Question about Motorola Mobility A768i Cellular Phone
Touch Screen Not Working
When i switch on the phone,it works normally,but as soon as i touch the screen with anything,it starts vibrating endlessly after 3 seconds and i am left with no other option but to remove the battery.Please help me out
When i switch on the phone,it works normally,but as soon as i touch the screen the phone freezes... i have to remove the battery to switch it off..
Posted on Mar 23, 2008
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
The calibration on my samsung impression was way off so i used the unlck code *2767*3855# the phone shut down and restarted and at the calibration screen tapped the center of cross many many times cross...
OK..your touch screen was jammed or not working and you did reset via code *2767*3855# then the phone restarted with the calibration cross....you tapped the cross but nothing is happening.......what to do? first shutdown the phone remove the battery for 30 sec also remove the simcard put the battery again start the phone when the calibration screen pops up tap on the cross here you must feel the tapping is working by feeling a light vibration of the phone.....then tap on the lower bar of the screen which has color (light gray) different than the calibration screen the cross will move to another corner......repeat this for all four corners then you should see and OK on the bar to save and exit to the normal screen........done
Jan 03, 2011 | Samsung SGH-A877 Impression Cell Phone
My buttons on my phone works but my touch screen is not responding to anything at all.
check MENU settings may be touchscreen is off ,else touchscreen loop is broken
Aug 02, 2010 | Cell Phones
Whenever i turn my phone on the screen is just black. i can accept phone calls and the touch screen responds when i touch it but i cant see anything.
Hi,the screen of the phone is bad is not together with the touch screen.The screen is located at the back of the touch screen.The touch screen is working fine as you said.
Ones you replace screen, phone will work as normal again.
Take nice.
Jul 02, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
Touch screen stopped working
my touch screen stoped working i can still use all keys also i feel vibrate when touch the screen
helppp
Mar 07, 2010 | Samsung Tocco Ultra Cell Phone
Touch Screen is not working
Since this is the case you may need to soft reset the phone.
The touch screens normally give problems whenever there is a little pressure applied to its surface e.g when you don't use a pouch but place the phone in a tight jeans pocket and thus will need,screen reallignment.As you may already know.
Now your phone has a soft reset function...try it! Or turn it off,remove the battery (not immediately! so you don't loose your settings then re-insert it after 25 secs.) and do a restart. This should allow you access the screen allignment settings so that you could fix your screen.
Hope this helps.
Sep 23, 2009 | HTC XV6900 Cell Phone
Touch screen inoperative, buttons work
Hello
I have the same problems on my iTouch as well, here is what i do:
  • Restart the app
  • Reinstall it
  • Search for a newer version
Make sure u have the latest ipod touch firmware ;)
Feb 12, 2009 | Apple iPhone Smartphone
Motorola Mobility A768i Cellular Phone Logo
51 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
