Question about Sony Playstation 3 (PS3) Console
Ps3's working online. Laptop not working online. HELP!!
I have a ps3 connected using these settings on my linksys WRT54G router; DMZ enabled to host 192.168.1.103
the ports i got from portforward.com under goto(guides to Port Forwarding Guides by Router to WRT54G to PlayStation Network. Entered those and ports 10070-10080 TCP 10070-10070 UDP 6000-6999 UDP. UPnP enabled but not entered
in my PS3. Do I need to use the UPnP on my ps3. And when i did this my laptop's network stopped working. What do i do.
The network of your ps3 and loptop did not match try to use other IP address?
Posted on Feb 07, 2008
Nephews XBox now not connected, has worked for over a year, his Xbox is now saying that the MTU settings are wrong on the router, router hasn't changed, and I don't know how to check them, can you please...
NAT STRICT
Step 1 : Connect Router - Computer
Step 2 : open Router Setup by typing http://192.168.1.1 on the address bar of internet explorer (Default Password is Admin )
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
let me know if this works
Regards
TOM
Jan 04, 2011 | Linksys Wireless-G WRT54G Router
My NAT is set to moderate and i cant play xbox live off it. it says i have to open my NAT. how do i do that?
NAT STRICT
Step 4 : Click DMZ
Regards
TOM
Jan 02, 2011 | Linksys Wireless-G WRT54G Router
Need to change NAT type from moderate to open. possible upnp problem?
NAT STRICT
Step 2 : Open Router Setup by typing http ://192.168.1.1 ( Default password is admin )
Step 4 : Click DMZ
Dec 22, 2010 | Linksys Wireless-G WRT54G Router
Hello i need to open some ports in order for my ps3 will function properly..I need the Tcp ports open #'s (80)(443)(5223)(10070)(10080) and also need the UDP ports open #'s (3478)(3479)(3658)(10070) model...
LINKSYS ::::
NAT STRICT
Step 4 : Click DMZ
Else ...
Under application and gaming you can find port range forward
There you can open the ports one by one
And give the IP Address of the PS3 for all the ports opened
Dec 21, 2010 | Linksys Wireless-G WRT54G Router
How to get your NAT type from strict to open for a ps3. i have tried opening the ports on the router. it still does not change the NAT type
LINKSYS ::::
NAT STRICT
Step 4 : Click DMZ
Regards
TOM
Dec 06, 2009 | Linksys Wireless-G WRT54G Router
Cant connect my ps3 to wireless internet
you can auto config your network settings on the ps3, make sure you see your wiresless network, if you dont your router is not broadcasting its ssid and you need to activate it by logging into your router from a pc ( in a browser go to "192.168.1.1", username is "admin" password ia "admin" or nothing, unless you set up otherwise)
If you dont remember your WEP/WPA code you can find it under "wireless" then "security" in the router once you have gained access as mentioned above.
If all of above is ok then check your IP on your ps3 in settings, network status (i think havent done it in a while) make note of it and go back to the router as mentioned above. click applications and gaming then dmz, enable dmz and type in the ps3 ip, save settings and perform a 30 second reboot to the router (unplug it for 30 seconds) all should be good!
one last note if you have configured everything and you cant connect or it takes ages to do anything, you may need to reposition the router, mine is on the otherside of the room and is working great =p
Feb 19, 2009 | Linksys Wireless-G WRT54G Router
Found the check box - for Block WAN
I believe your initial problem was for PCAnywhere rgiht? just make sure ports 5631 (Data Port or TCP) and 5632(Status port or UDP) is properly opened/forwarded on your router's config page plus make sure that you instruct the router to forward those ports to the computer that you have PCAnywhere plus I have read some articles that newer versions of PCAnywhere 10.+ 11.+ will not work with older version 5.+
Now if it still doesn't work try setting up DMZ for you host computer(Note: enabling DMZ will open a wide range of ports, well common ports that is).
Jul 02, 2008 | Linksys Wireless-G WRT54G Router
Unstable PS3 connection
good idea to assign your own ip but no need to use dmz...
do the following:
1. reset your router to factory settings, assign urself an ip address (make sure its out of the scope of the dhcp), no need for dmz
2. enable upnp (thats what ps3 uses)
open these specific ports if u are using firewalls
TCP:
  • 80
  • 443
  • 5223
UDP:
  • 3478
  • 3479
  • 3658 should also be opened for voice chat.
also if u want to make it faster use Port forwarding and then forward the above port to your static ps3 ip address and u will get even lower pings to play games and no lag
cheers
smeags
Feb 27, 2008 | Linksys Wireless-G WRT54GX Router...
Unable to connect PS3 to my Secured WIreless Router
http://www.askdavetaylor.com/connect_to_the_internet_with_my_sony_psp.html
Jan 17, 2008 | Sony Playstation 3 (PS3) Console
Gaming
You need to set the correct address for DMZ (your PC IP address). You may also find that your PC firewall settings will need changing.
You shouldn't need to set DMZ for this, you can set port-forwarding instead, and then select the ports you wish to pass through for each IP address connected to your home side of the router.
Nov 29, 2007 | Linksys Wireless-G WRT54G Router
Sony Playstation 3 (PS3) Console Logo
87 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
