Question about Canon CLC 1120 Color Copier
Error Code 0181
I Can't seem to find what this error code means. There is also the E020 as well.
Thanks!
  • Canon Expert
  • 1,326 Answers
I did not see that error code on Canons web site. It may have something to do with the laser or a pinched wire with one of the lasers. Also, which color is giving you a E020 code? It may have something to do with the other.
Posted on Feb 07, 2008
  • 86 Answers
I know what this problem is phone me on 07764303923
Posted on Feb 14, 2008
  • philip davies Feb 19, 2008
    EO20-0181 = magenta developer toner level faulty you can reset it but you have to check the black density sensor is not soiled and there is no toner scattering inside the machine. If you need more help please get back to me i am in the uk 00447764303923
Error code E 020 0181 How do I clear error code? Cannon 1150 color laser copier
Hi
Error code E 020 0181 means that the patch sensor has turned bad or is dirty, to access this try removing eac dev unit and gently unscrew each top so that the patch sensor window is visible. Also, check whether the toner hopper is overfull, it happens sometimes that the toner motor worm gear splits as a result of the hopper becoming packed tight. This may cause the worm gear to split and break if the hopper is 1/2 full or less. You may need to replace toner motor, part number (FH7-1762-030). If the toner motor is fine, then check whether the web solenoid is activating. Clean the web solenoid and ensure free action. This would clear error E020. If the error still not disappears then make sure that the DC controller is fine and the connections from the controller are fine.
Hope this helps...
Daniel
Oct 11, 2010 | Canon CLC 1150 Color Copier
Please help e0020-00ff black toner supply????? comes and goes
Check for blockage in toner supply ,located at rear of hopper. Also is the toner ok
Jun 26, 2010 | Canon imageRUNNER C6800 Copier
Error
CLC1150 problem code E020 0181
what is this? The machine has been off/on and we also this problem
info@setobemmel.nl
Jan 31, 2010 | Canon CLC 1150 Color Copier
E020 01BO What does this error code mean?
E020 indicates a Black Toner malfunction. If you've recently changed the toner and failed to distribute the toner by gently shaking it from side to side, this could be the cause of this error or if the toner is very low it could trigger the same error.
01B0 is a drum error related to your toner error message. If toner cartridge is good, remove the cartridge, clean the drum, replace the cartridge and both errors should clear. A dirty drum will also trigger your 1st error e020.
Nov 16, 2009 | Canon CLC 1120 Color Copier
Error code E020 0181 on oce cs115 how do we remove the code
Hello sir; Try to replace yellow color developer and then running"stir" or "install". should removed the error code.
Oct 09, 2009 | OCE Office Equipment & Supplies
E020 0181 or e020 0440
clean your toner sensors take machine off then on doa develpoper stir int then do a graduation adjust
Aug 22, 2008 | Canon CLC 1120 Color Copier
Error code E000020-0181
Hello Brass, This error code means that the yellow drum/developer unit has failed. Your machine has 4 drums, cyan,magenta,yellow and black. At best they are good for about 40,000 copies. You can order one online and it is fairly simple to replace. Let me know if I can help further.
Jan 03, 2008 | Canon imageRUNNER C3200 Copier
E020-0181
I don't know about the color copiers but here is a list of error codes, and their likely problems.
Looks like you will have to ge t a tech to fix it.
http://www.visualhawk.vcc.ro/canon_error_codes_en.html
Oct 23, 2007 | Canon CLC 1140 Copier
Error Code
SPECIFICALLY...you need to replace the Black drum unit.
the sequence of that particular error code is;
E020-01XX(Yellow drum)
E020-02XX(Magenta drum)
E020-03XX(cyan drum)
E020-04XX(Black drum)
Apr 02, 2007 | Canon imageRUNNER C3200 Copier
Canon CLC 1120 Color Copier Logo
540 people viewed this question
old marine
old marine
