Hold the power button down for 5 seconds. This will perform a soft reset which simulates pulling the battery out on devices that have non-removable batteries.
Depends what's causing it! Does the whole screen freeze or just the text?
It can happen if you have too many programs open and you do not have enough memory for the computer to do everything.
Does it always/often happen, and what are you doing when it happens?
defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If the phone displays the message "PHONE FREEZE. SIM UNAVAILABLE PLEASE CONTACT YOUR SERVICE PROVIDER" then your phone has got hard locked. You need to unfreeze the phone to get unlocked. You can get the unfreeze code, unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website TheUnlockSpot.com which is doing good service .....you can approach this website.
Generally, if a device is froze, you can remove the power to the device to reset it. What type of device are you trying to unfreeze and please tell me what happened before the device froze so I can help you figure out this problem.
if you can still hear sound then you might of accidentlly hit a button on the remote. some tvs offer closed caption1 closed caption 2 and text 1 and text 2. And if it is set to text 1 or 2 it causes the screen to go black.hope this helps!! Good Luck
