Question about JVC AV-27230 27" TV
JVC T. V. Model # 26505
I have a perfect picture, but no sound. If I place a VCR tape in the VCR it plays perfectly- picture and sound. I have tried the mute button but there is no difference. I have unplugged the T.V. for thirthy minutes and then re started to no avail. It is on satellite, so I tuned my econd T.V. to the same channel and it has perfect picture and sound. Suggesstions please?
Thanks.
I can only suggest you check your audio feeds from your VCR to your TV or to your home theater system tuner(if you have one)
Posted on Feb 09, 2008
On play back I have sound but no picture
You just need to clean the video heads. You can get a tape cleaner for this, or you can do it manually.
To do it manually and it's the better option. You will need a can of Servisol Video 40 (from places like Maplin or on the Net). Some cotton buds.
Remove the top cover of the video. Once done, spray all the parts the tape touches with Servisol. Wipe any visible dust and dirt away with the buds.
Concentrate the spray to the big video head. That should look clean when done.
Leave to dry, it won't take long and try a video. If you can see the picture, but it is breaking up or has "sparkles" on the screen. Then clean the head again till it is a clear picture.
Notes: don't clean with a tape in the machine.
If you don't know which parts the tape touches. With the lid off and powered on play a video. And watch where the tape goes.
It will take longer to clean the video if anyone smokes in the room where the video is kept.
I repeat NEVER put a tape into the machine till the deck is dry.
You might have to do this again a few weeks months later.
Jun 22, 2016 | Samsung VR8705 Video Cassette Recorder...
Playback problem EP
Do you have a tracking control on the
vcr if you do it should be centered during
record It can be adjusted during playback
to clear up the picture adjust it for the best
If you dont have a tracking control on the
vcr then it may require a mechanical adjustment
of the backtension or guidepost which requires
special tools to perform
Nov 18, 2007 | JVC HR-A592U S-VHS VCR
After a long period of non-use,of my VCR, I recently tried to play a new VHS tape. It loaded properly, but refused to play it.
Could be the belts have become too old for the unit to function. you could try to take the unit apart to clean them.
Mar 25, 2015 | JVC Hr-a591u 4 Head S-vhs Hi-fi Stereo Vcr...
Video on my Sony VCR (SLV-780HF) goes gray after playing a tape a few seconds. What could be the problem?
The only real cure will be to clean the video head. If that doesn't work then I'm afraid that whatever recorded you EP mode tape was not set up well tracking wise. So other machines struggle to track the tape. Some VCR's will only playback SP or LP tapes and don't have EP mode. In which case you should check to see if these VCR's can play the EP tape and if they can't find one that can.
Dec 06, 2012 | Sony Televison & Video
Go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
JVC HR S5700AM S-VHS video recorder - won't accept tapes
Hey Lindsay
Yes the ejector is probably damaged inside maybe a bent arm or something mine is like that 2 and I didnt even bother fixing it I will be finding one very soon and I suggest you should 2 so just throw out the old and come in the new with your new vcr or dvd vcr combo..
Jul 23, 2008 | Televison & Video
Poor EP playback
hi sir
the speed in EP is differ from sp ,EP it is much slow then all quality would be less cause you are using less magnetic particles on the tape so here are many reasons for bad recording
first may be you have to clean video heads
or ,you have to clean the path of the tape in the recorder there are some metal guides that turnes with the tape to get it rounds the heads they may be dirty
or clean the capstain pinch roller and its metal roller that makes it run ( the capstain roller )
or you should have new heasd drum sir
regards
Recording from my vcr to the dvd hardrive
It may be that the tape you are trying to record from is copy-protected. You will then get a "scrambled" picture
Nov 04, 2007 | Wharfedale DVD-M3 DVD Player
VCR/Tuner Video Problem - DVD Playback Issue
What is the unit, exactly? Make, model, etc.? Your description sounds like an AFT (automatic fine tuning) problem ... but is it hooked up right?
May 10, 2017 | JVC HR-XVC18B DVD Player/VCR
JVC AV-27230 27" TV Logo
115 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
