slowley comes, and then increease the noise. when it swicth off for half an hour. then start the fridge the noise is not come. after one hour the noise is come. what is the reason. if arrest the noise use paper in the backside of the fridge that means the compressor and the spring the paper use it is correct or not.
  • Anonymous Apr 04, 2009
    The compressor sounds like it's vibrating and when it shuts down it clunks. The fridge and freezer work fine.
  • Anonymous Mar 29, 2014
    Diagram for compressor of whirlpool refrigerator
  • 281 Answers
This is a compressor problem, and chances are there for this to worsen if not attended promptly.
Posted on Feb 06, 2008
Makes a clanging noise when it stops running
it has to be the compressor and has come loose on its rubber mounts and as the motor stops the internals of the compressor strike the side of the compressor body and produce this noise,tighten the rubber mounts on that compressor and it should be fine
Mar 30, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
The paperwork that you received at the time of purchase should list a telephone number to call for warranty service. This problem should be covered under your warranty.
Apr 14, 2010 | Whirlpool 17.6 cu. ft. Top Freezer...
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
My Whirlpool refrigerator makes a loud groaning cough noise when it turns off. Is it near the end?
the compressor is pushing a lot of pressure. when it shuts off sometimes the pressure forces the compressor to roll backwards and make a pressure release noise. I've known some to do that for years.
Jun 08, 2009 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
A three loud consecutive popping sounds at various
You probably have a bad compressor. It's internal parts are held up with 4 springs and one of them has probably broken and causes the compressor piston to hit the side of the comp. housing. This will happen when the ref. shuts off. To be sure, if you turn the ref off at the controls then you should hear the noise in the back. If it is less than 5 years old you can get it replaced under warranty. if more than 5 years old it will just be noisy. it will most likely last several more years like it is. Let me know if I'm right.
Apr 01, 2009 | Frigidaire FRT21H8 Top Freezer...
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
Whirlpool Top-Mount Refrigerator Freezer warm, cracking noise
8yr old? Buy a new one. The cracking sound is from expansion and contraction of the cabinet and ice cooling or defrosting. It can be as simple as a bit of a top up of refrigerant, but can also be that your compressor has worn down the valve plates and therefore is not producing sufficient pressure throught the system.
Mar 06, 2009 | Whirlpool ET1FTTXK Top Freezer...
Whirlpool Gold Fridge w/ freezer on top. LOUD banging noises.
I think the banging means the compressor is shot. (more like a load "clunk"). I had the same noise on a dehumifier.) I dont' think replacing a compressor is a DIY, and doubt it is economically efficient. But I leave that to the specialists to comment on. Check Craig's List in your area - you can get a good deal for a few hundred bucks.
Also, the "clanging noices" is probably the fan blades for the air circulator that moves cold air from the freezer to refrig compartment. Check the online manual for your model (exploded parts view) to see where it is located and if it is readily accessible by taking out a few screws inside the refrigerator. Might be more than one fan - open the door when it happens and see if you can locate where the noice is coming from. This is a plausible DIY - I did it only my old fridge - replacement parts were cheap. But you might even be able to just reallign the fan blades so they don't clang.
Oct 26, 2008 | Refrigerators
Whirlpoor Refridgerator 10-12 yrs old
I had a whirlpool fridge that did the exact same thing. Sometimes it was loud enough to wake me up at night! It is the compressor shutting down. I had it for several years untill I purchased a larger one, and then gave it to a girlfriend at least a year ago. Its still working good today. So if you can tollerate it, just live with it. Otherwise change the compressor.
Jan 04, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Refrigerators Logo
1,990 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
