Question about NEC LCD1712 17" Flat Panel LCD Monitor
NEC LCD1712 monitor works with laptop but not either one of my 2 desktops
This problem started a while ago, my normal desktop would only send a signal to the monitor occasionally and it was diagnosed to be the mother board. Ok fine, so I plug the LCD monitor into the laptop and it works. I get another desktop - dell optiplex GX 270, was working on another monitor - but plugged it into the LCD and it will not send a signal to my LCD. What the &%$# ! ! !
  • 3711 Feb 17, 2008
    i unable to switch to nec monitor from my latop
4 Suggested Answers
  • 286 Answers
SOURCE: NEC LCD1712 Problem
Please try your monitor on a friends computer.
This is a very odd problem so you should make sure it's being caused by the monitor.
If it is the monitor, it's a tough one. It could be a bad main board, or a bad LCD panel.
I would check your warranty status. It sounds like it may need to have the signals checked on the board to determine which of the two parts are causing the problem.
Posted on Mar 28, 2008
mail2pvs
  • 390 Answers
SOURCE: Distorted shrunken picture
hi
reduce the resolution to a bit lower and the refresh rate to a nominal 60hz and things should get back to normal
my hunch is u r using a slightly high resolution and refresh rates
but before that try the buttons on the monitor to see if expanding the image sideways or top and bottom would help initially
cheers
pls rate if this was any help
Posted on Jul 13, 2009
  • 95 Answers
SOURCE: Video input: 2 D-sub No signal /Video input 1 DVI-D No signal
Below is a link that may help you...Good luck http://www.techspot.com/vb/all/windows/t-35070-DVI-to-DVI--No-Signal-on-LCD.html
Posted on Apr 06, 2010
Why did my screen turn light blue lcd1712 ?
Please try to connect your computer to a different monitor. It may be that you're experiencing the notorious "blue screen of death", but you will be able to determine whether that's the case by trying another monitor. Please keep me posted. Thanks!
Aug 06, 2014 | NEC LCD1712 17" Flat Panel LCD Monitor
How do i factory reset my NEC LCD1712 Monitor?
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 22, 2014 | NEC LCD1712 17" Flat Panel LCD Monitor
Why is my monitor not displaying past start-up and how can I fix it?
You say that the problem occurs when you connect your secondary monitor up either solely, or as primary, but it also occurs when you have only the primary monitor connected Therefore I think the problem is inside your computer box not the monitor or cables.
I'd try another graphics card (the specs I have say the default the graphics is 1024MB NVIDIA GeForce GT220, but then they also say Win 7 Prof - http://www.pc-site.co.uk/reviews/dell-business/dell-vostro-230-mini-tower-desktop-review), either to the built in one (if your m/b has on-board graphics facility), or a different card (which may be the same model). Have a look in the BIOS too.
14.May.214
May 14, 2014 | NEC LCD1712 17" Flat Panel LCD Monitor
My vs19 monitor will not come on. says vga input/ no input signals and then goes to sleep. I checked all connections and all are ok. Happened about 2 months ago but has worked fine since. Is there a way...
It's not your monitor. It's your computer.
If you see a display on the monitor, it means it's working. (and you do)
Your computer is not sending a signal to the monitor. If you are working with a laptop, you can just press the Fn key/special function key combo to send the signal to the external monitor.
If you are using a desktop, then you need to do some troubleshooting.
Jun 03, 2011 | HP Computers & Internet
LCD1712 does not come, unplugged and still nothing. Power light on front is orange not green>>any ideas
Need to open up and check to see if do have 5v and 12v in the power supply, check for bad caps also. See example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 16, 2010 | NEC LCD1712 17" Flat Panel LCD Monitor
Cant connect to laptop (only shows desktop no playback)
if u r connecting a laptop to an external monitor...just connect the monitor cable to the monitor jack in the laptop and u need to make changes to the display in the control panel...
Control Panel/Display/Setting tab/Advanced/Monitor or Display Tab...there u will get the choice to send the signal to either the monitor or laptop display...
chose and freez the choice....
Dec 14, 2009 | NEC MultiSync FE700 17" CRT Monitor
NEC MultiSync LCD1770NX 17" LCD Desktop Monitor
components starting to fail. unrepairable. buy a new one
Oct 21, 2017 | NEC MultiSync LCD1770NX (Black) (Black,...
NEC LCD1712 Problem
Mar 27, 2008 | NEC LCD1712 17" Flat Panel LCD Monitor
NEC MONITOR 1700M+
Hello there !
First things Frist:
1) Test the switching on keyboard for external monitor and see if work, or you disable the laptop monitor.
2) install the driver for select external monitor. depending the video card, you may have 2 display panels, to select, on that driver. NVIDIA or RADEON
Mar 07, 2008 | Computers & Internet
White out
Take the monitor back where you bought it from.
Sounds like the main board or the LCD panel have gone bad.
Dec 25, 2007 | NEC LCD1712 17" Flat Panel LCD Monitor
NEC LCD1712 17" Flat Panel LCD Monitor Logo
41 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
