Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Picture is suddenly "bowed" and the convergence is askewed at everypoint but center.
My Akai PT5598HDIX rear projection TV has been working fine for the past 3+ years. I had it on this morning (it was fine), then turned it on again a few hours later, and the screen is now "bowed" (like a bow tie) and the convergence is off at everypoint but center. You can see the three images (Red, Blue and Green) of the same picture simultaneously offset and overlapping one another on all sides. [Icalled] The Customer Care Center suggests that I call the local TV Repair shop to have someone look at it, but I think there should be a way to fix it myself (remotely). I have retreived and recorded (on paper) all of the menu settings (using Mute, 1, 8, 2, power) and then tried the "reset" function with no success. Any ideas?
  • 2 more comments
  • Anonymous Feb 07, 2008
    same problem
  • Red Stripe Feb 23, 2008
    same problem after 3 years of use. HELP!!!
  • g6chamelion Mar 02, 2008
    I had a tech (very difficult to find...35+ miles away) come out to the house to diagnose. He removed and repaired the convergence box. This process took about 5 days to find a tech, 5 days for the appointment to be scheduled, and 5 days for the fix...There were multiple fried circuits in the box. Although this corrected the "bow," the picture was not anywhere near normal. The picture was shrunk and slightly twisted, but more legible! This better, but not right correction cost was $220!...Nice guy...he cut me a break from the original quote of $395 since the fix wasn't right. He suspects another board may need to be removed and sent out (2 weeks or so at a cost of about $400-500 additional) to diagnose and hopefully make everything right.
    I sat down and played with the adjustments (which would not work before the Convergence box was fixed) for about 2 hours and fudged the picture on the screen so that you cannot tell that anything was wrong...it looks new again...for now.
    Thank you again for the help.
  • 1alison Aug 13, 2008
    all of the sudden i turned my tv on and the screen lokked like a bow. the tv is only 1 1/2 years old. help!!!!!!!!!!!!!!! i have messed with all the settings forever!!!!!!!!!! and then got online.
    Sergeant:
  • 395 Answers
The problem is the EW cicuit of the deflection cicuit. this is a component level repair call a tech. the EW or East West correction is apart of the horizontal deflection. IC431 is the pin amp.
Posted on Feb 06, 2008
I have an akai 55" projection tv and the top and bottom of the picture is bowed with green and red colors which makes it look like a 3-D movie. how can i fix this problem and what will it cost to fix and...
The tv have a problems known as a convergence problems,it dead.Yes,try website like Tvrepairworld.com to buy a whole rebuild convergence board for the replacement.The Akai/Samsung use the same tv convergence board.The board around $200.
Sep 09, 2010 | Akai PT5598HD 55" Rear Projection...
AKAI rear projection TV won't turn on
possiblity convergence needed...
main power board malfunctioning
contact akai service center
Apr 26, 2010 | Akai PT4298HD Rear Projection Television
Same problem as above, picture bowed top and bottom, convergence
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 19, 2009 | RCA P52939 52" Rear Projection Television
AKAI PT5598HDIX, the picture is ghosting
Convergence - many other posts here. A sample: http://www.fixya.com/support/t634294-replaced_convergence_board_picture_still
May 01, 2009 | Akai PT5598HD 55" Rear Projection...
Need a remote for a pt5598hdix akai tv
Here's a link to order the original Akai remote control for this model (PT5598HDIX) from a major parts distributor:
Akai PT5598HDIX Replacement Part Remote Control
Also available in a cheaper version made by Samsung (which makes parts for Akai units) below:
Samsung PT5598HDIX Replacement Part Remote Control
Feb 15, 2009 | Akai PT4298HD Rear Projection Television
AKAI Rear Projection TV PT5598HDIX has sound but no picture
double check your solder connections on stks,check pico fuses they go bad check connections . see if high voltage lead is connected .
I do alot of these and have run into same thing and i had bridged a solder connection.
I hope this helps
thanks doctor video
May 01, 2008 | Akai PT5598HD 55" Rear Projection...
Sudden discoloration, ghosting, bowed horizontal lines in top and bottom of picture
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 10, 2007 | Samsung PCL6215R 62" Rear Projection...
Hitachi projection tv model 3 51gwx208
Do you mean that at the top of the picture, the red color has shifted downward, bowed towards the center? If that is what you see, one color suddenly bows toward the center on any side of the picture, then it means that one of your convergence IC's has burned out and needs to be replaced. It is a good idea to go ahead and replace both STK392-110 IC's with the newer improved STK392-150's. If you have never replaced convergence IC's and realigned the convergence circuits in a projection TV then allow a qualified tech to handle it for you.
Aug 05, 2007 | Hitachi 51GWX20B 51" Rear Projection...
Akai tv
have a good tv guy repace you convergence amp's john
Jul 31, 2007 | Akai PT4298HD Rear Projection Television
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
286 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
