Question about Bosch PB10-CD Radio/CD Boombox
Won't charge battery
If I use a "charged" battery on my radio, it will run until the battery is dead. Plug it in and it will continue working, however, it will not charge the dead battery. I must charge it in a different charger. Why?
  • 3 more comments
  • froggy1972 Feb 07, 2008
    OOps! I should have added that I purchased a new battery just to see if my batteries (2) were bad. Also, those original batteries only took a charge maybe 100 times, if that. And the new battery...nothing. So, I tried charging all of these batteries on a friends radio...and they charge fine.
  • ramon33 Apr 19, 2008
    battery not charging. I bought a new bosch 14.4 volt battery. The battery did have a little charge when I first placed it in the radio. When the battery died the radio shut off and now when I plug the battery back into the radio it displays that it is charging than the charging battery display shuts off and does not charge. The rest of the radio works fine.
  • heco1 May 15, 2008
    My Radio will not work unless it has a fresh battery. If plugged into A/C the Outlets (on radio) have power but the radio will not function.
  • podger trace May 17, 2008
    i have charged battery by plugging into the socket and when i turn radio on it cuts out even if i use a fully charged batt charged on my drill charger. but if i plug it in to the plug socket and turn on radio then un plug it it will work as normal untill batt runs out (almost like a bump start) any solutions ?
  • Anonymous Jul 05, 2008
    yes
    Master:
    Sergeant:
  • 440 Answers
Battery worn down need new one they only last so many hours ok thx nick
Posted on Feb 06, 2008
  • nick helpap
    nick helpap Feb 07, 2008
    well what type bateries this take they make chargers on ebay this ones for 20 bucks does all sizes
WHITE OUTDOOR ZERO TURN MOWER MODEL #13AT626G190 WON'T STAY RUNNING AS BATTERY GOES DEAD HOW CAN I CHECK THE CHARGING SYSTEM?
put a volt meter on the battery then start it and check the voltage before and after if it is not more running it's not working if it is not charging remove the top cover from the engine and see if mice chewed the wires
Jul 04, 2012 | Garden
T will indicate charging but it won't charge actor
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 23, 2012 | HP Compaq nc6400 Notebook
My vivitar x345 wont hold charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | Vivitar ViviCam X345 Digital Camera
Laptop Battery Won T Charge on a laptop dell inspiron 1525
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Mar 19, 2012 | Dell Computers & Internet
Agptek replacement battery not working
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Nov 20, 2011 | Toshiba Satellite M115-S1061 Notebook
Inspiron mini 10 Running on battery even when a/c is plugged in restart computer and plug in a/c again and charges up but then drains battery again
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Dell Inspiron Mini 10 Notebook
Lenovo y550 laptop, battery shows fully charged, everytime i un-plug the charger,system shuts down, and won't start back up until i plug it into an outlet
Quite simply, the battery is dead. What is happening, is that the battery is charging, but the cells cannot retain the charge and it drains straight away. You need a new battery
Jun 16, 2011 | Computers & Internet
Battery will not continue charge after a few seconds
Run the battery all the way down until completely dead and then try recharging. Nickel metal hydride (NiMH) batteries don't develop a "memory" quite like the old nickel cadmium (Ni Cad) batteries, but this seems to work when my cell phone won't hold a charge for more than a day.
Mar 16, 2009 | Kodak EasyShare Z760 Digital Camera
Bosch PB10-CD Radio/CD Boombox Logo
365 people viewed this question
Top Bosch Audio Players & Recorders Experts
wayne-m
Marvin
Marvin
Are you a Bosch Audio Player and Recorder Expert? Answer questions, earn points and help others
