Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door hard to close have starts to close stops and starts to open again have to keep stopping and reversing door mult times to get closed
  • CRAFTSMAN
  • Garage Door Opener
  • Model# 13953635SRT
    I have the above door with the safety beams. The date of manf. is 1994. works for the most part fine, but lately we have to keep pressing opener to get closed and the sesor beems are not interupted. I even cleaned the lenses. So basically what is happening is that the door starts to close and then stops and reverses as if the beam was broken. I have to catch it with opener and reverse to closing again and it starts closing then catches again and keep this up till finally get down. Sometimes it happens at 3 or 4 spots and sometimes less. I don't have a manual as it was in when i bought the house. Is there a programing issue or something and where if anywhere is this manual available on line. Please help in anyone has any ideas. Hoping this is small fix.
    Thanks Titus
  • Posted by on
    • I try Apr 25, 2008
      I have exactly the same problem . I tried adjusting the two side screws for tension to no avail.
    • Anonymous Apr 25, 2008
      I have the same problem and am now going tocheck all the wiring. It seems the electrical circut must be breaking as it works then stops then works for a day or two then does it again. If I knew what was wrong I would replace the entire thing. I called a door company who came out an said it was the springsw which cost me $700. The thing was that the power went out just before they came and back on after they left with the same problem. So if anyone knows the answer please let us know before some outfit replaces my garage.
    • 589 Answers
    There should be two small white adjustment knobs on the side of the unit that you turn with a small flathead screwdriver. These are the load / limit adjusters.
    What it happening is it think there is something stuck under the door (like a car hood, etc)
    These adjustments are VERY sensitive, so be patient while adjusting them.
    Posted on Feb 11, 2008
    My Craftsman garage door will not close, only a few inches at a time
    have a problem which returns every year when outdoor temperatures drop close to freezing. garage door will open only a few inches, then stops. I can close it and try opening it again... same result. After five or six such attempts it typically will open. Interestingly, when I push the switch button mounted on the interior wall of my garage and keep it pushed, the door will open, until I release the button at which point it stops opening.
    Dec 19, 2013 | Building Materials
    Erratic garage door opener
    It is an adjustment problem. Any obstruction and the door goes up again. So try adjusting again but don't leave space to invite rodents that will cause damage to car wiring. I am just going thru that.
    Dec 04, 2013 | Craftsman Sears Liftmaster Garage Door...
    I have two craftsman door openers. They work great with pushbutton on wall, open and close ok. The door opens fine with remotes ( one handheld other homelink in car ) but will not close with remote. It...
    If the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Make sure the lights on the sensors are both on and not flickering. Tweak them if necessary. If you cannot get both lights to come on you have bad sensors or the wiring to them.
    Dec 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
    The garage door closes and then opens up again, I have to close it several times before it secures. There are no obstructions. Is this a sensitivity problem?
    More than one thing can cause this type problem.
    If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is not flickering ever so slightly.
    If the door reverses when it hits the floor it is a sign that the door is traveling a bit to far. The adjustment for this is on the side of the motor unit. Turn the 'down limit' in the opposite direction of the arrow printed on the cover. Some tweaking will probably be necessary.
    Jul 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
    My Sears Craftman garage door opener closes about 1/3,stops,and reverses.When I activate the remote again it stops rising,starts down again, comes down another foot or so,stops,reverses etc.,etc,etc It...
    If the main light is flashing 10 times when the door reverses it is a door sensor problem. One may have been bumped so that they no longer point at one another. Make sure the small light on each sensor is lit and not flickering. If this isn't the case you might need to increase the down force a little. The control is on the back panel near where all those white wires go. Increase it about 1/4 turn and try.
    Dec 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Garage door only opens 4 inches then reverses and stops
    you need to replace gear when the door is fully closed. then do your tweaking.
    Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
    My craftsman garage door is about 8 years old. It
    Make a slight adjustment to the Upward force on the side of the machine. Turn the screw a 1/4 turn each time and test, see if that helps. Also, make sure there are no obstructions or friction when the door opens and closes. Try it manually first.
    Feb 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
    CRAFTSMAN GARAGE DOOR OPENER PROBLEM
    i have a garage door opener craftman 1/2 hp model 13953985 the light is flashing 10 times . now you have too hold down on the button to raise and lower .
    Feb 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Garage Door Opener Intermittingly Reversing
    try adjusted the sensor controls on the sode of the unit other wise replace the logic board
    http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
    Dec 24, 2007 | Sears Craftsman LiftMaster Chamberlain...
    Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
    994 people viewed this question
    Top Sears Building Materials Experts
    Glenn Mayer
    Glenn Mayer
    Mike
    Are you a Sears Building Material Expert? Answer questions, earn points and help others
