Cars & Trucks Logo
Posted on Jan 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to know what position the dist. sits inside the engine.what angle does the vacume port face
Anonymous
Level 2:
New Friend:
  • Expert 51 Answers
  • Posted on Jan 09, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
51
Questions
0
Helped
17282
Points
154
As long as u install dist. with room to turn or adjust timing, it doesnt matter. install dist have some crank engine with cap off. watch which direction rotor turns. then start firing order with no. 1 wire at rotor and work around cap in the direction of dist rotation
1helpful
Okay thanks guys now i see there's 2 hole on both cams at the back soo my question is both must be facing upwards towards the bonnet or should it be left hand side cam in a angle and right hand cam...
Both facing upward, with the flat parallel to the engine deck. Then the #1 cylinder lobes should both be facing upward (relative to the engine deck- remember the engine sits tilted at an angle in the engine bay), and slightly pointing inward toward each other.
tip
How to Reinstall a Distributor if Crankshaft Moved.
Applys to all Distributor Engines.
Follow this easy instruccions if you want to reinstall a distributor on a vehicle where the crankshaft was moved from the position it was when the distributor was removed.
Remove #1 spark plug
Place your finger over the spark plug hole while turning the engine with a wrench on the pulley bolt at the front of the engine.
When you feel compression continue turning the crankshaft slowly until the timing mark on the vibration damper is aligned with the "0" on the engine timing indicator.
Position the disttributor rotor between the number 1 & 8 (for 8 Cil.) 1 & 6 (for 6 Cil.) or 1 & 4 (for 4 Cil.) spark plug terminals on the cap.
Lower Dist. into engine. To set the gear on the bottom of the distribuitor, you may need to turn the rotor a little bit. If the distributor does not drop down flush against the block is because the distributor shaft has not mated the oil pump shaft, if this happens, place a large socket w/braker bar on the crankshaft bolt and turn the engine over in the normal direction of rotation until the two shafts engage properly and the distributor sits flush against block.
With the base of the distributor properly seated, turn dist. housing to align the marks you made in dist. base and engine block. (you did make this marks before removal right? : )
Place the hold down clamp and install the hold down bolt not too tight.
Install dist. cap an reconect electrical plugs, spark plug wires, etc.
Check ignition timing and when set, tighten dist. hold down bolt.
1helpful
How do i replace the distributor in a 91 firebird with 3.1 v6
Best practice is to remove #1 spark plug, roll engine over by hand until #1 piston at top dead center on compression stroke. Remove dist cap , find a surface outside of dist to mark direction rotor is pointing then mark dist body position. Remove dist ,you will notice as you lift dist, rotor will spin backward keep an eye on it, when the rotor stops spinning as you lift, that will be your dropin position for new distributor. That will get you close,enough to start car but you will need a timing light to set exact timing
The air flow vent is stuck on defrost mode. when i switch to a/c or face/floor no air is directed out. the fan seems to be working fine
The air direction is vacum controlled. If you have 4X4 and ESOF ( switch in the cab) then you need to inspect the vacum lines that go to the hubs and possibly the hub seals. "default" position for air flow is the defrost position. If you DON'T have 4X4, and it's a diesel engine, inspect the vacum pump, If it's a gas engine then look at all the vacum lines from the intake manifold for a leak.
1helpful
Had a miss so I changed my wires now it will barley run I need to know the order so I can see if I got them mixed up . It's a 79 304
Standing in front of the engine the cylinders are positioned as:
FIREWALL
8 7
6 5
4 3
2 1
RADIATOR
The firing order is 1-8-4-3-6-5-7-2.
this is for a 1979= 304 engine, the rotor in dist. turns clockwise, #1 cylinder on cap is facing towards the front of engine. have a good day !!
I want to know what code 41 cam position sensor means or what needs to be fixed.
SHOULD BE 4.9 ENGINE / SENSOR IS INSIDE DIST. / MAY BE CALLED HALL EFFECT SWITCH OR SENSOR
1helpful
I need to know how to install the distributor rod(at what position and the position of piston) and the firing order send diagrams.
turn the crank with # 1 plug out untill you are on the compr stroke ,allighn the timing mark to 0, drop dist in so that rotor is pointing at # 1 cyl ,you also need to allighn the oil pump slot with the slot on the dist . make sure the dist ha s seated all the way down . vacume advance will be on the pas side pointed at the front wheel . put cap on and start with # 1 go clockwise 18436572.
Have 97 cherokee sport 4.0 has trouble startingt but
Vacuum you are seeing is about 13inches low. either something is causing the timing to stay retarded or the timing chain is stretched beyond it's limit. Id check the MAP and throttle position sensors as they have influence over timing (and fuel mixture) and check the chain for stretch. Since you had the distributor out, it is also possible that you have installed it one tooth off...that also can ****** the timing.
1990 K5 Blazer DIED(Electrical?)?
There may be no injector pulse if the computor does not see a RPM signal.
There will be no spark if the ignition module does not see a dist pulse from the dist pickup.......a RPM signal.
Because you do not have both ......I would suggest to check/change the dist pick up.
Follow the wires from the ignition module inside the dist to the pickup which is also inside the dist.
If it is just a bad dist pickup....keep all your old parts as good spares.
Also...is the dist turning? to provide a RPM signal?
You will have to remove the dist to change the pick-up.....mark your timing locations......"rotor position" and "dist body location"before removal.
A quick test before installing the "repaired dist" .....plug it in the the truck wiring and turn on the key....DO NOT CRANK THE ENGINE OR YOU WILL LOSE YOUR DIST ROTOR CORRECT POSITION......as you spin the dist by hand .....the injectors should spray.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
