Question about Shure UR24DB87A UHFR Dual Handheld Wireless System (with 2 Beta 87As) Microphone
Shure 87a wireless cartridge
Works when initially switched on - after about 10 seconds the signal starts to fade down to a very weak signal and it's too quiet
  • 682 Answers
Confirm from:- 1-good long life battery2-clean the switch with spray contact cleaner and move it on-off many times.3-go to the receiver and check antenna is in right positon and tight firmly to the receiver(not loose)4-put the receiver in position above head level not down or near floor.
Posted on Feb 29, 2008
Like to find out what's worng with my mic.
It's a condenser mic, so I suspect you aren't getting power to it. Make sure the phantom power is turned on on the mixer.
May 18, 2016 | Shure Beta 87A Professional Microphone
How do you unmute the Beta 87A wireless microphone
Look at the manual, the Beta 87A can be mounted on several shure microphone series. The shure web site has manuals for free.
Jan 06, 2014 | Shure Audio Players & Recorders
Weak audio static uc2-ub handheld
Sounds like either local interference or it needs to go to Shure for repair. Can you try it in another location maybe 10 miles or further away from the present location. If it operates in the MHz band you need to replace it, it is illegel to use that band in the US..
Mar 13, 2012 | Shure Beta 87A Professional Microphone
Shure Beta 87a - very weak signal compared to other 87a's in set. Not cabling, not amp.
Hello again..it's possible, just possible you have a fake beta 87a. A knockoff. Compare the physical characteristics of all your beta 87a's.
Feb 24, 2010 | Shure Beta 87A Professional Microphone
I have a Shure Beta 87a very weak output signal
Possible cause...microphone dropped on the ground.
Or possibly the capsule is fried from too much spit getting to it thru the windscreen.
Or possibly a short in one of the 3 pins/wires located in the housing where the xlr connects.
I have a Beta 87A wireless that will not power on... i have obviously replaced the batteries any thoughts
Your power switch may be damaged.
If the power button was pressed too forcefully, the switch on the circuit board in the handle of the 87A may have sustained damage. If the button no longer "clicks" when you depress it, that may well be the problem.
Oct 24, 2009 | Shure Audio Players & Recorders
Shure 87a no sound
Send the mic to Shure for repairs. www.shure.com/service
Sep 12, 2009 | Shure Beta 87A Professional Microphone
Access switches
I assume you have a wireless mic. Disassembly is dependent on the model of the wireless. However, typically, you would pop off the switches and then remove the C ring that is under the cartridge.
Jan 12, 2009 | Shure Beta 87A Professional Microphone
Shure UR24DB87A UHFR Dual Handheld Wireless System (with 2 Beta 87As) Microphone Logo
143 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
