Question about Bush DVD142RC 14 in. TV/DVD Combo
BUSH BTV19SIL, TV/VIDEO COMBI
TV FUNCTIONS PERFECTLY: VIDEO WILL NOT LOAD.
DOES UNLOAD PARTLY, IF YOU INSERT TAPE PART WAY & PRESS EJECT.
BUT DOES NOT LOAD OR PLAY A LOADED TAPE.
SUDDEN MALFUNTION WHEN A TAPE WAS LOADED.
M CARTER
  • mr. melvyn carter Feb 09, 2008
    No, sorry, the problem is electronic in nature.
    The obvious things you suggest were the first I went to.
    the machine is a customers, I received it with a tape stuck in.
    I disconnected the motor , & powered it up to remove the tape,
    There was no sign of damage or bits jamming the mechanism.
    The servo IC which Drives the VCR Head & the load/ unload motor is an LB11883N.
    I was hoping someone there would know if this was a typicl problem on this model.
    Thanks, M Carter RESTORATION
    Master:
  • 788 Answers
Look inside with a flashlight and look for any obstructions in the tape cavity, like cookies, pb&j sandwiches, army men, etc...
If no obstuctions look for broken plastic guides/levers etc...
You could always carefully open it up and see if you can't watch it load a tape to see if it is doing everything it should but that could be dangerous because of the voltages present in the TV. Would probably be best for a repair person.
Also sounds like the machine does not know there is a tape there, there should be a lever that gets pushed by the tape to trigger the sensor or switch that tells the machine there is a tape in the cavity, maybe it's stuck or broken, you would have to investigate.
Given the price of these times of combo machines these days, probably not worth getting it fixed, would probably cost more than a new one.
Good Luck!
Posted on Feb 07, 2008
  • 796 Answers
Hi
the connection interfacing the tv and the combo must be loose...try to open and disconnect it and reconnect it
How do you manually eject DVD from bush 40 inch TVs/combi without remote control
hi there should be a button on the side of the tv thanks
shaun
Mar 06, 2017 | Bush Televison & Video
How to eject a CD disk from Luxor combi tv, model 16855
If no EJECT button is apparent, the CD may eject when power is removed from your combi or when a different mode of operation is selected.
Aug 09, 2016 | Luxor Televison & Video
Bush tv combo TV/VIDEO BTV19sil
If there is not a button marked 'Menu' You must have its remote control to adjust anything.
Oct 24, 2013 | Bush Televison & Video
Tape did not eject
if the tape can not eject by press the button, you can only unload it manually, but you'd better ask an expert to do it, such as me, haha.
Dec 01, 2010 | Dell PowerVault 110T LTO-2 Ultrium Tape...
My bush btv19sil is all fuzzy and i can't find the remote. WHAT DO I DO
get connected to
bush tv remote replacement . com
you will find the remote you need.
Mar 28, 2009 | Bush 2871NTX 28" TV
My Sony SLV-N750 recorder works perfectly - except..
If the door is not connected to a "tape in" interlock
Jul 22, 2017 | Sony SLV-N750 VHS/S-VHS playback VCR
BUSH BTV19SIL NOT LOADING TAPES
There is a small CAM under the foward\reverse takeup wheel. Like a combination lock, must be set in proper sequence to send a signal to eject or load tape. Panasonic VCR has them also.
Hope that this helps, Buddy
P.S. The motor\rubber assembly MUST be set in such a way that the "end of Rubber band line" reaches a certin point WITHOUT turning any more then neccessary because it wll through the switch off aligement.
The LED that the VHS tape covers when it comes down on top of and covers it will give the same problem when it is " caca ".
Feb 07, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
MINI DV TAPE WON'T LOAD
First power off the unit, then remove the DV's tape housing , power up the unit, and allowed the mechanism to go back to the unload mode, make sure that the tape posts are at unload mode. then unplug the vcr back again, put back the tape's housing in the load position (tape in) power the vcr back on and push eject button to reset tape mechanism.
Jan 16, 2008 | JVC HR-DVS3 Mini DV/S-VHS VCR
Jvc-avx1 wont eject
Try to power down the unit and the power it back up then press the eject button. If this does not work there might be a hole in the front of the unit which you could insert a paper clip which will actuate a mechanical release switch.The last thing you can try is to open up the unit and manually rotate the load and unload motor and this will eject the DVD. Restore the cover and then start up the unit to see if things are ok.
Sep 16, 2007 | JVC KD-AVX1 Car DVD Player
Samsung SCD-5000 miniDV tape deck problem
Hi, I have a SCD 5000 Samsung camera. The video plays and records. But the camera side does not show in the video screen. HELP me
Jul 06, 2007 | Samsung DouCam SCD-5000 Mini DV Digital...
Bush DVD142RC 14 in. TV/DVD Combo Logo
114 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
