Question about Uniden Cordless Phone
Model 27851GE1-B Even when I change channels I get terrible reception on this phone. And any messages that are left on the answering machine have so much static that it's impossible to tell what the caller said.
  • 1 more comment
  • Anonymous Mar 26, 2008
    static on answering machine and phone.
  • Anonymous Apr 25, 2008
    terrible sound quality!
  • JANE A Apr 25, 2009
    can not remember how to change the message on the answering machine
Hello I lost the manual model 27851ge1-b is not using it and I can not get off the internet
Posted on Jun 19, 2008
My Cordless set always gives an indication as low battery. Its pretty now one. What is the check list to correct this problem and how can I fix it?
Posted on Apr 04, 2008
Ge 27851ge1 b
During a call, press the CHAN/delete button on the handset (bottom left corner of the keypad). If you need a manual, you may download a copy at http://www.home-electronics.net/USER-GUIDES/27851_DOM_EN_CL_IB.pdf
Jul 12, 2013 | Lands Phones
Tip
I am not able to get messages recorded on my GE phone (model 27851GE1-B)....
Bought GE phone, 2 years later, will not record. My Tip is buy from a reputable company like one in Japan, big US corporations are in it for the stock and most products do not last, or require a expensive warranty. GE does not bring good things to life... but that is just a personal opinion.
on Jul 17, 2008 | GE 27958GE1 Cordless Phone
Ricoh fax 120 please let me know how to put ricoh on automatic fax receiving while not in the office also when someone rings i can hear the fax sound from my ricoh
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} - Follow the next instructions to change the reception mode :
1. Press the [F2] key. “ this key is located on the left side of the Control Panel next to the key [12] from the left side and next to the [Memory Trans.] key from the rigt side ”
2. Press the left arrow key to select the reception mode “ this key is located under the Display of the Control Panel”
3. Press the [OK] key when on the display is displayed the mode you want.
note:as you sad you want the machine to reaceive faxes when you are out of the office, so the reception mode [Auto Select] is the most compaible mode for you.
The machine can treat incoming fax
messages and telephone calls in three
ways.
1.Manual Receive
- Use this mode if your line is shared
by a fax machine and a telephone
but you wish to answer all calls
yourself and decide whether they
are fax documents or telephone
calls. You must manually press the
[Start] key to receive a fax.
The machine will ring continuously
until you answer the call, so you
have to be near the machine at all
times. The Manual Receive indicator
is lit when the machine is in this
mode.
2. Auto Receive
- Use this mode if you have a dedicated
fax line. The machine assumes
all calls are fax documents.
It will ring once to alert you of an
incoming call, and then starts receiving.
3. Auto Select
- In this mode, the machine rings a
number of times. You can answer
the call while the machine is ringing.
If you do not answer the call,
the machine automatically changes
to receive fax messages.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
Static interference on Uniden 5.8Ghz phone
i have a uniden 5.8 ghz cordeless and thought it was a piece of junk as well. I had static or lapse of audio near the router, the kitchen sink, the microwave (even when off) and in the doorway. I switched the frequency on the router and changed the channels on the phones all with no luck. Short of steering clear of my entire downstairs nothing worked.
Just about ready to buy a new phone and hit up google. Saw a posting that said to keep the base away from even the tv. . .hmmm this is exactly where mine was located. So I swapped the digital answering machine base and moved it downstairs and put the additional base near my flat screen. Guess what? Problem SOLVED! I still cannot believe it.
Hope this helps
Apr 13, 2009 | Uniden 5.8GHz Dual Cordless Phone
Need to shorten the amount of rings before it answers.
http://www.home-electronics.net/ge/pc/IB/27851GE1_IB.pdf
Dec 09, 2008 | GE 28112EE2 Digital Answering Machine
MODEL 27851ge1-B
Press and hold the "Skip" key to change language.
Press the "Review" key to get directions how to use the machine.
Aug 04, 2008 | Uniden Cordless Phone
FAX, MODEL 920 NOT RECEIVING
Try calling your fax machine from a cell phone. If the fax doesen't answer, or if the line is busy, the phone line may be bad. Also check that the phone line to the fax is plugged into the receptical marked LINE, not PHONE. The PHONE receptical is to connect a telephone to the fax machine. If it still does not answer, try going into the fax menu and go to RECEIVE settngs. Try changing each setting, then call the fax with the cell to see if it answers. Write down each setting before you change it, so you can set it back if changing it does not solve the problem.
Jul 10, 2008 | HP 920 Plain Paper Fax
Language
Please help me change my language from spanish to english.We have tried unplugging the phone to taking out the batteries,nothing has helped.Also when we answer the phone it spmetimes has so much static on it that we can't hear,we have to hang up or move to another area.We have a model # 27851GE1-B.I really don't think that I will ever buy another GE telephone.Also I have misplaced my user manual.
Please Help!
Thanks
Sweettooth
Jun 24, 2008 | Uniden Cordless Phone
Language Change for model 27851GE1-B
press and hold skip button for 2 seconds. this will change language on machine
Mar 20, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
515 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
