Question about Dryers
Whirlpool dryer drum
Drum quit moving. I still have heat and air.
New belt?
Posted on Feb 06, 2008
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
Where is the igniter located on dryer
An easy answer: gas (natural gas) dryers have igniters, but your electric dryer has no igniter,
instead it has a heating element (a zigzag arrangement of wires similar to that found in a space heater). Remove the back of the dryer - the heating element will be enclosed in an air duct that feeds heated air into the drum via a vent at the top back of the drum.
If you look into the drum, you can see the vent cover that covers the heated air inlet at the top back of the drum.
Sep 12, 2011 | Whirlpool LER4634J Electric Dryer
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
DRUM NOT MOVING ON WHIRLPOOL ELEC DRYER
the belt is off or broken, changing the belt yourself can be tricky, you must remove the front bulkhead and door/panel assy, then you have to route the belt correctly from th motor to the belt tensioner, you may want to call a tech.
Jan 06, 2010 | Whirlpool LER5636P Electric Dryer
My whirlpool gas dryer makes a screaching noise turns off
your drum glides/rollers are defective on the front edge of dryer where the drum rests,sounds most like the glides are glazed,not roller bearings but check it could be either
Nov 02, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Overheats and sets clothes on FIRE
sounds as if your experiencing an air flow issue, check your venting.. it would be normal to see a red glow from the right side vents with in the drum( its heating up after all, and its merely a reflection form the heater located on bottom of frame, no way its gonna heat entire drum to "red hot")
Dec 24, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Cabrio electric dryer
ctwoods, this sounds like the heating element has shorted to the heater can. What that is doing is leaving the element at 1/2 power on all the time. If this happened, then the heat kept going up until it blew the thermal fuse which caused the motor not to run. So check the heater and any fuses in the dryer. You can go to Service Matters for Whirlpool Service Manuals on this model.
Feb 03, 2008 | Dryers
Dryers Logo
64 people viewed this question
Top Dryers Experts
Marvin
Marvin
